Cut Quality
Started by Rougespear, July 27, 2016, 11:35:56 AM
Rougespear
Let me begin by saying I am happy with the cut quality - no dips or dives or anything of the sort cutting at a normal feed speed.  However, my cut is noticeably rougher in the first few inches of the log as the blade enters the cut.  Is this common?  I find I am slowly entering the log then speeding up to full cut speed... are others doing the same?  Or is the rough initial cut quality to be expected?
Custom built Cook's-style hydraulic bandmill.
Dave Shepard
Wash boarding cones from going too slow. Try entering the cut faster.
Peter Drouin
Quote from: Dave Shepard on July 27, 2016, 12:03:33 PM
smiley_thumbsup
A&P saw Mill LLC.
License NH softwood grader.
Yup, the sawyers here on the FF taught me to enter the log at sawing speed.
Rougespear
Fair enough!  Thanks for the consensus folks... I will give it a go tomorrow when I'm back at the mill site.
Carson-saws
Let the Forest be salvation long before it needs to be
carykong
The butts on your older logs can be drier and harder that will affect how your blade cuts
drobertson
I get some at times, and just wondering, you guys that enter at speed, do or have you marked a set point for cutspeed for your setting?
caveman
Regarding the entry speed and a mark.  I do not have a mark on the speed knob but try to enter at approximately the speed at which I would saw the log.  If sawing a 6" cant, I hit it pretty fast.  If entering a 16" cant, I slow down quite a bit compared to the smaller cant but still at a speed at which I expect the saw can handle.  Sometimes I speed up or slow down a bit during the cut, especially prior to making a cant, based on the width of the cut (log taper).
I was getting the washboard appearance on some of the wide cuts until I sped up as a result of advice from the sagacious sawyers on this forum.  It was a bit scary to me the first time I ran the moving blade into a large log at speed but the resulting cut was a big improvement.
Caveman
Caveman
drobertson
I hear that, it goes both ways here, entry pine knots are hard for me to (slam) into but the concept is on for the majorirtory of sawing
woodmills1
when I enter hardwood fast, esp oak I get a bump up from the blade rising then coming back down.  For some jobs it is not a problem but for trailers and horse fence it makes it tough on the installers.
terrifictimbersllc
In my experience cutting flat in stump grain on the end of a log benefits from slower speed, at odds with a fast entry to avoid washboard.
YellowHammer
I use the dragback to pull the board back and off the mill, so as I'm tailing the board, I've put the mill in forward and let it enter the log hands off, some times I'm several feet away wrestling with a slab.  Normally, I'm not pushing the saw speed doing this, it more of a sweet spot feed speed.  By the time I get back, the saw has made its cut, and I return the carriage and do it all over again.
I don't do is all the time, and am very conscious of cut quality, but the way I see it, a bandsaw resaw never slows it's feed down to enter the cut, so I shouldn't have to, unless something odd is happening.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
drobertson
Resaws are sweet!  They for sure speed through, even without the 1/4 inch down!  They still defect even with narrow saw widths at times, bottom line in my view is each cut is of its own, some are easy others require some attention, even if some blade stuff occurs, it will, or should if need be planned out.
YellowHammer
Quote from: drobertson on July 29, 2016, 09:03:58 PM
I like your phrase, "Each cut is of its own" because it applies to much more than sawing.
It sounds like a song title.... smiley_guitarist
We need to get "The Project" band to kick in.
r
YellowHammerisms:
POSTON WIDEHEAD
Looks gang members.  ;D
Ga Mtn Man
David (drobertson) does have a unique way with words.  I always enjoy reading his posts.
"Some people just have a way with words, and other people...oh... not have way."
        Steve Martin
YellowHammer
Quote from: POSTONLT40HD on July 30, 2016, 05:53:18 PM
Yeah, they are a rough looking crowd.   :D  But they sound good.
YellowHammerisms:
drobertson
Now uins are serious bout one thing fer sure, music and sawing go hand in hand!
plowboyswr
Quote from: Ga Mtn Man on July 31, 2016, 07:39:37 PM
        Steve Martin
Ya ought to hear him in person!
Just an ole farm boy takin one day at a time.
Steve
esteadle
Do you have rough quality on "both" sides of the cut? Or is the top board smooth on the bottom, and the cant side rough? Vice-Versa?
As your blade enters and clears away sawn material, it creates a channel for the blade body, which helps keeps the blade straight through the cut.
In the first inch or two of the cut, perhaps the blade could be wandering?
Have you checked the parallel of the blade to your frame rails? To do this, lay a straight steel edge (a good level will do) over the unswaged tooth of a blade, and perpendicular to the direction of blade travel, and measure the height of the ends of the straight edge off of the bed rails. If these are different, you could re-set your roller guides and get them parallel and see if that helps?
Rougespear
Good point esteadle... I never thought of checking the underside of the board being sawn.
I will also confirm the guide settings... they were just set correctly recently but I have knocked them with the side supports since.
