Author Topic: 2, 1k gal conventional septic tanks in series then pump to sprinklers  (Read 296 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
Thinking of running 2, 1k gal septic tanks in a series. Run an air pump in the 2nd tank, then pump out to 2 or 3 sprinklers, rather then installing an aerobic tank. We are short on quality service people for maintenance and our ground would be better served i think with a sprinkle system. Thoughts? Thanks
Offline Southside
    • White Oak Meadows
Stink, stank, stunk is my first thought.  Second would be - is that even legal?  Land applied sewage has a ton of regulations that come with it.
White Oak Meadows
Offline Sedgehammer
I haven't checked here, but back home the sewage trucks wood spread the tank clean out on our fields
So whats the major differences with an aerobic tank and what a second wood be doing to break it down further
I can put in my own septic here
Offline Sedgehammer
Might need a smaller tank to set the pump in though
Offline scsmith42
    • Whispering Pines Farm
It’s my understanding that the second tank is called a “dosing tank” for the system that you describe. Basically the treated discharge from the septic tank accumulates in the dosing tank and then your pumps turn on to send a specific amount to the field or sprinklers.
Tom's 3638D Baker band mill
Detroit 53 series fuel pump
Started by David-L on Forestry and Logging
Last post May 21, 2015, 09:09:50 PM
by David-L
ArborMaster Training DVD Series / Working Climber DVD Series Review
Started by MinnesotaArborist on General Board
Last post November 15, 2014, 08:13:58 PM
by DonT
Old Homelite Clutch Spider/Drum Question for C-Series & XP series
Started by weimedog on Chainsaws
Last post December 11, 2005, 02:45:12 AM
by Bill
sprinklers on wood
Started by Tom L on Sawmills and Milling
Last post May 21, 2012, 11:03:13 PM
by WH_Conley
