Author Topic: Splitting wood PPE  (Read 2657 times)
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Splitting wood PPE
« Reply #20 on: December 07, 2020, 04:12:59 PM »
Mike, according to Google the official death toll on the Boulder dam was 96. These are the ones killed specifically working construction from fall, blasts, falling objects, etc. I think I'd suggest a different example for downplaying the significance of safety equipment and procedures. :D :D
Offline mike_belben
  • Pulp Friction
« Reply #21 on: December 07, 2020, 08:13:20 PM »
Cmon howard, grim statistics led me straight to the USMC.  Danger?  Sign me up.
Isaiah 63:10
Offline doc henderson
« Reply #22 on: December 07, 2020, 08:25:14 PM »
the ppe is for the intermediate stuff so you can work more days, without blood dripping everywhere.  If you number is up, with a catastrophic fail... too bad so sad.
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #23 on: December 07, 2020, 09:12:44 PM »
Glasses first and always,   safety toe boots,  chaps help with the fly debris,
Gloves,  treat the handle of your axe with sticky stuff.
D
Online Southside
    • White Oak Meadows
« Reply #24 on: December 07, 2020, 09:48:28 PM »
Well as a guy with his name on the vest save list, to me PPE gives you a fighting chance.  You might not be in one piece, but at least the pieces are big enough to still work.
White Oak Meadows
Offline trapper
« Reply #25 on: December 07, 2020, 10:16:25 PM »
I have a peice of steel in the back of my hand that came off a mall when splitting with steel wedges.  Sawed the handle off so I wouldnt be tempted to use it again.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #26 on: December 08, 2020, 04:30:26 AM »
 Tacotodd you did indeed use the summons correctly and I am very grateful for the heads up because apparently there is a thread in the chainsaw section I need to avoid that involves thongs and flip flops. I am vehemently opposed to the use of flip flops by any grown man.
Back in the day, it was not uncommon for me to get home from work and be out in the yard in my Jonathan Taylor suit and 6 inch heels splitting enough to last till morning. For safeties sake, I kept my sunglasses on.
So yeah, be careful, itís a jungle out there.  :D
Say when
Offline Ed_K
« Reply #27 on: December 08, 2020, 10:35:00 AM »
 If your going to use a steel wedge to split wood keep it sharp and grind any mushroomed steel off. Don't stand a 4' piece on end and hold the wedge in one hand an hit it with the maul short sticked :o :( bat_smailey .
Ed K
Offline mike_belben
  • Pulp Friction
« Reply #28 on: December 08, 2020, 12:21:50 PM »
So what i read is that roxie loves a man in thongs.  Should his thong match your heels is the 64 million dollar question..  You could both look the part splitting wood together!
;D
Isaiah 63:10
Offline sawguy21
« Reply #29 on: December 08, 2020, 12:45:00 PM »
Roxie, I spit my coffee envisioning that. It must be a PA thing. :D
Offline Tacotodd
  • To learn and help
« Reply #30 on: December 08, 2020, 02:51:29 PM »
I love it!
No wedges, just an 8lb splitting maul, but my personal experience (just me) an axe works better. Again, just me.
Now I canít get my mind off of high heels and thong. Thanks guys!
A wedge n sledge maybe. But broke Todd, I have ZERO of either.
The really knotty pieces go to the outdoor burn pit for parties 🎉. Thatís the ORIGINAL hotsaw!
Trying harder everyday.
Offline SwampDonkey
  • Large Tooth
« Reply #31 on: December 08, 2020, 03:30:23 PM »
I usually am wearing my logger boots, helmet and screen goggles. I split pretty much where the tree lands along side a trail or road. I have no way to forward firewood logs or load them, so she gets blocked and split on site and either tossed in the pickup or the SxS firewood buggy. ;D
I just split with a Collins. I will need to forward rounds of tamarack home in the pickup to bust up on a hydraulic splitter. So far I have not cut the bigger ones to split, just the wimpy skinny ones that the bears climb and bend down.
ďNo amount of belief makes something a fact.Ē James Randi
« Reply #32 on: December 08, 2020, 04:06:06 PM »
and wearing some man's suit, named Jonathan Taylor.?  is does conjure a visual @Roxie . :) :) :)
Offline Tacotodd
  • To learn and help
« Reply #33 on: December 08, 2020, 04:59:52 PM »
Doc, yes it does.
Swamp, Iíve been cutting a lot of sweet gum lately and itís almost impossible to split green, but dry itís as easy as red oak. With that said, splitting on site is not an option. Why gum? Itís not for cooking, only for burning 🔥! Besides, nice and dry gum is REAL easy to get lit.
« Reply #34 on: December 08, 2020, 05:22:59 PM »
well @Roxie you may have avoided the thread on chainsaw safety, but you seem to have really jumped into this one.  all in fun of course!  8)   :)  DOC
Offline SwampDonkey
  • Large Tooth
« Reply #35 on: December 08, 2020, 06:40:02 PM »
Will fir pitch do? Some people waste money on pine tar and turpentine. Get some nice fir pitch on there, it's even UV resistant since it's used in window repair and don't yellow none. Fir pitch on topper windows hasn't yellowed in 7 years now. (fir pitch blisters and sapwood end grain rubbing on glass)
Gotta smile sometimes. :D :D
Offline SwampDonkey
  • Large Tooth
« Reply #36 on: December 08, 2020, 06:44:15 PM »
Doc, yes it does.
You know what it takes to get'r split, so take the easiest path I say. ;) Up here maple and yellow birch splits easiest green and frozen if doing by hand. My uncle used to split 6 cords every winter that way for the kitchen stove, for next season. White birch, aspen and fir are a dream to split. Not the BTU per volume of sugar maple or oak, but never froze to death yet. ;)
Offline Tacotodd
  • To learn and help
« Reply #37 on: December 08, 2020, 10:40:34 PM »
Swamp, it SEEMS like gum and pine have ABOUT The same BTU but keep in mind my case, Iím burning it outside so no real way to compare. The oaks that Iíve cut, I can tell have a lot of BTU in them. Pine and gum are great for a summer time party where you like the light but donít need the heat. Oak is great for heat but not so much for the light on a dark winter night 🤪 Just my perspective.
Offline mike_belben
  • Pulp Friction
« Reply #38 on: December 09, 2020, 09:36:21 AM »
Spiral gum can jam even a hydraulic splitter if its multi wedge.
Some stuff you just have to quarter up by noodling with the saw. For hand busting big rounds that wont pop, cut a pair of kerfs into it one bar height deep in a criss cross so as to make a phillips screw head.
Now pound a steel wedge into the far side until you hear crackling fibers.  Then wack a few times with your maul on the close side.  If it wont pop put another wedge in the center and work the two.  But dont try to use your maul between two wedges or your bust a handle by hitting the closer one.
If you dont wanna wedge em try to knock pieces out from the perimeter with your maul. The outer wood is straighter than the inner a lot of time and will chunk out easier. Just keep going around making a big round to a smaller round before trying to split in two.   On spiral gum is may be impossible.
Isaiah 63:10
Offline Edvantage
« Reply #39 on: February 19, 2021, 02:31:46 PM »
In my thinking the word accident comes from the dangers of careless ax use. I've knocked myself out with a splitting maul. A builder had cleared a lot and left firewood length pieces scattered around the building site. As I worked from one pile to the next I ended up with a clothesline behind me. The maul bounced off the clothesline and hit me in the temple. I crawled to the house not knowing if I had split my skull or not. Apparently I'm not the only one to do this. E.H. Kreps writes in his book "Woodcraft" (1920) about this very thing "I have known several men who have cut their heads splitting wood under a clothesline" same applies to low branches. I believe this is also mentioned in the older boy scout handbooks.  Knowledge and awareness of the hazards is the first step towards ppe.
wood splitting
Started by saltydog on Forestry and Logging
Last post October 12, 2010, 07:36:54 AM
by RSteiner
wood splitting
Started by Button on General Board
Last post April 11, 2009, 07:00:36 AM
by Ironmower
Splitting wood can be fun??
Started by DR_Buck on Firewood and Wood Heating
Last post December 01, 2014, 09:58:50 PM
by DR_Buck
wood cracking & splitting
Started by Dr. Jerry K. on Drying and Processing
Last post May 08, 2004, 11:48:47 AM
by old3dogg
