Author Topic: 3/4" Diameter x 48" Long Dowel Maker?  (Read 1864 times)
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« on: September 01, 2022, 08:03:50 PM »
One of my customers buys about 4,000 poplar dowels per year, 4 feet long x 3/4" diameter, per year for his products.   They are pretty expensive and low quality, and he wants to make them.  Is there such a device out there that can make relatively large amounts of these dowels, out of poplar or maybe even oak?  He's been looking for awhile but can't really find any machine suitable.
Any suggestions?
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  So dont burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Ianab
Re: 3/4" Diameter x 48" Long Dowel Maker?
« Reply #1 on: September 01, 2022, 08:37:28 PM »
Sounds like a broom handle making machine?  Not sure where you would buy one, a quick search leads to Alibaba (China) or Indian sites. But imagine an overgrown electric pencil sharpener. Feed 1"x 1" stock in one end and it spits out a 3/4" dowel, and a cloud of pencil shavings.
« Reply #2 on: September 01, 2022, 08:47:08 PM »
I had not even thought of a mop or broom handle machine.  That's a good idea.
YellowHammerisms:
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #3 on: September 01, 2022, 08:56:22 PM »
I have seen a table saw jig used with a drill to spin the bar. Looks like it works pretty slick and fast.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #4 on: September 01, 2022, 08:58:02 PM »
oooh looky, I found it :)
Offline thecfarm
« Reply #5 on: September 01, 2022, 09:05:14 PM »
I know it's on a much bigger scale, but don't WM have a round post jig?
Might be able to get an idea from that.
Offline 21incher
« Reply #6 on: September 01, 2022, 09:19:13 PM »
When I had my Foley Belsaw planer I had a knife set that was a half round cutter set to make 3/4 dowels. You ran one side then flipped it and had a dowel. They also offered  gang cutters that did 4 at a time. Wood grain could cause less them perfect rounds. Had to use the slow feed gear. Wood master may have that ability.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline Larry
« Reply #7 on: September 01, 2022, 09:47:32 PM »
A common complaint I hear from chair makers. No attention is paid to grain run out and size tolerance is all over the map. Most roll their own using a jig or maybe the Veritas Dowel Maker. All slow and low production but high quality.
For production, a doweling machine is needed. Lots were made when the US had furniture manufacturing. Search the online industrial auctions but they are scarce these days.  I was at a auction a couple of years ago and one sold for I think $600.  I looked and the only new one I could find is this one. Oliver Dowel Machine. It looks to be a clone of some of the old US made machines.
Ive made them on my shaper but it was a jury rigged setup for just a few. With the shaper and power feeder I can climb cut so the finish is perfect. Takes two passes, but I think a smart guy could rig up some feed ramps to make it into a production machine.
Online peakbagger
« Reply #8 on: September 02, 2022, 07:14:46 AM »
My friend used to be the machinist for Saunders a large dowel producer in Maine. They are long gone. They tried at one point to offshore the production but they could not compete and slowly went out of business. I think National Wood Products in Oxford Maine bought some of the production lines but they to seem to be out of business. The machines I saw were two sided board planers with special knifes to make half round cuts. The dowels than went into a sanding machine. The majority of the dowels were made with white birch but they would do custom runs of other species. They completed against imported tropical hardwood dowels that were typically very low quality. In addition to the collapse of the furniture industry in the US, they had a tough time getting white birch. Back in the 1940s there was a big drought in New England followed by numerous forest fires all over Maine and NH. White birch grew in heavy and they are not particularly long lived trees so the resource declined. Saunders had an increasing problem sourcing large white birch and were driving farther and farther to get it. Still plenty of white birch around but nowhere near what was out there 30 years ago.
The tricky part with maintaining the machines was keeping sharp knifes and setting them just right. Ideally when the dowel came out of the planer there would be no trace of seam on the dowel but the points on the cutters would wear out far faster than the gullet of the cutter so as the wore out there would be a visible bump along the seam. The sander could deal with the bump,  but I think the dowels could start to get oval.
When they were cleaning out one of the operations my friend was hauling home all sorts of odd products they had made to burn in his woodstove. One of them was coffin pegs for some religion that required all wooden coffins.  I got a few of them somewhere plus a bundle of Ash dowels.
« Reply #9 on: September 02, 2022, 07:42:05 AM »
These are good ideas, and I've been looking since he asked yesterday.  It's an interesting problem, how to make round sticks out of flat boards with speed.  That Oliver looked nice, and I suggested to him to use a molder also, but the seam was an issue.  He has already called several companies asking for them to help and they are not coming up with much, one of them was even a place that makes machines to produce round stair posts.
YellowHammerisms:
Online Don P
    • Calculator Index
« Reply #10 on: September 02, 2022, 07:49:54 AM »
You can use more than 2 heads to wipe the seam from the sides.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline kantuckid
« Reply #11 on: September 02, 2022, 09:02:37 AM »
I've bought a very few hardwood dowels from the company in Cinn, OH- www.cincinnattidowel.com
Mostly I turn them freehand for furniture.
Oak Timber pegs I bought, not turned, as I was too busy building the building itself to do lathe work. ;D
In quantity having them made may make more sense than owning a production machine? Or from a box store in cases?
« Reply #12 on: September 02, 2022, 09:52:47 AM »
He said that one reason hes looking to make his own is that most are made of oak and he needs poplar and that hes tried several sources (he didnt say which) and they come with a good mix of clear but with some unusable low grade with cracks, knots and wane, as if the rods are being made of the low grade waste and so hes getting lots of culls which drives his price up. Hes building and selling big stretching jigs or frames for making blankets, big embroidery goods, stuff like that and the rods are put under strain and if they arent perfect they will snap.  Im not sure why he has to use poplar, but apparently it is the accepted approach for the dowels or rods.
So now he just orders them by the pallet, and throws a bunch out and is looking for a better way, but he cant spend all his time making dowels so needs a semi automatic machine of some sort.  I contacted him with some of these suggestions and also pointed him to Alibaba, but of course, hes nervous about those products and lack of support from the manufacturer.
Worst case, or maybe best case, is he just keeps buying them as he is.
YellowHammerisms:
Online Southside
    • White Oak Meadows
« Reply #13 on: September 02, 2022, 10:59:24 AM »
I suspect a 4 head moulder would do those just fine. Overlap the blade design to eliminate a seam.
White Oak Meadows
Offline SwampDonkey
  • Large Tooth
« Reply #14 on: September 02, 2022, 04:51:24 PM »
Only one I use is the Veritas dowel maker. It is not a production jig by any means. For the quantity your friend needs, it is not what he wants. But makes great dowels. Made this drying rack with dowels I made. They were over 60" long, but trimmed to 60".
During construction
Completed and folded up.
Those spool bodies and the rods they slide onto.
The spokes of those reels on this reel swift.
Yeah, I make dowels. But not in lots of 4000!!  :D Mine are all maple. The wood was kilned.
No amount of belief makes something a fact. James Randi
Offline kantuckid
« Reply #15 on: September 03, 2022, 09:40:45 AM »
In a box store most are either oak or Asian wood, but the link I gave makes many, many kinds. Poplar would be an easy dowel to make. The wood is very "docile" which is why it's a much used millwork species. Factory a few miles from me uses poplar exclusively and may make dowels for all I know? Comes in by the tractor trailer loads all week long.
Offline DMcCoy
« Reply #16 on: September 05, 2022, 03:35:39 PM »
Super easy and fast.  1" round hole on the front accepts 3/4" square stock.  3/4" hole on the output.  I use a cordless drill and a 3/4" square drive socket to spin the stock.  A bit touchy to adjust but once it's dialed in it is about as fast as you can shove it.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #17 on: September 05, 2022, 03:58:40 PM »
Awesomeness!
Offline 21incher
« Reply #18 on: September 05, 2022, 06:29:43 PM »
Love It. I will have to copy your idea for 1 inch dowels that I use in my Beall threading jig.
« Reply #19 on: September 05, 2022, 08:57:25 PM »
That is cool!
YellowHammerisms:
"Sled" jig for small diameter "logs"
Started by Full Circle on Sawmills and Milling
Last post September 03, 2012, 10:58:22 AM
by barbender
moved
MOVED: Looking for 4" x 24" hydraulic cylinder with 3" rod diameter
Started by chet on Firewood and Wood Heating
Last post August 16, 2015, 09:05:42 PM
by chet
Small "widow maker" caught on video
Started by CCC4 on Forestry and Logging
Last post December 26, 2013, 06:44:17 AM
by mesquite buckeye
Sawing pattern for 14" to 20" diameter hardwood logs
Started by WoodenHead on Sawmills and Milling
Last post May 21, 2014, 05:45:46 AM
by WoodenHead
