Author Topic: 14 12 Block Buster videos  (Read 712 times)
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« on: July 05, 2021, 11:03:35 AM »
Should have put a sharp chain on  ;) :D ;D
Offline Corley5
    • Whittaker Farms
Re: Trying out this video stuff
« Reply #1 on: July 05, 2021, 08:34:44 PM »
Loading the deck with the 753.
Offline Corley5
    • Whittaker Farms
« Reply #2 on: July 05, 2021, 08:35:58 PM »
New Bar and Chain.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: July 05, 2021, 11:05:21 PM »
Heck yeah.  Looks great.  Boy you move some wood.
Isaiah 48:10
Offline Corley5
    • Whittaker Farms
« Reply #4 on: July 06, 2021, 02:15:43 PM »
I did just short of 1,500 face cord/500 standard cord in 2020.  I'm on track to at least match that this year.
Offline thecfarm
Re: 14 12 Block Buster videos
« Reply #5 on: July 07, 2021, 05:52:43 AM »
Looks like you keep a few bars on hand.  smiley_thumbsup
Offline samandothers
« Reply #6 on: July 07, 2021, 06:57:33 AM »
Makes my back ache! :)
Offline mike_belben
  • Pulp Friction
« Reply #7 on: July 07, 2021, 08:37:11 AM »
Corley how many hp, psi and gpm is that unit putting out?
Single gear pump or multiple?
Isaiah 48:10
Offline Corley5
    • Whittaker Farms
« Reply #8 on: July 07, 2021, 09:57:33 AM »
  Honda GX670 24hp, I've not confirmed the gpm but recall something about it being 25 or 28.  Which seems high for the hp.  Runs 2,800psi.  Double gear pump.  Big section runs the splitter and saw.
 I get about 500 face cords out of a bar unless there's a mishap ;) ;D
 Way less back aches than wielding a chainsaw and wrestling blocks on to a splitter :D :D :) :) 8) 8)
Offline mike_belben
  • Pulp Friction
« Reply #9 on: July 07, 2021, 10:34:50 AM »
Dash 8 or so hoses to the saw motor?
Isaiah 48:10
Offline Corley5
    • Whittaker Farms
« Reply #10 on: July 07, 2021, 10:52:45 AM »
It's more complicated than that ;)  3/4" from the power beyond feeds a sequencing valve controlled by pressure from the saw bar valve/cylinder supplied by a 3/8" line.  1/2" feeds and returns oil from the saw motor from that  :) ;D  When the log is clamped hydraulic pressure actuates the spool in the sequencing valve and turns on the motor.
Offline mike_belben
  • Pulp Friction
« Reply #11 on: July 07, 2021, 10:57:14 AM »
ahh.
Cant trust the operator to use his own sequencing valve per the product liability insurance reviewers initial report.
Forgot about that.
Isaiah 48:10
Offline Corley5
    • Whittaker Farms
« Reply #12 on: July 07, 2021, 11:33:01 AM »
I misspoke.  Pressure is supplied by the log clamp to actuate the saw motor and move the saw bar.  Clamping and sawing are done with one valve.  When Multi Tek first came out with the 1610 there were two valves to use.  You clamped the log and then pulled the valve for the bar and saw.  Block Buster's system then was far better.
Offline mike_belben
  • Pulp Friction
« Reply #13 on: July 07, 2021, 05:23:43 PM »
Thats a horse of a different color.  Is the clamp cylinder and bar stroke cylinder teed in upstream of the saw motor?
 the saw motor engages softly as the clamp gets tight? Or the clamp tightens then saw bar begins to move and saw motor comes on full force after a certain pressure rise?
Does the saw motor spin in reverse when you raise the clamp?
Isaiah 48:10
Offline mike_belben
  • Pulp Friction
« Reply #14 on: July 07, 2021, 05:28:42 PM »
Im rereading and looking closer at the vid.. I think youre saying Oil pressure in the clamp circuit acts against a spool that starts the saw motor.
Isaiah 48:10
Offline barbender
« Reply #15 on: July 07, 2021, 05:33:23 PM »
Not sure and I've never even looked at how it's plumbed, but my Dyna works the same way. You bring the clamp down, and when it hits a preset pressure (I think it's around 1000psi) the saw motor starts and the bar starts to feed. The saw motor starts fairly abruptly, too.
Offline Corley5
    • Whittaker Farms
« Reply #16 on: July 07, 2021, 06:14:56 PM »
Yes and no.
Offline mike_belben
  • Pulp Friction
« Reply #17 on: July 07, 2021, 11:08:43 PM »
Maybe just as simple as a pressure switch engaging a solenoid diverter valve or something like that.
Isaiah 48:10
Offline Tin Horse
« Reply #18 on: July 08, 2021, 08:32:27 AM »
My Bell 1000 works as Mike describes it also. On a single valve. I can clamp and not engage the saw until a slight pressure increase.
Bell 1000 Wood Processor. Enercraft 30HTL, Case 580SL. Kioti 7320.
thumbup
A Brain Buster
Started by CHARLIE on General Board
Last post May 18, 2010, 11:47:10 PM
by Brucer
Noise Buster Earmuffs
Started by Tom Sawyer on Health and Safety
Last post June 03, 2008, 09:29:44 AM
by Tom Sawyer
Pulley Block / Snatch Block
Started by Saki on General Board
Last post January 24, 2003, 02:21:31 PM
by Saki
Here's a brain buster, wood handle steam fit??
Started by Brad_bb on General Woodworking
Last post February 04, 2011, 07:43:36 PM
by MattJ
