7 tooth or 8 8 tooth sprocket
Started by postville, April 16, 2011, 08:32:21 AM
postville
What would the difference be running a 7 tooth sprocket on a 038 , 24 inch bar , instead of a 8 tooth? Bob
LT40 25hp Kohler, Gehl 6635, Valby grapple, Ford 4600, Farmi winch, Stihl saws
chucker
# 7 gives you more torque and less speed for larger wood, and the #8 gives you more speed at WOT.. with less power to run through the big wood using manual power to push the saw to cut...
respect nature ! and she will produce for you !!  jonsered 625 670  2159 2171/28"  efco 147 husky 390xp/28" .375... 455r/auto tune 18" .58 gauge
ladylake
  A 7 tooth will cut faster in medium to big wood, a 8 tooth might cut faster in small softwood.  . Stick with the 7 tooth unless you just use the saw for limbing.  Steve
quietrangr
Quote from: ladylake on April 16, 2011, 06:42:11 PM
ditto--I would want at least 5 cubes before using an 8 tooth.
Al_Smith
I'm in agreement with what's been already said ,stay with the seven tooth .That saw will do better if you keep the r's in the torque band .
HolmenTree
General rule of thumb is a saw with 85cc and over can use a 8 T- 3/8 drive sprocket as standard.
But my Husqvarna 395XP -32" came from the factory with a 7 T-3/8 rim, so longer bar length can change the standard also.
Willard.
PAFaller
Sort of depends on what you are running in for timber too. I run an 8 on my 2172 Jonsered and 7900 Dolmar with 20 inch bars, but I cut a pile of softwoods. Been in pine, aspen, and hemlock for the last 8 months, and the extra speed is great for limbing. Also, a 20 inch bar and sharp chain on that sized saw you don't lose much when you get to an occasional hardwood tree.
It ain't easy...
postville
10/4 . I am going to try the 7 tooth. Bob
