meter pins
Started by xlogger, December 28, 2019, 01:47:51 PM
xlogger
When you notice that one of your pins in the Delmhorst hammer is starting to bend do you go ahead and replace it or just let it bend all the way bad? I'm thinking it makes the other pin bend more quickly.
I tap/bend it back straight.
YellowHammer
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
GeneWengert-WoodDoc
Delmhorst makes 1/2" long pins that bend much less.
 pins are made with a metal that is hard to bend straight or crooked without the pin breaking or starting a break that actual breaks all the way soon.
xlogger
Quote from: WDH on December 29, 2019, 08:34:11 AM
I've tried that a time or two and broke the pins.
Gene, I use longer pins mostly because I drying live edge slabs and run them in from edge to get in slabs deep as I can.
YellowHammer
Yep, the pins are fragile.  Try to bend them back before they get too bad.  They snap off pretty easy.  I'm not real sure whey they are made of such brittle material.
YellowHammerisms:
