Author Topic: clark 664  (Read 453 times)
Offline bubba dub
  • Member*
clark 664
« on: August 30, 2022, 09:58:18 AM »
have a clark 664 skidder with a loose wheel berring how do i tighten this up
Online C5C Tree Farmer
Re: clark 664
« Reply #1 on: August 30, 2022, 01:35:22 PM »
Welcome to the forum!
If you have visually noticed that one of the wheels on your skidder is loose to the point of wobbling there is a good chance that at least one of the hub bearings failed. This is easy to verify. Pull the drain plug on the outboard planetary unit and drain the oil. Check for metal fragments in the oil and on the end of the magnetized drain plug. If fragments are found the hub and planetary unit should be completely disassembled and inspected for damage.
Will a 664c Clark Tranny fit a 664b clark ranger skidder?
Started by delimberboy on Forestry and Logging
Last post December 22, 2015, 01:23:05 PM
by oldseabee
Clark 664
Started by mjeselskis on Forestry and Logging
Last post March 02, 2011, 12:14:52 AM
by tlandrum
Help with a clark
Started by stoneeaglefarm on Forestry and Logging
Last post March 07, 2015, 05:55:20 PM
by stoneeaglefarm
Clark 664
Started by KWood255 on Forestry and Logging
Last post April 15, 2014, 06:47:32 PM
by RKH Logging
