Author Topic: Older Skidders - Quality of Oil  (Read 1127 times)
Offline Loony661
« on: August 26, 2022, 01:00:52 AM »
This is mostly out of curiosity, but also because everyone has a different opinion on the subject. My question to you all is:
In older equipment, skidders specifically, what kind of oil do you use throughout your machine (engine, trans, hydraulic, etc)? Do you use the cheapest farm and fleet brand you can buy, or do you run a high quality, top name like Amsoil or Schaeffer’s, etc?
I can tell you that any leaks bother me, but I can tolerate an occasional drip. Anymore and I try to repair before it gets worse. I also believe that high quality oils do perform better, and last longer than cheap stuff. What say you?
Timberjack 230A
MS 661 w/MaxFlow 25”
MS 462 w/25”
MS 460 w/MaxFlow, BGD, Timing Advance, Dual Port Muf 25”
MS 441 25”
025 Muf Mod 16”
Offline B.C.C. Lapp
  • I'd rather be logging.
Re: Older Skidders - Quality of Oil
« Reply #1 on: August 26, 2022, 03:03:15 AM »
Ive used the cheap stuff forever and have never had problems.    Paying for the expensive stuff is fine if you want to but unnecessary.     It aint the name on the oil that matters but regular oil and filter changes matter a lot.   I keep records for every machine and do the maintenance on time.  With all the tractors and skidders Ive owned I've only ever done one out of frame motor rebuild and that happened because of a split oil filter.
     I have a friend that worked in a refinery for decades that told me the only difference from brand to brand is the color.  All the same stuff.
Listen, or your tongue will make you deaf.
Offline Firewoodjoe
  • Im getting old
« Reply #2 on: August 26, 2022, 04:59:35 AM »
This has become an interest for me in the last year or so. I never cared for the most part. I tried to stick to one brand though. But I was having cold weather starting problems and had already done the normal mechanical checks. Well I looked into oil and cold weather pour test. Now I use only rotella t in the winter and generally all summer. And it does make a difference. As for hydraulic oil I use the farm store stuff. Just get a pallet and be done. Well since the motor oil thing I’ve been paying more attention on the hydro oil. The cheap stuff will have grimy junk in the bottom of every bucket. The good stuff don’t 🤷‍♂️ Also been thinking of swapping oil out in the summer to 68 weight. For better heat protection. So far I’m still using the farm store stuff but it has me thinking.
Offline barbender
« Reply #3 on: August 26, 2022, 10:09:42 AM »
Joe, I have seen the same difference in hydraulic oils. The good stuff flows WAY better in our lovely -20° temps, that's the main difference I've seen.
Offline EricR
« Reply #4 on: August 26, 2022, 10:25:23 AM »
The statement on the cheap stuff from the tractor supply website turned me off of using it even though it supposedly meets deere specs. The stuff I use now is double the price
Warning: ultra j20a plus utility tractor fluid is primarily designed for use in older equipment manufactured before 1990 or for aging machinery where frequent fluid replacement is required
Online Andries
  • Making buildings out of big curvy logs
« Reply #5 on: August 26, 2022, 11:28:40 AM »
What? That’s a clear sign that it’s oil priced to leak out or get dumped/replaced when a decrepit old hydraulic hose pops.
But it meets specs? 😝
I’m with @barbender, the good stuff flows at low temps, and is priced accordingly.
LT40G25
Ford 545D loader
Stihl chainsaws
Offline chevytaHOE5674
« Reply #6 on: August 26, 2022, 11:54:52 AM »
More expensive oil generally has better additive packages to help it deal with temperature extremes, moisture, extreme pressures, etc.
The more expensive oil is cheaper than things like piston pumps, hydrostatic drive motors, etc.
Offline Jkauffman
« Reply #7 on: August 27, 2022, 11:00:44 PM »
What I hate is machinery that calls for straight motor oil throughout,like trans/hydraulic oil etc.Now that gets expensive
Offline barbender
« Reply #8 on: August 27, 2022, 11:37:39 PM »
Yes I have a Case 1845c that calls for 10-30 engine oil for the hydraulics, with a Case additive mixed in that has become quite expensive.
Offline Riwaka
« Reply #9 on: August 28, 2022, 06:45:07 PM »
Another thing to consider is oil incompatibilities. There are cases where someone was short of the same brand/ spec of oil they were using in a machine and added something else to make up the volume required and problems resulted. Similarly, when changing from one brand to another, not enough old oil from a previous brand was removed.
Offline Kodiakmac
    • Upper Canada Outfitters
« Reply #10 on: August 31, 2022, 08:38:44 AM »
The manual for my 440 JD called for JD303 in the hydraulics, but it became ridiculously expensive at the JD dealer or completely unavailable - so I switched to TDH fluid from Canadian Tire which met or exceeded the JD stuff and was a little more than half the price.  I used Castrol 10W30 in the engine and I never had an issue with either oil.  I didn't use the skidder very often in bitterly cold weather because that is just too hard on old machinery... and old bones. :)
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
Kioti rx7320, Wallenstein fx110 winch, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980  Mark 8:36
Good quality trees or poor quality trees?
Started by Dobie on Ask The Forester
Last post March 23, 2016, 06:06:47 PM
by SwampDonkey
Air Quality
Started by Ron Scott on Forest Education
Last post June 19, 2004, 04:10:45 PM
by SwampDonkey
Quality of cut.
Started by AtlanticAcres on Sawmills and Milling
Last post July 02, 2010, 08:51:53 AM
by Hilltop366
Cut Quality
Started by Rougespear on Sawmills and Milling
Last post August 03, 2016, 12:07:09 AM
by Rougespear
