Author Topic: Log weight log home construction  (Read 970 times)
Offline Edvantage
« on: March 30, 2019, 05:13:03 PM »
Logger just cut down 30 red pine trees for me for my log home project. I have a knuckleboom crane I plan to mount in the middle of the house for lifting logs. I just cut a 6in. piece off each end of a 46ft log (20in butt 14in tip) Together the two pieces weigh 92 #s which gives me #s per foot of log x 46ft = 4000#s . The calculator I used said this log should weigh 3340#s @ 75% moisture so I am assuming I am at the high end of moisture content. My crane is rated for 3312#s at the reach I need. So at the current moisture % I am too heavy. How soon might I expect to loose some of this weight? I cannot get the logs delivered until load restrictions come off in mid may and was hoping to leave bark on until then. So I would not be lifting these until June. If I had to peel them sooner I could but would be a little more difficult due to the location
Online barbender
Re: Log weight log home construction
« Reply #1 on: March 30, 2019, 07:45:28 PM »
Nice logs👍If anything, the ends you cut off will have a little less moisture than the rest of the log. I don't think they are going to dry substantially in the time frame that you have, even if you do peel them. Even then you will be working right up at the limit of your cranes lifting capacity, which is never good. You must be building off site of your foundation if you are set up inside the building? Can you move the loader around the outside instead?
Offline Edvantage
« Reply #2 on: April 08, 2019, 07:16:34 PM »
Turns out my scale was off a little when I corrected it the log weight calculator and my actual weight are very close. My full length logs will be at max crane capacity but if I cut at door openings I can minimize these. The plan is to use the crane in center of house and lift it out later. The building site is too steep with walkout basement to use loader. Being able to setup in one location and not reposition a loader for each log will save lots of labor. Crane has a base that travels  on parallel I beams which will be left as  as floor support beams.
Offline ljohnsaw
« Reply #3 on: April 08, 2019, 08:44:12 PM »
Don't discount lifting one end of the log at a time.  With proper restraints, you should be able to do that safely.  What time of joints are you doing?  Butt & pass or scribe?
Offline Edvantage
« Reply #4 on: April 08, 2019, 09:07:31 PM »
Full scribed
Online barbender
« Reply #5 on: April 08, 2019, 09:50:00 PM »
If you buck your logs for doors and windows, you will reduce your max length lifting on most home designs a LOT!👍 It sounds like you have a solid plan.
Offline fishfighter
« Reply #6 on: April 11, 2019, 08:19:50 PM »
If you look down towards the bottom of the page, you will see a red tool box. Click on that. There is all kinds of info there and even a log weight tool. 8)
Myself, I would start peeling them suckers asap before it warms up and bugs attack.
Offline Edvantage
« Reply #7 on: April 12, 2019, 05:25:15 PM »
The log weight tool proved quite accurate. We are still buried in snow. I laid unblock for my basement last fall, a month ago I had 6 1/2 feet of snow in it. Melted down to a couple feet and got another 12"last night. I am not too worried about bugs before June with this kind of weather hope to have logs peeled by then. I have three boys that can't wait to peel logs actually my girls are fired up to get going also.
Offline btulloh
« Reply #8 on: April 12, 2019, 05:39:20 PM »
smiley_thumbsup
HM126
Offline Edvantage
« Reply #9 on: April 12, 2019, 05:56:15 PM »
Block Layers
Offline Edvantage
« Reply #10 on: April 12, 2019, 06:01:51 PM »
Snow in March
Offline Andries
  • Making buildings out of big curvy logs
« Reply #11 on: April 12, 2019, 07:11:56 PM »
A great start to a big project! It takes some courage and a solid family.
Growing up in a big family with a big project like this is so familiar - it's how I grew up too.
I'm going to agree with all the responses above, including lifting one end at a time. you can do a lot with ingenuity and 'where there's a will there is a way'. Just go slow and figure out a safe way to get it done with what you have.
Here's my last project, snow included, but not anywhere what you lake-effect folks get;
Your logs will release moisture (and weight) very slowly, measure in years, so allow plenty of space above doors and windows for settling and a bit of shrinkage.
Peeling is better done sooner, rather than later.
Please keep posting pictures and updating your progress.
You'll get any and all questions answered here - these other guys are some smart rascals!
:D ;D :D
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline Edvantage
« Reply #12 on: April 12, 2019, 08:06:44 PM »
It's how you grew up and look what you are doing pretty cool. I have 10 kids oldest boy is 20 and moved out of state 2yrs ago. Recently came home and told me how much he loved all the stuff we did when was growing up.
Questions on Log home Construction
Started by hbeane on Timber Framing/Log construction
Last post July 06, 2016, 04:56:59 PM
by ppine
exclamation
Need logs for log home construction
Started by SmileSurferStyl on Forestry and Logging
Last post March 01, 2019, 06:30:42 PM
by BargeMonkey
Looking for ideas on log home construction
Started by customcutter01 on Timber Framing/Log construction
Last post April 22, 2018, 02:26:26 PM
by mike_belben
Question regarding use of rough sawn lumber for home construction
Started by brdmkr on Sawmills and Milling
Last post August 24, 2005, 08:11:20 PM
by Don P
