C4 Transmission
Started by C4treefarmer, January 19, 2023, 06:11:44 PM
C4treefarmer
Can someone tell me where to check the transmission oil in this C4? Also, what does it take for oil? Thanks
C5C Tree Farmer
There is a pipe plug on the right side of the transmission case. Remove the plug and the oil level should be level with the bottom of the hole. I run 80-90W gear oil in mine. Transmission is refilled through the same hole.
C4treefarmer
Thanks! How do I access this? Down through the floor?
C5C Tree Farmer
To gain access to the transmission you will need to remove the floor plate in the cab.
C4treefarmer
Thanks will do. I thought it was down in there. Wasn't sure.
