Author Topic: taco pump  (Read 437 times)
Offline xlogger
taco pump
« on: July 11, 2021, 06:24:00 PM »
On my CB I use it about year round, mainly for my wood kiln. I cut it on this morning and the pump didn't seen to be working. First thing I though about was maybe air locked. I've had that happen several times. But this time it don't seen to be the problem. I can feel the pump working but no water flow. Can the pump itself not pump while running? Maybe just worn out.
Offline barbender
Re: taco pump
« Reply #1 on: July 11, 2021, 06:26:11 PM »
The impeller could just be shot.
Offline mike_belben
  • Pulp Friction
Re: taco pump
« Reply #2 on: July 11, 2021, 08:43:24 PM »
Or have fallen off the shaft.  Pull the cartridge apart.
Isaiah 48:10
Offline trapper
Re: taco pump
« Reply #3 on: July 11, 2021, 09:53:51 PM »
I have had several taco impellers
disintegrate
Offline xlogger
Re: taco pump
« Reply #4 on: July 12, 2021, 06:21:48 AM »
I went ahead and order a new one, this time I got a stronger one. Went from 007 to 011. I was close to the pickup with the 007, maybe too much for the pump. I'll take the one off and check it out. If I can fix it I'll have a spare.
Offline thecfarm
Re: taco pump
« Reply #5 on: July 12, 2021, 06:33:52 AM »
My dealer had a variable speed pump. Would go from 007 to a 011??
Online K-Guy
    • http://www.nyle.com/
Re: taco pump
« Reply #6 on: July 12, 2021, 11:15:25 AM »
Many of these pumps will not self prime. It may just have air in it.
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline xlogger
Re: taco pump
« Reply #7 on: July 12, 2021, 01:59:53 PM »
I have prime it several times over the years, but not this time.
Taco pump
Started by Ivan49 on Firewood and Wood Heating
Last post March 03, 2015, 08:38:56 PM
by jcmc
What is another brand pump to replace Taco 009 F5
Started by Superclyde007 on Firewood and Wood Heating
Last post September 25, 2018, 03:49:39 AM
by E Yoder
Taco 011 - Will This Pump Orientation Work?
Started by LegendsCreekFarm on Firewood and Wood Heating
Last post July 12, 2016, 08:33:42 AM
by LegendsCreekFarm
Is there a limitation on what 1/25 hp TACO pump and push?
Started by DR_Buck on Alternative methods and solutions
Last post February 10, 2014, 09:44:24 AM
by WmFritz
