SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Maple Sugar 2022  (Read 10740 times)
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
Re: Maple Sugar 2022
« Reply #20 on: January 16, 2022, 10:46:53 AM »
Dumb question, do you just drill a hole and push in a tube for the jug on a tree method?
I drilled holes, gently pounded in a plastic tap, then attached the tubing to the tap. I do plan on testing out just inserting the tube into the drilled hole next, as I'm out of taps.
You coulld do that for sure, the sap will even run down the outside of tube...
Offline IndiLina
« Reply #21 on: January 16, 2022, 10:51:30 AM »
I beveled the end of the tube to create a tighter fit.
Tracts in So. Indiana, Nor. NC, SW Virginia
Offline IndiLina
« Reply #22 on: January 23, 2022, 07:45:26 PM »
Boiled today in NC.
Offline Chuck White
  • Sawing Mobile 2005-2022
« Reply #23 on: January 23, 2022, 08:42:33 PM »
Now, that picture brings back some memories!
Thanks for posting!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, Retired Mobile Sawyer 2022, 2018 Silverado 4X4,  2019 Subaru Forester.  Cooks Cat Claw Sharpener and single-tooth setter
Offline IndiLina
« Reply #24 on: January 23, 2022, 08:46:41 PM »
Thanks for posting!
First time using my grandpa's old boiling pan I saw him use when I was a kid, so brought back some memories for me, too.
Offline Stephen1
    • muskoka Sawmill
« Reply #25 on: January 24, 2022, 09:00:54 AM »
I remember doing that. We had cement blocks though, not stumps. looking good
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #26 on: January 24, 2022, 06:35:56 PM »
A sign of things to come  8) 8) 8) 8)  I figure we'll start tapping around February 12th.  Our first run last season was 2/22 and then is didn't run again for three weeks  ;D
Offline IndiLina
« Reply #27 on: January 25, 2022, 11:30:13 AM »
First little bottling of the year.
Offline rastis
« Reply #28 on: January 28, 2022, 08:47:26 PM »
I’ve been watching the temp trends to see when to tap. Right now it’s looking like 2/9 to tap. I have 144 taps on vacuum and produce about 60 gallons a year, boiling on a 2x6 modified with AOF and boil right around 50 gph
Mike, that fiber filter is still yours if you want it. You coming up this way soon or shoot me your address and I’ll mail it.
Offline Stephen1
    • muskoka Sawmill
« Reply #29 on: February 06, 2022, 07:31:49 PM »
We are still solid in winter here. Our normal tapping is March 10
Offline OH logger
  • livin the dream
« Reply #30 on: February 06, 2022, 08:17:11 PM »
Gonna run out normal 200 buckets this year. That’s enough to keep it as a hobby. We are adding a Smokey lake auto draw this year I’m excited about and a little scared too. If I have to go unload logs or do something else I hardly trust dad to keep an eye on the draw off. If his phone rings the draw off is the last thing on his mind. 😆. Last year we had a real close one. I had to go in the house and I got back out and he was 3 degrees over where we were drawing at. 😯. Should be a great addition. As long as it works right 👍🏿
Offline Corley5
    • Whittaker Farms
« Reply #31 on: February 06, 2022, 09:05:52 PM »
Our Marcland auto draw has always worked very well.  But it's always watched just in case.  Never trust a machine :) :)
Offline mike_belben
  • Pulp Friction
« Reply #32 on: February 06, 2022, 09:57:25 PM »
just saw this carl, thanks buddy.  i will PM you in a minute
its starting to feel like im behind, but last year i tapped on valentines and it was a dud for 2 more weeks.  was that on account of the wacky year or .. ?
Revelation 13:11-18
Offline mike_belben
  • Pulp Friction
« Reply #33 on: February 07, 2022, 11:11:55 AM »
im totally not ready.
Revelation 13:11-18
Offline GAB
« Reply #34 on: February 07, 2022, 02:53:48 PM »
On Feb 18 in 1981 (my dads 55 birthday) he boiled enough sap with a 5 x 16 rig to make a barrel (31.25 gal.) of syrup between his morning and evening dairy chores.  Then old mother nature froze everything solid for 3 weeks.
When it comes to agriculture mother dictates.
GAB
Offline Jdock
« Reply #35 on: February 07, 2022, 06:20:57 PM »
Here in Nw NC I tapped my trees last Sunday. Roughly 14 taps on 3/16 tubing. Over the weekend I boiled about 3 qts of finished syrup. 3/16 tubing is awesome. One 2 day run yielded over 30 gallons from 7 trees
Offline OH logger
  • livin the dream
« Reply #36 on: February 07, 2022, 07:43:59 PM »
Lol. By the looks of your weather you should be ready 🔨
john
Offline mike_belben
  • Pulp Friction
« Reply #37 on: February 07, 2022, 08:02:35 PM »
I cant remember the last time things went how i planned.
Revelation 13:11-18
Offline rastis
« Reply #38 on: February 09, 2022, 12:54:16 PM »
Finished tapping about 7:00 last night and most trees were dripping. Replaced about 300 feet of tubing due to tree rat damage. Checked the controller this morning and vacuum should kick on when it hits 38 today. Maybe boiling tonight.
Offline Joe Hillmann
« Reply #39 on: February 09, 2022, 04:41:48 PM »
If you take a piece of PEX pipe ( I think I use 3/8 but not sure) you can gently heat it with a torch while rotating the pipe in one spot above the flame.  Once the pipe starts getting plastic you can pull on both ends and the spot that was heated gets narrower.  While still stretching the pipe dunk it in cold water to make it solid again.   Then cut the pipe where you heated it.  Now that end tapers from the full diameter of the pipe to whatever you stretched it down to.  That taper can be pushed into a hole in the tree that is just a tiny bit smaller than than the original pipe diameter.
That gives you a nice tight, leak proof fit between the pipe and the tree.  I am cheap so that is how I make all of my taps.  If my description isn't clear enough I can post some pictures if you need.
SPACE AVAILABLE
