Tree ID for 3 trees
Started by WVMountaineers, April 29, 2021, 08:45:46 PM
WVMountaineers
Bottom two look to be hickory.  The first could be hickory too.  Do you have any twigs/buds/leaves?
WVMountaineers
Quote from: WDH on April 29, 2021, 09:19:33 PM
Couldn't see any. The last one down I thought was maybe an elm. I don't see a lot of them here though
The bottom one is red hickory, Carya ovalis.
Virginia Tech Dendrology Fact Sheet
I do believe that all three are hickories.  The second one is almost certainly pignut hickory or bitternut hickory, most likely bitternut.  They are easy to tell apart with the leaves.  Also the buds of bitternut are sulfur yellow.
luap
cannot help you. A long time ago I had a college course in forestry. to pass the class ,the students were required to identify 50 species of various trees and shrubs all by buds, leaf scars, no bark, leaves etc and know the latin names and correct spelling. It was a fun class and yes I did pass the class. The other  class that was also interesting was a soil class That was taught by a pakistani PHD whose lectures were extremely difficult because of his accent. He gave lot's of reading assignments and his exams were always based on the reading assignment, never on his lectures. So if you didn't read the book you were in trouble. Too long ago now
Walnut Beast
What kind of pine trees are these big guys and are they worth sawmilling up with all the branches that came off them ?  Thanks
Southside
How many needles and what do they look like?  As far as are they worth sawing?  Seems to be the big limbs are on the one side, so for say "knotty pine" interior wood, that sort of stuff - you will have some waste around the monster limbs but otherwise they would probably be OK.   I would not even try to make framing lumber from those.
White Oak Meadows
Walnut Beast
Ok Thanks! We really don't have many pines around here. I will check that out on the needles. Just a couple miles down the road.
Most helpful would be # of needles per fascicle, needle length.    A cone would be a tremendous help.
Don't listen to me, but those pine trees look a lot like the eastern white pine on my land.
I don't have any that grow in an open row like that, but I have some with limbs that big and that low.
They sure do keep me warm when it's cold outside.  ;)
When my father and me was cutting this land, we would haul out the limbs on those big ones for pulp.
HemlockKing
Quote from: thecfarm on January 23, 2022, 10:22:48 AM
I'm with you, Im certain those are EWP.
A1
Big_eddy
My turn
These logs have me stumped.
Wood is white under the bark, reddish deeper.
Bark looks almost like pine.
My first thought was cherry, but it does not cut, split or smell like cherry.
(It does not smell like pine either.)
stavebuyer
customsawyer
The last three pictures look like Deoder Cedar.
www.thecustomsawyer.com
Big_eddy
Quote from: customsawyer on January 26, 2022, 06:41:14 AM
I don't know what Deoder Cedar is. Here in Ontario we have red and white cedar (how Canadian of us) and they certainly are not either of those.
Biggest log is about 24" dia.
What ticks me off is I've spent the last 30 winters playing "name that tree" with my kids while out snowshoeing. We're typically pretty good at recognizing bark. ???
customsawyer
If you google it there is more answers. It is native to the Himalayas. I haven't figured out how they got over here. I have one in my yard that a tree service took down in town. Near as I can figure it's around 150 years old. Interesting growth on some of the limbs and a unique smell when sawed.
Big_eddy
Quote from: stavebuyer on January 26, 2022, 03:50:15 AM
Sure, looks like Cherry.
I've taken a better look at some of the logs (in daylight without the snow on them) and I am now sure that they are cherry. It was the layer of white wood  under the bark that was throwing me. Most cherry I have seen before was trunk wood without the white band. The larger logs are more typical of the cherry I am used to.
Thanks for the inputs. Unfortunately these are firewood logs, and they are bent, twisted, and none of them are suitable for milling.
Ron Scott
~Ron
All the cheery that I have ever seen on my land would not even make straight smoke.  :(  I only know where there are 2. I am clearing down by the road and have left them to grow, crooked, they look more like a snake crawling across the ground.  :o
Them thing seem to die at about 8-10 inches across. These 2 have a few more years left in them.  :)  When they fall over, they don't rot either. But they still make crooked smoke.   ;D
Big_eddy
Quote from: thecfarm on January 29, 2022, 06:13:06 PM
These ones must be relatives of yours! Out of 8-10 logs, the longest straight section is about 2'
Cherry is shade intolerant. It looks for a hole or light in the canopy and strives to go there.  If that hole/light is not straight up, the cherry won't be either.  In managing for cherry, give the crown light from all sides and some room to grow.
Walnut Beast
Quote from: WDH on January 23, 2022, 10:09:59 AM
This is what I got guys. Thanks
Oh yea, Eastern White Pine. I have 100's of them things on my land that would make lumber. Then 1000's more that are growing.
Walnut Beast
