Author Topic: My New Processor  (Read 2594 times)
Offline mike_belben
  • Pulp Friction
Re: My New Processor
« Reply #40 on: April 25, 2021, 09:24:02 PM »
Sign me up for that deal.
Isaiah 48:10
Offline hedgerow
« Reply #41 on: April 26, 2021, 09:23:29 AM »
Corley5  Looks like the new to you live deck is working out nicely. I have wanted one for my homemade processor but any I found were thousand or more miles from me and they wanted good money for them. With me only doing 15-20 cord a year for myself I can live without one. I didn't even use the processor last year as most of the hedge we did was so crooked and smaller it wasn't worth trying to run it threw the processor.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #42 on: May 10, 2021, 09:17:05 PM »
  It's working good 8) 8)  I can get it 2/3s full without advancing.  That's working out.  I put that much on and run it which gives me 2/3s of a load on the 550.  I put the same amount on and have a third left when the truck is full.  I can then completely fill it and the next load I don't have to run the Bobcat at all if I don't want to ;D ;D 8) 8) or with a third left I can fill it :) :) :)  The chains and rails are getting some of the 30 or so years of rust polished off and loosening up.  The short deck needs to be installed to serve as a descrambler before the processor.  There's a reason to use both of them.  I'll install it when I move everything into the other building later in the summer.
 The hydraulic motors are mounted wrong.  They should be below the rails. Where they are a crooked or knotty stick with the crook or knot down catches the motor and messes up the advance.  A definite design flaw.  And for this machine they should be on the opposite side.  Nothing a little time cutting and welding can't fix.  Considering I've got less than $1,200 including fuel into the whole mess of stuff I'm not complaining ;) ;D :) 8) 8) 8)  It works.  I've put over 50 cords of 100" over it.  I've spent way more and ended up with way less :) :)
Offline Corley5
    • Whittaker Farms
« Reply #43 on: May 10, 2021, 09:28:34 PM »
Before I had to be careful of the building's header with the Bobcat's loader arm's.  Now I have to be careful not to load the deck too tall ;D :D ;D
Offline mike_belben
  • Pulp Friction
« Reply #44 on: May 10, 2021, 09:41:40 PM »
Pics or it didnt happen!
Isaiah 48:10
Offline Corley5
    • Whittaker Farms
« Reply #45 on: May 11, 2021, 06:35:01 AM »
;D :D 8). Maybe today  :)
Processor Build, Home Made Firewood Processor
Started by Higgo on Firewood and Wood Heating
Last post September 17, 2018, 08:52:41 PM
by hedgerow
Leveling processor vs standard track processor
Started by quilbilly on Forestry and Logging
Last post December 23, 2017, 12:46:21 PM
by Skeans1
Got a new processor on TJ 608
Started by Mike_M on Forestry and Logging
Last post February 16, 2021, 09:44:52 AM
by JCHSRH
processor
Started by woodmills1 on General Board
Last post February 07, 2002, 05:45:14 AM
by woodmills1
