Author Topic: Broad axe hatchet  (Read 2112 times)
Offline Brian_Weekley
  • I am Batman!
Broad axe hatchet
« on: February 25, 2012, 10:58:31 PM »
I just picked up a nice old broad axe hatchet head (5 inch).  Don't know why, it was just too cute to pass up.  Too small to hew logs with.  I'm just curious what uses you folks have found for a small single bevel broad hatchet?  Are broad hatchets typically fitted with an offset handle like broad axes?
e aho laula
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Broad axe hatchet
« Reply #1 on: February 26, 2012, 10:40:35 AM »
I'm not sure about the offset, mine is pretty straight. They are great for pointing pegs, if you aren't using a draw knife and shaving horse. I use one for putting a really quick chisel point on tomato stakes. I think they would have been used a lot more when working hewn timbers. When scribing hewn timbers, sometimes you want to make a small correction before you start marking the timbers.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #2 on: February 26, 2012, 10:43:56 AM »
I recently acquired a 5" broad hatchet head for a customer. And I also got him a handle. It was a straight handle, as most hatchet handles are.
He wanted a curved handle, and we don't have a source for that. So, this handle is available if you need it.
As mentioned, the uses of this type of small broad hatchet is many, and you'll find uses for it when you start using it.
It is something nice to have in the toolbox.
Jim Rogers
Broad axe
Started by thedeeredude on Timber Framing/Log construction
Last post January 05, 2006, 08:11:48 PM
by ARKANSAWYER
Broad Axe handles
Started by Jim_Rogers on Timber Framing/Log construction
Last post February 03, 2009, 11:51:56 PM
by Old Hickory Log
grin
I GOT BROAD BAND
Started by Ga_Boy on General Board
Last post June 14, 2005, 06:07:36 PM
by SwampDonkey
Broad ax question
Started by Bill_G on Timber Framing/Log construction
Last post February 24, 2013, 05:35:12 PM
by timberwrestler
