Whatcha Sawin' 2024 ??
Started by Magicman, December 31, 2023, 05:14:39 PM
Magicman and 2 Guests are viewing this topic.
Southside
Yes but that would get you the rough in work done, from there a router sled would clean it up once dry.
White Oak Meadows
TimW
Thanks SS. ffwave   I understand, but you're a little far to borrow a router sled. smiley_thumbsdown
Router sleds are pretty easy to make. (as long as you have a router). Cookies from that fluted ERC would make a pretty, impressive table. Especially with some of LogRite's legs.
Peter Drouin
If you did cut it with a chainsaw then put it on the mill. With a hardwood backstop. You could see better. Then turn it to to fit better. Not sure I don't make or cut cookies.
A&P saw Mill LLC.
License NH softwood grader.
TimW
Peter,
Think round table tops 3 inches thick 39x34 inches in size.  Not really a cookie.  I was thinking about an angle iron stop on the fixed mill stops, but not sure it that would help or hurt until I just try it.
TimW
Quote from: beenthere on April 19, 2024, 01:52:57 AMRouter sleds are pretty easy to make. (as long as you have a router). Cookies from that fluted ERC would make a pretty, impressive table. Especially with some of LogRite's legs.
I had a router years ago, but lost it in the divorce.  Looking at router sleds, now, online.
I always can use more tools. :sunny:   What I need is more time. move_it smiley_thumbsup   Seems the older I get, the more I want to sleep. zzzz_smiley
TimW
I chickened out and cut the butt chunk into 2 halves.  I cut 6 three inch cookies.  The pallet they are stacked on is 40x48 inches.
The cookie on the top of the stack is 3.5 inches thick.
TimW
Dan R
Cut some Douglas Fir. Use it for re decking at Flat deck.
8 2x-12s on the pick up.
Peter Drouin
A&P saw Mill LLC.
Peter Drouin
Man, I wish I had Fir around here. Have an order for 8"x16"x18' and 16'  All I have that big is W Pine. Hemlock no way.
A&P saw Mill LLC.
TimW
TimW
Quote from: Dan R on April 20, 2024, 12:39:44 AMCut some Douglas Fir. Use it for re decking at Flat deck.
Is this deck a trailer deck or a house deck?  What is the wood of choice up there for trailer decking?
Down here it is White Oak.
Brad_bb
I got the new quick connector for the fuel tank for my mill.  Once I got the fuel flowing I think this has fixed it.  I proceeded to slice a small cherry 5/4 live edge.  Obviously the squirrel placed a walnut in the crotch of a branch and the cherry grew around it, and I sliced right through the middle of the walnut.  So I have a book matched set with each half of the walnut.
Dan R
Tim
Fir is probably used the most for trailer decking. The PT hemlock is garbage. It is used for sun decks because Red Cedar is very expensive.
Peter that fir was salvaged from a setting and was left behind after logging.
Dan R
Today's cutting Red Cedar for fencing at a project of my Sons. It is now inside drying beside my Dads old work truck. Thought I'd show it off in a picture. He restored it with my Son in 1997. He was very proud of it. We take good care of it now in it's retirement
Dan
Wlmedley
Brad bb that is a interesting piece of wood.I'd love to run into something like that.
Bill Medley WM 126-14hp , Husky372xp ,MF1020 ,Homemade log arch,Yamaha Grizzly 450,GMC2500,Oregon log splitter
TimW
Dan R,
 I am guessing 1966 C-10.
TimW
It was such a gorgeous day, I couldn't resist doing something outside.  So I put the Cedar Butt Chunk on the mill on 3 pieces of C channel so I could slide it over.  I figured out to wedge blocks of wood between the Chunk and the C channel.  I think this will work cutting soft ERC.
I didn't want any excitement today, so I will saw it tomorrow, after putting on a fresh blade.
Dan R
Wlmedley
I'm doing a little building project for a fellow and need some rot resistant 4x4s and I had one approx. 25" white oak log 6 1/2' long that fit the bill.Got some pretty nice boards out of it but was a little hard to turn. I'm going to have to quit putting such big logs on the mill.My back is not what it used to be.
TimW
TimW
I cut six more 3 inch ERC cookies today.  Here is the biggest.
Outstanding.  Keep that up and you will be known as da Cookie Man !!   ffsmiley
TimW
I might put a huge clock on it. ffcool  Now if I can only find one in the shape of Texas. :sunny:
Not an inserted clock like this.
But one with numbers on the cedar and the mechanism inside with a hole for the movement and arms.  That would be awesome.
da Cookie Man?  I am a friend of da Cookie Monster!
