Author Topic: splitter opinoins  (Read 2096 times)
Online stavebuyer
Re: splitter opinoins
« Reply #20 on: February 08, 2021, 04:44:21 PM »
I really like the Eastonmade Ultra. If Andrew could incorporate a log lift he probably couldn't keep up with orders. He has done much in a short time advancing splitters. I hope his taking on the Bells processors doesn't cause him to loose interest in splitters.
Offline hedgerow
« Reply #21 on: February 08, 2021, 05:46:13 PM »
For what I do, I'd want the speed of the smaller cylinder. Too many people go with a splitter that will split the biggest ugliest hardwood crotch they can find, when those are such a small part of what you'll probably end up splitting. Half the time they're not worth the fight anyhow. Watch the videos on the Eastonmade Ultra, they split some stuff that is ugly enough, and I believe they use a 3.5" cylinder.
I couldn't agreed with this more. I split most of the 15 cord of hedge and locust that I burn a year with a homemade splitter with a four inch cylinder and a 28 GPM two stage pump. I like the speed over the strength of a five or six inch cylinder.
Offline jmur1
  • Wood is King
« Reply #22 on: February 08, 2021, 06:14:03 PM »
Hi trapper:
I have not used any of those heavy build splitter units but I can say from my own processor the multiwedge adjustability is absolutely necessary for my logs.   I have noted that the Eastonmade units have several things that I would include with my splitter (when I make a new one).
1. Adjustable wedge.
2. Log chunk sits above beam (raised bed) so that adjustable down is possible without clearing previous splits.
3. 1st wedge angled upward so not to drive the chunk down into beam and therefore driving wedge up.
4. Chunk centering so hands can stay clear of operation if desired.
5. Heavy build for real world use.
6. Heavy hydraulic wedge - I have seen alot of damage to these parts and can only imagine how quick some of the lighter units would be ripped apart.
Good luck
jmur1
Easy does it
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #23 on: February 08, 2021, 06:18:52 PM »
My processor has a 4" cylinder.  Seldom do I come across pieces that can't be split :)
Offline trapper
« Reply #24 on: February 08, 2021, 10:31:19 PM »
Good point barbender but no need for speed at my age.  But then again I help a lady split wood that sells campfire wood.  Her deceased husband made a splitter using a vw engine and a 6 or 7 inch cylinder.  He used a single stage pump.  It has about twice the cycle time as my 37 ton box store splitter that has 5 or 6 hp engine.  Times I have to be careful not to stall the engine on her machine.
Offline Ed
« Reply #25 on: February 08, 2021, 11:26:09 PM »
Timberwolf TW-5 here, log lift and adjustable 4 way wedge. It's old enough it has the auto-cycle also.
Very pleased with it, been a trouble free machine.
Ed
Offline gasman1075
  • I'm lucky
« Reply #26 on: February 09, 2021, 09:59:21 AM »
I agree I had the same luck with all my Timberwolf splitters.
Just a TW1 for now and the immediate future.
JD 2302R/Stihl MS461/Stihl MS261/ Timberwolf TW-P1/ new left hip /
Offline barbender
« Reply #27 on: February 09, 2021, 12:37:08 PM »
There are a lot rumblings and complaints about the new ownership at TW. I haven't really heard from any Bruteforce owners, I've seen nary a complaint from Wolfe Ridge and Eastonmade customers.
Offline Bruno of NH
« Reply #28 on: February 09, 2021, 06:50:34 PM »
Andrew says he has some new things on the horizon for splitters and the extra room at the Bells location will help him cut down on lead times.
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #29 on: February 09, 2021, 11:46:46 PM »
Here's my Wolf Ridge 35 high output.  I upgraded to the auto cycle, electric start Honda, and 6 way wedge.  Comes with the 4 way, so I have both.  Hydraulic log lift and wedge up/down are game changers, and so is the 8 second cycle time.  5" cylinder, 4" heavy duty ram.  The return stroke is super fast, and if I stage my logs, or have a helper (which I do), I can split 3 cords an hour.
This is a true 35 ton machine.  I split a lot of HUGE nasty tree service wood, and this thing is incredible.  Nothing it can't split.
The other half of the log lift is in the "Stow" position for towing.  Awesome machine.  I split 31 cords of firewood in January this year alone.  Very happy with it.  Well worth the money.
I'd also recommend staying away from the chinese Rugged Made machines, if you want to actually work it hard.  A friend bought one, against my warnings, and is having all kinds of trouble with it.  There's a reason it's so cheap, and that's because every component on it is as cheapo as you can get.
Offline mike_belben
  • Pulp Friction
« Reply #30 on: February 10, 2021, 11:35:18 AM »
i spy a milwaukee milling machine.  8)
Psalm 37:16
Offline Chipmeister
« Reply #31 on: February 10, 2021, 04:40:38 PM »
Can you please give details about the "all kinds of trouble" your friend is having?
There is a huge price difference between your 35 which is probably about $17,000 (with lift, adjustable wedge and 6 way) and the ruggedmade which is $4,000 (delivered). My demand is very different. My annual splitting will be about 15 cords per years vs your 30 cords per month or whatever it averages.
I am 100% on board with Buying American, and do whenever it's possible given all factors. I'm looking at USA made steel toed boots right now. I can find those. However, when any of us need or want to buy a new TV, that is going to be a tough job!
Offline woodworker9
« Reply #32 on: February 10, 2021, 11:17:45 PM »
Kearney and Trecker Model 2K, universal horizontal with the 5:3 ratio high speed universal head.  It's a dandy.  They don't make em' like that anymore.
Offline woodworker9
« Reply #33 on: February 10, 2021, 11:33:59 PM »
Chipmeister
My 35 HO was $10,500, and I got a discount for paying cash cash.  I don't know if there have been price increases (probably should since he's 6 months out on orders), but the price list is posted on the website.
I am not gonna spend any time discussing a chinese made machine.  He's getting rid of his, as he's sick and tired of it not functioning correctly. Probably gonna lose $1500 or so selling it. I won't help him fix it, as I warned him not to buy it in the first place.  I do a LOT of machining and repair work in my shop, and I don't work on chinese machines.  Buy quality, and cry once.
I know he tried using it like a commercial machine should be used.....all day long, and he got the hydraulic fluid wayyyyyy too hot because they designed it poorly with that 12 gallon rated hydraulic reservoir, which really is going to hold only 9 to 10 gallons.  The heat probably damaged the seals on his components....don't know for sure, but that's what his problems stem from.  chinese junk.....
Offline mike_belben
  • Pulp Friction
« Reply #34 on: February 11, 2021, 11:35:01 AM »
i had to look that name up.. now i realize that the machine i recall wasn't a milwaukee brand, it was a Kearney and Trecker "milwaukee" model.   interesting past time the industrial revolution was.  definitely defined much of the northeast.
Psalm 37:16
Offline Arctiva
« Reply #35 on: February 11, 2021, 12:01:37 PM »
I use a 30" warrior on the bobcat. Paid 2k for splitter I sit in the cab and push a button. I can stack and split at the same time. I tried a 4 way wedge but was like campfire wood and alot of waste so stuck with the single wedge.
At 44 years old I'm trying to work smarter and dont want all the extra handling of the wood. Alot of the wood I handle is 24"+ around so made sense to get bobcat splitter since I had a bobcat already
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #36 on: February 12, 2021, 07:01:49 AM »
OMG Arctiva, you are so old!  :D :D  I wish I could throw wood around now like I could when I was 44. :-\
But seriously Arctiva, you are smart to take care of your back now because you'll still want to use it when you're 72.
Offline trapper
« Reply #37 on: February 17, 2021, 09:06:25 PM »
Wife and I drove up to look at the wolfe ridge splitters in person.  Put a deposit on a 28 pro.  looks great now to wait until the end of june for it.  The desk chris uses is made from a big slab.
Offline hedgerow
« Reply #38 on: February 18, 2021, 12:04:48 PM »
I think you will like your new {TOY} tool. It will give you something to look forward to and get your mine on this weather. June will be here before you know it.
Offline trapper
« Reply #39 on: June 01, 2021, 11:19:33 AM »
Wish  i had the new splitter with log lift tree trimmer left a load of honey locust with some butt peices over 30 inches across.  Cut them down some with chainsaw but still heavy to resplit.  Also some black walnut butt cuts that big.  Any black walnut over 4 foot long I will make into lumber.  New splitter should be here by end of june.
Rugged Split 37 ton splitter/splitter suggestions?
Started by jbos333 on Firewood and Wood Heating
Last post November 14, 2014, 08:57:15 AM
by ckhenshaw4
Hand powered log splitter, the Smar-Splitter??
Started by Chuckolicious on Firewood and Wood Heating
Last post March 23, 2010, 01:50:09 PM
by Ernie
Log Splitter
Started by kmorgan on Firewood and Wood Heating
Last post December 18, 2013, 05:40:18 PM
by thurlow
New splitter
Started by goose63 on Firewood and Wood Heating
Last post July 05, 2015, 12:13:04 PM
by PaulR
