taco pump
Started by xlogger, July 11, 2021, 06:24:00 PM
xlogger
On my CB I use it about year round, mainly for my wood kiln. I cut it on this morning and the pump didn't seen to be working. First thing I though about was maybe air locked. I've had that happen several times. But this time it don't seen to be the problem. I can feel the pump working but no water flow. Can the pump itself not pump while running? Maybe just worn out.
The impeller could just be shot.
mike_belben
Or have fallen off the shaft.  Pull the cartridge apart.
Praise The Lord
trapper
I have had several taco impellers
disintegrate
xlogger
I went ahead and order a new one, this time I got a stronger one. Went from 007 to 011. I was close to the pickup with the 007, maybe too much for the pump. I'll take the one off and check it out. If I can fix it I'll have a spare.
My dealer had a variable speed pump. Would go from 007 to a 011??
K-Guy
Many of these pumps will not self prime. It may just have air in it.
Nyle Service Dept.
- D. Adams
xlogger
Quote from: K-Guy on July 12, 2021, 11:15:25 AM
I have prime it several times over the years, but not this time.
