Husqvarna 450 dies when I hit the throttle
Started by baumfamily52, April 04, 2020, 01:03:31 PM
baumfamily52
I need some help!  When I use my chainsaw for a few minutes then let it idle between cuts it dies when I hit the throttle to resume cutting.  Anybody know what is causing this?
Thanks!
sawguy21
Bring the idle speed up until the chain starts to turn then back off until it stops. You may need to enrich the idle if you have the right tool. How old is the saw?
Bandmill Bandit
What he said plus clean the carb. Typical of condensation/dirt in the fuel pump section of the carb.
Canuck123
Also if the above does not work fatten up the low speed jet setting a quarter turn out . This normally cures any hesitation !🍻
Nothing like the Smell of Motul in the Morning !
