Author Topic: Protected untreated posts above ground vs treated  (Read 992 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« on: July 28, 2020, 06:54:44 AM »
Our barn requires posts on the porch and the open lean to. I know 12" x 12" aren't needed, not even close, but I think that's what we are going with. With that said i have 3 choices in timber. Doug Fir, Southern Yellow Pine and SYP treated.
All will be above ground. I will make a bracket to secure post to the concrete. Prolly a 2 part and then weld the bracket that's fastened to the timber to the one fastened to the crete.
The porch posts are 8' and face west. Lean to posts are 16' and face east.
Since it's off the ground and over hang is 2', does this require a treated post?
Offline farmfromkansas
Re: Protected untreated posts above ground vs treated
« Reply #1 on: July 29, 2020, 08:16:47 PM »
Most of the porch posts made for use on houses are not treated.  Think I would use the Doug Fir, and make sure it is at least 6" off the ground, and leave a gap between the concrete and the wood. Don posted a link to a heavy timbers web site, it has several ways to attach your wood to the concrete, simplest way was a U shaped piece of strap iron poured with the U in the concrete and the uprights you put your wood between and bolt.
Offline Brad_bb
« Reply #2 on: July 30, 2020, 12:13:41 AM »
I've been using stainless steel knife plates for our own buildings.
They won't react with the oak posts, and if they ever get wet, no problem.  These are custom fabricated to order.
Offline Sedgehammer
« Reply #3 on: July 30, 2020, 01:53:51 AM »
Yes, I think I've seen them in the timber frame area. Thanks
These are 12" posts, so wood need to be bigger. I'd fab them with 2 holes offset for the upright and 4 for the bottom. Prolly 3/8 min plate for the bottom i thinks.
Question though. How do you line up the hole through the wood to be exact enough through the metal?
Do you have a drill press for the timber?
You use a metal pin with wood plugs?
Do you epoxy the bolt anchors to the crete?
Any preferences on wood?
What is the 2 larger round holes for?
Offline mike_belben
  • Pulp Friction
« Reply #4 on: July 30, 2020, 10:35:31 AM »
You can hammer drill a SS redhead anchor into the center of the pad, drill a mating hole in center of the post and put an asphalt shingle, grit down, between the two for a moisture barrier so the post doesnt wick from the cement.  During hot weather the load will squish asphalt up into the end grain to further seal it.  I mean nothing says you cant brush some roof flashing sealer on the end too.
Isaiah 63:10
Offline Jensming
« Reply #5 on: September 09, 2021, 08:46:25 AM »
Brad - is there a way to reach you to inquire about ordering these?
Offline Tom King
    • HistoricHousePreservation
« Reply #6 on: September 09, 2021, 11:15:12 AM »
I built a timber framed porch in 1983.  Every piece is treated SYP, including the 12x12x16' posts.  The porch roof has four feet of overhang, and is still solid as a rock today.
That house has changed hands three times since I built it, on a nice lake lot, and the last time it sold was for well over a million.
The guy that bought it from me originally spent a couple of hours going over it with me, drove off but didn't get out of sight, turned around, came back, and wrote me a check for it right there.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: September 10, 2021, 10:19:31 AM »
boy i could use friends like that guy.
Isaiah 63:10
Offline Tom King
« Reply #8 on: September 10, 2021, 11:42:11 AM »
He had just sold a Pharmaceutical company for 114 million.  He came up with a test strip method for quickly testing for Marijuana use.  He tried several other businesses, like liquid Aspirin, but none of them ever made a go.
He hooked up with a young, really good looking woman who ended up with everything he owned.  Don't know the details, but he didn't live long after he had to sell everything.
Offline beenthere
« Reply #9 on: September 10, 2021, 11:54:16 AM »
Quote
Surprise! Surprise!  Where there is money, there are gold diggers.  Heffner had it figured out tho...
Offline fluidpowerpro
  • Hi there!
« Reply #10 on: September 10, 2021, 01:02:18 PM »
I recently read about a product called Bor-8. Its a small rod this is inserted into the post. Its used to help prevent rot on wood. I have not used it so I cant attest to how good it works, etc, but maybe its something you could consider using as extra insurance.
Change is hard....
Especially when a jar full falls off the top shelf and hits the top of your head!
study relating to serviceable life spans of treated/untreated fence posts
Started by Modat22 on General Board
Last post June 01, 2007, 07:47:46 PM
by Tom
anyone ever built any outbuildings or anything with untreated posts?
Started by hazazil on Timber Framing/Log construction
Last post August 12, 2018, 03:47:11 PM
by Autocar
Protecting untreated posts from rotting?
Started by mtcates on Timber Framing/Log construction
Last post August 27, 2010, 06:25:06 AM
by ljmathias
Treated posts
Started by ArnoldFarms on Sawmills and Milling
Last post March 25, 2014, 04:13:50 PM
by Ocklawahaboy
