Farmi 351
Started by goat704, March 26, 2018, 12:18:36 AM
goat704
Well I found a used Farmi 351 that I purchased. I have a question for you pro's as I've never used one.
My tractor has a hydraulic top link on the 3 point hitch, will this create a problem, or will it stay put?
mike_belben
Probably wont hurt the equipment but it does mean a lot of pressure will be in one of the lines while winching and skidding.  Were it to let go you may have a fluid injection risk.  Would be a bit safer to either swap in a fixed TL or chain it.
Praise The Lord
Riwaka
For some tractor 3 point  hitch applications I made a top link with cat 2 lower link ball ends welded to a piece of steel.
Never had to worry about operators undoing the top link and pulling loads with too few threads on a acrew adjustable top link.
Look up the online manuals for operating procs.
Manuals | Tractor Mounted Winches - Farmiwinch.com
47sawdust
For winch applications the hyd. top link has no real advantage.A manual top link is easier to adjust for initial installation of the attachment.
Mick
g_man
Interesting - I have a 351 on M5640. Last week I took off the standard TL and put on a hydraulic TL that I had. This was the first season with this rig and I found that because the TL is at so steep an angle that the winch rolls back severely when raised. Often the winch butt plate jams hard into the butt end of the logs when it rolls back preventing any free swing in the hitch. The hydraulic TL allows me to relieve that problem by lengthening it when I raise the winch if I have to. So far it has worked well with no troubles but it has only been a short time.
gg
Ed_K
 My neighbor built a hydro top link just for the purpose that g-man stated. It's been in use for over 5 yrs and has had no problems. He pulls a lot of full length w/pine and hemlock for fire wood for his maple operation.
Ed K
47sawdust
Well there you go,guess I'll have to try that myself.Glad I consider myself a lifelong learner.
Mick
John Mc
I leave my hydraulic toplink on all the time when using my logging winch (Uniforest 35E - very similar specs to a Farmi 351). It has not caused me any problems.
