Author Topic: Spark arrestor screens... can you remove em?  (Read 31426 times)
Offline Great Big
« on: March 13, 2009, 09:43:39 AM »
Is there any benefit of removing the screens?  Better exhaust flow?  Risk of fire?
Any performance gain?
Brandes Farm Trophy Whitetails Est. 1999
Managing for Quality Whitetails in Southeast Ohio
Offline ErikC
    • Erik Cordtz Enterprises
Re: Spark arrestor screens... can you remove em?
« Reply #1 on: March 13, 2009, 10:59:41 AM »
  We can't run without arrestors here, and the fire danger is so high I wouldn't anyway. There is less restriction without it, but cleaning them from time to time helps a lot. If it's hot and dry, I wouldn't risk it.
Offline Polly
« Reply #2 on: March 13, 2009, 01:08:24 PM »
my problem with them is when you shut down the engine and they pop like a shotgun ,i have converted two engines back to dual exhaust using the old type mufflers that have a 1 inch threaded inlet ,this adapts easily to your manifold engine pipes ::) ::) :)
Offline SwampDonkey
  • Large Tooth
« Reply #3 on: March 13, 2009, 03:10:55 PM »
I have never removed the screen in my saw, but it's a homeowner type saw. Not a  saw used in the bush for a living. That being said, the screens come off our brush saws. I don't know anyone that leaves them in. It wouldn't be so bad if they didn't gum so quick. And don't accuse me of not knowing my gas mix like the last guy. If so, than I guess us brush cutters are some dumb lot.  :D
No amount of belief makes something a fact. James Randi
Offline ErikC
« Reply #4 on: March 13, 2009, 09:52:59 PM »
  What's your climate? SD has pretty high humidity, but where I am is is under 10% all summer and most of fall, with huge amounts of fuel. I would fire someone if I found out they had removed it, because if the USFS found out they'd cite us, and if we started a fire we would pay the bill. If I lived in a different climate I would probably remove it too.
Offline Al_Smith
« Reply #5 on: March 13, 2009, 11:10:47 PM »
I won't say go for it .However in northern Ohio you would have an awfully hard time setting a woods on fire with a chainsaw .
An yes as a normal rule they will run better but of course they get kind of loud  if you strip the baffles .Just pulling the screen doesn't make them bark that much though .
Now as far as reworking a muffler there must be ten thousand threads on evey web forum on the net pertaining to same .
Offline SwampDonkey
  • Large Tooth
« Reply #6 on: March 14, 2009, 07:25:33 AM »
On a Husky spacing saw, you have to take the muffler off to get the screen out. But, none-the-less after about 6-10 replacements of that screen to clean the thing the threads are going to be all stripped out. Is DNR going to give you a new saw when the muffler starts dangling on there. NO! A spacing saw runs more hours on high rev than most guys on a chain saw. Your not holding the throttle on when you walk around choosing your next tree to saw or waiting for the tree the fall for limbing. A spacing saw covers about every square inch of ground for up to an hour each tank. The tank is usually bigger on a spacing saw as well, so a lot more fuel runs through it in a day.
Offline Jim Spencer
  • Washington, Mi
« Reply #7 on: March 14, 2009, 07:58:56 PM »
What is a "spacing saw"?
Offline SwampDonkey
  • Large Tooth
« Reply #8 on: March 14, 2009, 08:08:57 PM »
errmm brush saw to some.  ;D No, not those home owner weed whackers. ;) We call'm spacing saws or thinning saws up here 'cause that's how they are used.  ;D
Here's a Stihl FS550. The screen on it bolts on to the outside with a metal shield over it. The bolts still strip out on the muffler as the exhaust and rain corrodes it. The screens bugger up fast and you loose production. The newer Huskies have the tank that goes out the tube and holds a lot more gas than this, but are a little less powered than the old professional Husky saw and this Stihl. Echo now is the biggest brush saw, power wise.
Offline Al_Smith
« Reply #9 on: March 15, 2009, 11:22:40 AM »
 If I could post a picture on this site I would show you all something you actually would not believe .
Last spring I did a simple port job on a Stihl 038 AV .The saw had a carboned up piston top which I cleaned before reassembley .
Just yesterday I lifted the top to cut down the cylinder base after maybe 30-40 hours of running time .That piston had absolutely no carbon ,looked new .
I attribute that to two things .First 32 to 1 mix and secondly a gutted muffler .
So say what you will about oil and do what you like about mufflers .I know first hand as do others . :)
Offline arojay
« Reply #10 on: March 15, 2009, 12:01:01 PM »
I agree about the oil and mufflers, but I also think that octane has an effect.  I used to run regular gas and my screens would carbon up, along with some other undesirable conditions.  Since I started running gas over 91 ron I have none of these problems.  More complete combustion.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
Offline SwampDonkey
  • Large Tooth
« Reply #11 on: March 15, 2009, 12:09:57 PM »
I never use regular gas in my saws either, was recommended not to by the dealers. I use higher octane.
Offline Polly
« Reply #12 on: March 15, 2009, 07:36:55 PM »
my sthl manual says use medium grade 89 octane ,it sure makes it start better ;) ;)
Offline SwampDonkey
  • Large Tooth
« Reply #13 on: March 15, 2009, 07:52:06 PM »
I use mid grade also, I recall the dealers saying the high test had no added benefit. Clean my air filter on my brush saw every day and I never have engine trouble until the saw in warn out. I'd say 200 acres on a  brush saw is pretty dang good, 300 is even better. :D Most are pretty much done after 200. Some only cut 100 and kept as spare, because some guys buy a new one regardless. I have two saws now that have cut less than 100 acres and no trouble to start right today if I wanted to. I plan on using them both this summer. Two saws and I should cover twice the ground eh? ;D :D
Offline zackman1801
« Reply #14 on: March 16, 2009, 04:46:56 PM »
one in each hand? :D
As far as spark arrestors go, if you do remove em make sure you dont get caught. The US forest service will write out fines for the removal of the spark screens. I cant see that it would make a TON of difference removing a 1 inch piece  of metal screen for the muffler to breath better, if you need to get your muffler breathing better do a muff mod on it, but i would still add my own screens for it then too. The question is, is it really worth it if you do start a big fire in the woods?
"Improvise, Adapt, OVERCOME!"
Husky 365sp 20" bar
Offline Al_Smith
« Reply #15 on: March 16, 2009, 05:23:32 PM »
 Nobody said you couldn't put the screening back in .Just make the hole larger .That's simple enough .
Offline SwingOak
« Reply #16 on: March 16, 2009, 08:39:09 PM »
When I bought my 262XP back in '94 I asked the guy if there was any potential problems I should know about, and he said that as soon as I got home I should take the screen out. He said most of the saws he got in for service just had a clogged screen, and there was no reason to have it in there unless I was going to be cutting on USFS land, and I wasn't. I've never seen a spark come out of the saw - ever.
Now, my dad has a 1961 Homelite that looks like the 4th of July when it runs. He tells me it never started any fires, but it's easy to see how it could happen.
Offline Al_Smith
« Reply #17 on: March 18, 2009, 06:28:41 PM »
I think that's probabley typical of a low compression saw engine .Some of those were only 6.5 to one comp ratio .
Offline IndyIan
  • Weekend Woodsman.
« Reply #18 on: March 20, 2009, 09:26:51 AM »
I run my 372 with the screen off and I pryed the flap over the exhaust hole up a bit, I can't say I noticed a huge difference in power but the saw did run a little bit leaner so I think it gained a bit more hp.  I also just turned the screen around and left it on the saw so I could find it again if it gets really dry here.
I do see the occaisional spark come out of the exhaust when cutting into the evening so the screen is there for a reason.
Offline zackman1801
« Reply #19 on: March 20, 2009, 12:43:27 PM »
If your going to open up a muffler or do things to make it flow better you have to richen up your carb. If you dont give the saw some more mix its going to burn itself up by running lean. Just some things to think about before you start gouging holes in the muffler. But it will gain you more power and speed.
Husky 365sp 20" bar
spark arrestor
Started by minn firewood cutter on Forestry and Logging
Last post January 05, 2015, 10:19:54 PM
by treeslayer2003
No Spark Arrestor?
Started by Old_Town on Chainsaws
Last post May 05, 2010, 07:52:16 PM
by campy
spark arrestor screen
Started by SawGuru on Chainsaws
Last post January 11, 2004, 07:48:27 AM
by Ron Scott
Started by keppoch on Chainsaws
Last post March 24, 2009, 07:40:07 PM
by SwampDonkey
