Author Topic: What’s the best fence post material from this selection  (Read 510 times)
Online HemlockKing
I have, tamarack, black red and white spruce, white pine, red maple, red oak and aspen. Are any of those fence post worthy? I want to log fence. I’m thinking probably the tamarack?
Offline SwampDonkey
  • Forester
  • Large Tooth
Re: What’s the best fence post material from this selection
« Reply #1 on: June 18, 2021, 04:25:20 PM »
Tamarack. You haven't much for cedar in NS do you? Some along the Fundy and Halifax area. Too bad to, cedar will last 40 years. The slow grown kind.
“No amount of belief makes something a fact.” James Randi
Online HemlockKing
« Reply #2 on: June 18, 2021, 06:18:10 PM »
None around my parts SD. Love cedar too
Offline barbender
« Reply #3 on: June 18, 2021, 08:28:33 PM »
Tamarack would be the "least bad" choice, IMO. It is one of those woods that does pretty good for rot resistance if it isn't in ground contact. Once it touches the ground, not so good. Cedar is about the only post that will last that we have in northern climes.
Online Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: June 18, 2021, 08:57:28 PM »
None of those listed are "really good" fence post material.
If you have any available up there, get some Black Locust, it's what the Amish refer to as the permanent fence post!
Other than that, of the ones you listed I "think" the Tamarack would last the longest!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Online HemlockKing
« Reply #5 on: June 19, 2021, 04:34:46 AM »
What’s listed is the only species available to me unfortunate
Online HemlockKing
« Reply #6 on: June 19, 2021, 04:36:50 AM »
I’m not about to pay for wood from a yard, or ever again, this recent climb pushed me to it, so what’s on my land is what I got, maybe I can do certain things to make them more rot resistant
Offline Ed_K
  • Leave it better than you found it. Ed_K
« Reply #7 on: June 19, 2021, 07:23:18 AM »
 Would rapping the below ground part with a plastic bag and somehow taping the top of the bag to keep wet out work??
Ed K
Offline farmfromkansas
« Reply #8 on: June 19, 2021, 02:29:38 PM »
Sounds like you guys need to buy a semi load of hedge posts.  I have a neighbor who might be willing to oblige you.  They do cut quite a few hedge posts. Don't think they have any available right now, and hedge posts are not the straightest.  The crooked ones last the longest, they took the most time to grow.  Hedge posts last a long time in Kansas, I have taken out a few skinny posts that were in the fence when my dad bought the farm 70 years ago.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #9 on: June 19, 2021, 04:46:34 PM »
Different climates will effect the life of a post. The dryer and colder the climate, the longer it will stand. :)
Online HemlockKing
« Reply #10 on: June 19, 2021, 04:53:13 PM »
It doesn’t need much integrity it’s more ornamental I suppose, or to keep people from driving into my seedlings.
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #11 on: June 19, 2021, 04:59:26 PM »
You should be able to get 10 years out of it and by then spruce will be 8-12 feet high.
Online HemlockKing
« Reply #12 on: June 19, 2021, 05:02:13 PM »
Yeah you’re probably right. I’m going to treat the bottoms with sealant and see if I can’t come up with something else.
Offline mike_belben
  • Pulp Friction
« Reply #13 on: June 19, 2021, 07:23:29 PM »
Red maple is horrible about rotting out.  4 yrs to dust if the bark stays on.
Red oak is pretty bad too but might go up to 2x as long as red maple IF the sapwood is removed and the heartwood is treated.. Thats by observing it in tree house application out of the dirt but unpreserved and open to rain.
Isaiah 63:10
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #14 on: June 20, 2021, 03:28:11 AM »
I have a nice little grove of straight up white cedar on my land where I go for posts. All kinds of fence post sized trees, I just thin through them when cutting for posts. Like going to my own wooden post depot. :D I can actually buy them pretty cheap locally, all debarked and sharpened, $3 a post, at Chester Grant's. ;)  And cedar bark don't slip easy in the spring, best to let them dry some and the bark will pretty much fall right off. ;D
Offline John Mc
« Reply #15 on: June 20, 2021, 02:52:06 PM »
I coated the underground portion of some posts with roofing tar. I did the whole underground portion and up to a few inches about ground level. (My posts were sunk about 4'+ deep). They were Hemlock, which has some rot resistance to begin with, and a pressure treated post that was rated for "above ground" use (All I had available). I coated them and stuck them in the ground about 10 or 12 years ago, and they still seem fine. I dug down a few inches around one a couple of years ago, and it was still solid.
I've since been told I could probably have gotten away with just coating the bottom and up the sides a few inches (to keep the end grain from soaking up water, plus the area from a few inches above ground to about a foot below ground (the "bio-active" layer of the soil). I've not tried that, however.
Offline Gary Davis
« Reply #16 on: June 20, 2021, 07:53:19 PM »
I have use copper naphthenate to
Chimney material selection?
Started by Old Greenhorn on Firewood and Wood Heating
Last post August 03, 2020, 07:03:30 AM
by Old Greenhorn
Fence material
Started by stumpy on General Board
Last post June 24, 2007, 11:22:48 AM
by beenthere
question
Silt fence material
Started by Kevin_H. on General Board
Last post November 06, 2003, 02:32:37 PM
by Kevin_H.
Fence post removal
Started by bedway on General Board
Last post July 23, 2012, 07:11:03 AM
by gspren
