jd 440a valve specs?
Started by thumper, July 28, 2010, 06:48:30 PM
thumper
hey guys, im finishing up the head job on my 440a right now. does anyone know the valve adj specs and rocker shaft block torque specs for it?  ???
Jonsered 2150 2152 2156 2165  Husqvarna 262xps Worn 1970 JD440a 06 GMC 3500 DURAMAX
snowstorm
think its 10 and 20 i can look it up have to go the garage and find my tech manual. why did you have the head off??
thumper
fire ring on the head gasket split..
snowstorm
usually when that motor pops a head gasket........its cause of lots of hrs. the liners are worn . dose it use any oil???start hard???.............intake.014....exh .018  rocker arm bolts 35lbs    head bolts 95lbs
aksawyer
Snowstorm has it exactly right.Its also in the operators manual page 52.
