Ideal Deck Height for a Manual Mill?
Started by jpassardi, March 15, 2021, 01:09:45 PM
jpassardi
Gents,
What have you found to be the best deck height for a manual mill without a log turner? In my case an LT15. I have a machine to load so that's not an issue.
I may build a winch claw turner like WM sells for the LT28 & 40 though.
I'm thinking 24" to the bunks - thoughts?
GAB
I'm thinking one's height may affect the desired height.
You mention LT28 & 40.  Can you use those machines for a basis for an answer for yourself?
GAB
Patrick NC
24" is probably in the ballpark depending on how tall you are. Mine is 28" and I'm 6'3".  That seems to be the sweet spot for me to handle logs comfortably without bending down too much.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
RAYAR
I would say if you're handling a lot of 24"+ logs, I'd likely aim closer to the 24" bunk height, but if you're mostly milling smaller logs, in the 18" and under, I'd aim for a bunk height closer to 30". Your height should also be considered, I'm 5'-8".
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (431,000 Km)
Hard to turn the big logs if you get the height too high.  Most logs are turned with you standing with your feet on the ground.
jpassardi
Thanks, I think I'll make some cross timbers and set up at 24" to bunks and adjust from there if needed.
