How large of a chainsaw does an average ....
Started by Randy1949, May 16, 2020, 08:09:07 AM
Randy1949
I live in north Al. and have 10 saws with a new Stihl 462 with a 24 inch bar being the largest.  Being an average home owner with 10 acres of land, I am wondering if I need a larger cc saw, like a Husky 395 or Stihl 661.   Can average person even handle a larger saw or can a 462 cut anything a 395 or 661 cut even if slower?  Any comments or opinions will be appreciated.
Randy
lxskllr
A 90cc saw is gonna get heavy, and make a long day if you don't absolutely need something that big. You need to figure out what size wood you're cutting, and how much, then go from there. I started all this with a 362 and a 25" bar. That worked fine for what I needed at the time. If I had to cut all day with a 25" bar, a 462 would be a better fit.
Stihl specs a 28" bar as the maximum for the 462. If I had the 28" bar frequently buried in hardwood, I think I'd want to step up to the 661. OTOH, if I very infrequently needed something big, a 32" bar and a skip chain should do the job on a 462. On the long end of the bar scale, you'd do yourself a favor getting an ES Light bar. Balance is more important than weight imo, and the lighter bar will balance better.
gspren
I've been living on our farm for over 30 years and my big saw is an 044 with a 20" and 24" bars and anything bigger would have been for the "neatness" of a big saw and there's nothing wrong with that.
Well, if you have 10 saws and 10 acres, you are not an average homeowner.  I am sure you can handle a bigger saw if you do well with all the others.  So you need a bigger saw for something?  do you just want one.  I have an 880 with a 5 foot bar.  I have used it with that bar twice, and it cost as much as a used car.   :)  .  I run it to exercise me and the saw. we have big elm and cottonwood here.  I had bought a 661 and it had problems the dealer could not seem to fix, so I went on up in size.  got full credit for the 661.
Real1shepherd
Not to be argumentative/disrespectful but if you have 10 saws, you should have covered yourself with every conceivable cutting scenario on your place. But given CAD and all that, nothing wrong with just collecting.
If you had a 372XP it could be setup to cut anything you had. I'm sure there's a similar Stihl model. A 395 would be a waste of a larger saw....you don't say the size of the timber on your place? Bigger cc saws can be somewhat dangerous for amateur cutters.
Kevin
The first real saw I bought was the 046 and it was the only saw I had for 20 years.  I had 5 acres but in ks. not as many trees.  It was great with a 24inch bar, had a 3 foot just in case.  now I have many but the 261 and my old 046 mag are my most often used.
Al_Smith
Just depends on what you want to do with them  I guess .I have saws from 1.9 cubic inch up to 7.5 cubic inch .The two I use  the most are an 024 Stihl at 42 cc and a modified 038 Magnum .The later at 72 cc because it's modified can very easily handle a 32" bar .
The rest of them,maybe 45-50 are just a hobby thing which is not for everybody .Any more if the saw is not rare or has the ability to be modified into a really fast saw I'm not really interested in them .I've got two 99 cc saws right now I'm restoring .However after I'm done with them  I don't see using them that often .
Pine Ridge
I have three 372 Husqvarnas that i use for logging with 20" bars on them. I have a 288 Husqvarna with a 28" bar that i only use for bigger trees when needed. The downside for me with the 288 is that it may sit for a few months between use, its hard on saws sitting for periods of time not being used, kinda like extra vehicles that don't get driven alot. I can run a 28" on the 372s, but the 288 handles it much better.
homeheater
All depends on your land and trees.  I have 38 acres and am cutting on about 18.  I have probably 20 face cord on the ground and in the wood shed.  Have a 6400 with a 24" bar that will sit unless it has to be used.  It made 8 cuts in all this wood.  There is a reason I have 6 saws from 43-52cc.
Patrick NC
I've always had a 50cc and a 70cc saw. Currently they are a 550xp mark 2 and a 372xp. The 550 runs an 18" bar and the 372 has a 28". I have a 36" for the 372 but I've only ever used it once.  I only cut part time to supply my mill, but I've never felt like I needed anything bigger.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Sorry all those numbers don't mean nothing to me. I only know what a husky 372 and a efco 152 is,because that is what I have. Husky is a 70cc and the efco is a 50cc.
Just like the models numbers on tractors, I have no idea. I only know about 4 models. ;D
That 372 can get heavy at the end of the day. Did a number on my shoulder until I started to use that efco saw. I did a lot of sawing with that efco.
Tacotodd
Your 462 should do anything you need. With proper technique you can do a lot. I do most everything with a 50cc and the remainder with a 70cc. The 50 wears a 16" and the 70 swaps between my 20" and 28" for everything else and I have yet to find anything around here that people want/allow me to cut that I can't handle. I want it for my own firewood so dropping them in a safe direction is the most difficult part. I wouldn't mind having that 661cm, but reality tells me that it wouldn't be a financially good decision. Just my 2 cents. My biggest yet to approach has been 40" at the stump and if the person wanted it lower, then I would have to get a stump grinder involved. If you drop it at belt height first, you would be 10 steps ahead. You just have to remember that this is on your own land.
Trying harder everyday.
Real1shepherd
A lot of good advice here for the homeowner with more than an acre.
Having been a logger for part of my life, I adapted what I already had in saws to move forward into new venues. I can tell ya though, there's some real BS out there about chains and saws. One of the dumbest 'absolutes' out there is that skip-tooth square file chisel chain gets dull easily and is only suited for PNW softwood, like Doug Fir.
After I quit loggin', I moved into farming and raising sheep. Eventually I bought two farms in central MO and joined them as one. I had about 500 acres. 120 of those acres were woods. I was able to immediately put to the test skip-tooth, square file chisel chain against walnut & oak. Granted, you need 80cc or more to run this .404 chain. It cut like butter into anything I put it in and it stayed sharp like in the PNW wood.
Moral of the story is; don't accept 'absolutes' from the Internet....go with experience and everyday practicality. Consider boards like these as an exchange of ideas based on real time experience. If you're buying and using things just based on what others have 'heard' or tried one time, that's a bad rabbit hole to start down.
Two saws should be enough to service anything you have on acreage. Even one saw with different bar lengths is the most economical way to go. Having a big cc saw sitting around only for the occasional task is not smart usage of a tool. Conversely if you cut/buck large stuff with any regularity, why stand there and gnaw on it with a smaller saw/bar?
Tree services do this and it drives me absolutely crazy. They could cut their time in half by using the right sized chainsaw for the task. They're often tasked to cut/remove large old tress from someone's property and they send the guys out with undersized limbing saws. Sometimes I just have to turn away........
Kevin
Real1shepherd
Quote from: thecfarm on May 17, 2020, 08:30:20 AM
Nobody ever mentions this because as guys, we assume that everyone is big and macho. But the truth is, many homeowners are physically limited into what they can use all day. And also, some homeowners have old injuries and/or are not in very good physical shape. With a chainsaw, you just can't will yourself through the day because you think you ought to be able to do everything the other guys brag about online.
Know your physical limits when buying a saw; if it feels extraordinarily heavy or hard to pull start for you because of a shoulder injury or your physical stature, consider something else. It's really easy for someone to hurt themselves with a saw larger than they can handle.
Conversely, don't take on a large job at hand with a little termite saw. At the end of the day, you'll be more tired then you need to be, considering the original task.
Kevin
longtime lurker
Look I still kill about 500 ton of log a year just to keep in practice logging and put about 1200 ton a log a year through a sawmill, which involves a lot of crosscutting because we buy our logs at tree length. So in terms of time on a saw per annum I am a long way from the 10 aces of woods to keep tidy class, but no-where near where I used to be as a serious pro logger.
I have 5 saws. A pair of 395's, a pair of 461's and a little top handle saw that gets started about once a year. As I get further away from being a serious pro logger that will drop back to 3. One day that little top handle will break and then I'll be down to two. I'll stick with 2 because you cant be stopping a sawmill because 1 saw is sick.
If I ever change careers and just go back to being a guy with a couple acres I'll only own one. Because I have but two hands and I (mostly) keep them both on a running chainsaw. 1 chainsaw that gets used regularly is a better bet than half a dozen sitting around with the carby's gummed up because they arent getting enough fuel go through them to keep them healthy.
Ed
I'll run a 36" bar and full skip chain on my 046 if I need it....no issues at all. Much easier on my walking corpse than the 084 and 36" bar.
Really need to rebuild the 066 though.
Ed
celliott
I'd guess 90% of people could cut anything they ever wanted (or should) with a 70cc saw. No, make that anything that will handle a 20" bar. At some point, for personal homeowner use, you have to question if a huge tree is worth your time and physical effort. Because it's usually way more than the saw effort on big trees, regardless of what you're doing with them.
I used to buck up yard maples with a 357xp and 20" bar, cutting from 3 sides. Takes time.
70cc will get anything done. More than that, if you want more power, that's another deal. And yeah, probably a lot of folks who don't run a saw very much would have a hard time running more than a tank or two through a 90+cc saw, physically.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
sablatnic
How large I need, don't know.
Have a 100cc with 48", that I use maybe every ten years.
A 80cc with 28", that I use about every two years.
A couple of 70cc with 20", maybe used once a year.
A few in the 50 - 60cc range, 15 - 18 range, used a few times a year.
Some in the 40 - 50cc range with 12 - 15", used whenever I need something cut.
A couple sub 40cc for climbing or clearing of bushes and small stuff.
How large is needed and how large is for fun - I don't know and don't care, they were cheap / free.
A 70cc with 24" / 28" would cut almost all what I have cut yet. But it is fun pulling out the bigger stuff.
Eddie Southgate
Quote from: Randy1949 on May 16, 2020, 08:09:07 AM
I live in Minor Hill TN , not far from you . I have 36cc ,50cc 60cc , and 72cc saws running right now . Truth is unless you have a lot of large wood to cut and plan on doing so on a regular basis you will not NEED a larger saw than you already own . The saws I use the most are the 36 and 50 cc saws .
1997 Husqvarna 272xp 24"
1998 Husqvarna 136 12"-14"
2019 Stihl MS261 CM 16"-20" wearing an 18"
1966 ? Remington Super 754
2019 Stihl MS261CM  20"
Stihl 0041av 20"
Stihl 041av Electronic 20"
Stihl 044av
Stihl 056 Magnum II
1963 Ford 2000
801 Ford
Woodchuck
Haleiwa
Husqvarna uses the first digit to designate the series and the following numbers and the approximate size of the engine.  Thus, a 55 Rancher and a 455 Rancher are the same size, but the 455 is newer.
Stihl uses odd numbers for farm duty saws and even numbers for professional saws.  The older models started with a zero, then the zero was moved to the end of the number, then higher numbers indicate later series.  Thus, a 046, 460, 461, and 462 are all similar size, but the 462 is the latest version.  The big Stihls are the 66 and 88 models.   A 462 Stihl and a Husqvarna 372 are similar sizes.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Quote from: Haleiwa on May 23, 2020, 06:38:31 PMStihl uses odd numbers for farm duty saws and even numbers for professional saws.
So my MS362 is a what?   ;)
longtime lurker
Stihl numbers have never made sense to me. Back when I started the pro Stihls available here were 056/076/070 and 090. Then they discontinued the 056/076 series for the 066 and 088 but the 66 was smaller than the 56 and the 88 was bigger than the 76.
Then emissions regulations came along so they turned the 088 into the 880 and the 066 into the 660 and dropped the 090 out of production worldwide.
Today I can buy a MS 660 or MS880 in whatever version they are on now.
But I can also buy a 651 which is the old pre EPA 066 or a 780 which is the old pre EPA 088 if my government hasnt agreed to the EPA restrictions.
And could get a brand spankin' new in the box MS720 (which will run rings around the lot of them in big wood)  which is a 50 year old 070 with updated anti vibration mounts - if my government didnt make chain brakes mandatory.
And if you put a gear drive on an 2020 MS720 (because the 50 year old part you have in a box on the shelf fits) than it becomes an 090G circa 1976.   ;D ;D ;D
Yeah... Stihl numbers: I luv them.
ehp
the older I get the smaller the chainsaws get  Im not sure because Im getting smarter or lazier ;D. Now I pretty much run 462's , I have ran the ported 372 abit but not much , big saws sit in the shop around here , I got a real good ported 3120 sitting in the shop that I have not started in I guess 2 years and its even got a pipe if I want to run that , I sold the 395 and 661 as I just never use them . If I need to run a 36 inch bar I got a ported 461 that will run one but its going to need to be over a 5 ft diameter butt for me to even think about running that long of a bar , not many trees I cannot cut with a 28 inch setup on a saw
Haleiwa
Quote from: Magicman on May 23, 2020, 07:22:31 PM
Stihl's website lists the 362 as a professional saw
I was told my 261 is a pro saw.  best power to weight ratio.  for a smaller saw.
I use the bottom end of the Husqvarna pro models, the 60 cc 550. I thin small wood for firewood, the woodlot is all second growth since 1994. A whole lot less splitting involved. ;D So I won't be cutting any 30" aspen or maple for a few more years. Although, with a few large tooth aspen, you can cut a few of them at 30 more years, but I'm not cutting wood in my 80's. There comes a time to hang up the hat. ;D :D :D
Quote from: Haleiwa on May 24, 2020, 08:36:20 AMStihl's website lists the 362 as a professional saw
I know and my point was that Stihl's numbering system only describes a certain saw.  smiley_dizzy  It would be difficult to expand their numbering beyond that.  whiteflag_smiley
Randy1949
Thanks for all of the great comments!   I think I fall in the "macho? category as I often think I need, or want, a larger saw although at 70 I'm still strong as ever but can't hold out near as long.   I just love chainsaws.
Randy
longtime lurker
Quote from: ehp on May 23, 2020, 08:29:56 PM
I got to thinking after reading this and what I'd written above and.... yanno we all tend to think everyone else uses a saw under the same conditions we do.
I don't really think anyone at Stihl is building an MS 720/070 today with no chain brake and a manual oiler to save throwing the tooling out. Best guess - that old banger can run on a grade of fuel a whole lot poorer than any of the subsequent designs, which probably matters when you're in the middle of the Congo or somewhere else where fuel comes in drums and is probably half stale and you get the rust for free.
Same as if I'm correct in thinking an MS651 is interchangeable with the 066 magnum... there was a big difference in the torque curve between 066 and 660, the EPA thing chopped the legs out of them and if you're running 404 chain that difference becomes really noticeable. I run 404 because it suits my species better so.... that was when I went to the 395's. Now I like those 395's and no way would I think about an MS660 but if I could buy a new 066 magnum I'd be thinking about it.
I got a couple 461's because they fit better on the skidder/dozer for a spare saw. Nice saws but I tried to put 404 on a 461 but even with a 24" bar they're pretty hopeless. So back to 3/8 which wont hold an edge for long. Hearing someone talk about banging a 36" bar on one leaves me.... yeah mostly a little jealous because I like those little saws they're just not capable of carrying the chain that works here. Weird world huh?
sawguy21
We are in different worlds my friend. ;D The 651 and 720, would love to see one of those, have never appeared in North America. I worked for an Oregon distributor, the .404 market has dried up. We gave the last of ours away to free up space, a few loggers on the west coast run it on the MS880 but that is it. My boss wanted us to push it in Alberta as sales were non existent, I pointed out nobody runs the big saws there. It's all tree length fence posts.
I had a call for a new 070 when I was with a Stihl dealer! You want a WHAT? He was going to south east Asia where they were still being used, it was cheaper to take it as carry on from Canada than buy locally. I had no idea they were still produced.
gspren
I have 3 Stihl saws, 041, 044, and 261, two of those are pros and I know it's not the 041 cause it says Farm Boss right on it. The 044 is a pro cause the dealer said so and she knows her Stihls while the 261 has to be a pro because it's just too nice to not be!
Real1shepherd
Quote from: sawguy21 on May 24, 2020, 11:15:40 AM
I assure you there are plenty of loggers here in the PNW still using .404 chain exclusively. Don't believe me, call up Madsen's in Centralia, WA. They probably sell more .404 chain than anyone in the US.
I run .404 skip-tooth, square file chisel on my little Jonsereds 80. That would be the minimum to run it though; 80cc. And on a 28" bar, it's a ripping beast for the 'smaller' stuff.
Then I have a Husky 2100 and a J'reds 2094 set up with 36" bars and the same chain. I use them all the time.
So speak for yourself on the on the decline and death of .404 chain.
Kevin
Geotech
I have 24 acres of small to medium hardwoods.  I bought an Echo CS-490 when I first bought the place.  Recently bought a Stihl MS 661 with a 36 inch bar to try milling.  I can't imagine needing anything else.  If something other than milling is too big for my Echo, I would just slap a shorter bar on the Stihl.  Actually, the 36 inch bar is quite serviceable for bucking.  Not really something I want to mess with to fell 24 inch and less diameter trees though.
Real1shepherd
It all depends on the timber you're cutting down & bucking. But even in smaller stuff, I would never walk down a log measuring log lengths with my Spencer tape and use anything less than a 28" bar.....too hard on the back.
A chainsaw is just a tool....you match it to the job at hand.
Kevin
ehp
.404 is pretty dead around here , we can buy different grades of 3/8' in hardness . I keep hearing about a longer bar is easier on the back but when your stumps are 6 inches high or  lower to the ground your back is going to be sore until you get use to it and we pretty much bore cut everything so most days Im running a 24 or 28 inch setup
sawguy21
Kevin, I wasn't trying to start an argument. Obviously your market is different.
Real1shepherd
Quote from: sawguy21 on May 26, 2020, 01:04:12 PM
I know you weren't.....I'm cool with it.;D
It analogous to saying the car I drive everyday is dead and there's no parts for it. There may come a day when that's true, but in the meantime, I use it. Same with .404 chain......
Madsen's so far supplies me with everything I could ask for. Silvey quit making their old tree jacks, so Madsen's stepped up to the plate and had one just like it produced....maybe even better than the original. Cost is over a thousand, but obviously there's still a market for it and they carry parts to rebuild the old Silvey jacks. That's dedication to their loggers.
However there could come a day where Madsen's sells out like Bailey's and tries to be everything for everybody. I hope I don't live long enough to see that happen. Bailey's was a kick-a** store once, where you could call up and probably get Bill Bailey himself on the phone. Their catalogs were fun and you felt a part of the fraternity. A lot has changed there.
Kevin
Real1shepherd
Quote from: ehp on May 26, 2020, 10:09:24 AM
All depends on what kinda scale you're working in and what shape you're in. Like I said, I'm not walking down a scale log, limbing, with anything less than a 28" bar.
Today in most places, you can get a lot of scale cut with a 28" bar.....just what the industry has become. Certainly most everything with a 36" bar.
Kevin
dougand3
The Stihl odd/even #s made more sense back when there were 021, 025, 026, 029, 036, 041, 044, 046 saws. Odd was homeowner/farm and even was pro. It still makes some sense (pay attn to 1st  2 #s) with MS250, MS290, MS311, MS391 = homeowner/ranch and MS261, MS362, MS460 = pro.
longtime lurker
.404 is dying here, which is as much about the decline of the regional timber industry as anything... demand for big saws rigged for day in day out felling operations is naturally going to fall off when it reaches a point where you can count the mills and logging contractors left without taking your boots off.
3/8 tungsten chain is slowly eating into what marketspace 404 has left. You carry 5 chains, change them out as required and sharpen in camp at the end of day. Tungsten always seems half blunt to me and it cuts slow... But it's also half sharp and you spend your day falling not filing. It's expensive to set up initially and you still need a 90cc saw to drag it but... tons on the ground at the end of day is what you get paid on and depending on the logs it can add up.
I'm mostly a sawmiller now so imma hold out with 404 as long as it's available. I can see the teeth to file them. :D
Real1shepherd
Yeah, I don't want to get into the perks & advantages of using .404 chain and there are many. It just becomes a shouting match between the wood cutters/homeowners/weekend warriors against the pro users.....pointless. In PNW wood, you can fell until lunch and then change out chains or sharpen....also a non-issue. But then as I noted in another thread when I moved to MO and had a big farm there.....the .404 square file chain cut through oak and walnut like butter. The myth being that .404 square file skip-tooth chain only works in softwood.
If your work big cc saws a lot you have muscle memory for the weight...it's a non-issue. If the wood cutters/homeowners/weekend warriors pick up a big pro saw, then the weight complaining begins. But.....chainsaws are just tools and so using a saw bigger than the task requires, is foolish as well.
I never heard anyone on a loggin' show complaining about saws being too heavy and the generation before me using gear driven saws had to deal with even more weight in the woods.
Kevin
