Cattle Rub vs Ear Tags.
Started by LeeB, June 24, 2021, 07:28:41 PM
LeeB
The flies are horrible this year. I've used ear tags in the past but not recently. Just wondering if a rub sock would be more effective. The face flies are bad too this year so thought may a rub with face flaps might be good. Any opinions on which would be a better option? I don't have a whole lot of cattle and have sprayed them with permethrins a couple of times already this year but it doesn't seem to make much difference.
YellowHammer
Good ear tags work, in both ears, but get them from the COOP if you can, they will know which formulations are the most effective for this year.  When a cow has them in both ears, and they are near the tips, the cow will flick their ears and the tags will reach their face.  They will knock put the face and horn flies pretty well.  The flies get immune to some of the insecticides, yearly, so basic brand ear tags from tractor supply were pretty worthless, year after year, at least from what happened to us.
A sock rub works OK but I had much better success with a good cattle spray mixed heavy with diesel.  I use a standard garden pump sprayer, and literally hosed the cows down every couple days, dripping wet, when we brought them up for feeding.  (We sold our cattle last year and haven't restocked this year).  When their heads are down in the trough, hose them down, but avoid their faces.
Spray every cow plop you can find, especially in your feeding area.  The flies hatch from them, so spray them as you walk by.
One year the flies were so bad, we bought fly parasites, and sprinkled them into the cow plops.  The little buggers hatch, and seek out fly larvae and kill them.  They were pretty effective, but we eventually quit, and just went to ear tags and lots of spray.
Remember that the flies hatch from the manure, so the ones you kill today will be replaced next week.  Just keep at it.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
mike_belben
This was a good document i came across while researching the active ingredients in all sorts of product to put on my boots and pants for summer in the deer woods.
The Cow-Calf Manager: Fly Control to Keep the Flies From Winning
Ive been stocking up on "mosquito halt" at my local co-op for $7/gallon.. Its outrageously expensive online.  Works great on me and the dogs. More than just permethrin.
Praise The Lord
Southside
Well the way I see it spraying insecticide onto manure pies is a great way to create resistant parasites. Just the same way we now have Roundup resistance in many plants.
When you attack the problem bugs with poison you also attack the good ones, those are the ones that eat the problem bugs.  Be that dung beetles or cow birds. Eventually all you have are super resistant bad bugs.
Try mineral oil instead of diesel as a carrying agent. Very effective and a whole lot less toxic.
Nebraska
Dragging your pasture to break up the manure piles is probably  a better process  than  spraying patties. That being said most folks don't have that kind of pasture where it's an option.  Yes flytags can help, different  ones work better in different places.  So visit with local large animal folks (retailers, veterinarians  etc) about what is working.... also  don't forget ag extension agents.  I have a mildly adversarial view of fly tags in my area. Our worst fly season is late summer,  we put most of our fly tags in during late spring. Most of the goody is gone by the time we need them the most. Consider that issue. Also most cows don't really like getting them restraint can be an issue.. Face wipes  are pretty effective if you can find an insectide  that works in your area and your cows figure them out.. Yes mineral oil is probably  a better diluent than diesel.  Just my two cents..
mike_belben
Nebraska is too humble to come out and say that hes a doctor of veterinary medicine.. If im getting the title right.
Praise The Lord
YellowHammer
I never tried mineral oil, I assume it would repel flies, also.  Kind of expensive though, but I'm recently out of the cattle business so I'll defer to the professionals and the people still active in it.
All the guys around here use diesel, there's not too many flies that will to land on a diesel smelling cow, pesticide or no pesticide, and it's rain resistant.  The cows certainly didn't mind getting sprayed, they would just stand there with a smile on their faces as the flies lifted off and disappeared.
Without a doubt, the best way get rid of the flies is to get rid of the cows.  We raised registered Angus for a couple decades, but got out because input costs were higher than our gross profit.  It was a shame, we enjoyed it, but between the hay, fertilizer, feed, etc, we were losing money.  The only thing we have left now is 3-1/2 miles of fence line and a couple donkeys.  No more flies.  The pastures never looked so lush.
I don't see how the pros do it, the margins are so thin.  We made more in one month with a sawmill than in a year with cattle, and I don't even have to castrate the mill.  I got pretty good at roping, but it's hard to drive a 4 wheeler and swing a rope at the same time.
We finally closed up shop when Bugger, our bull, decided to tear down a steel gate and joust with our Porta Potti.  Fortunately, the customer who was in it at the time came out fast when he heard the screams from onlookers, him running like a rodeo clown, pants down around his ankles.  It was scary and hilarious at the same time.
YellowHammerisms:
Southside
The only way the little guy makes money in cattle is the same way the little guy makes money with a sawmill.  Manage every aspect, produce something nobody else does, have better quality that anyone else, eliminate input costs every place possible, and make every penny work for you until it earned a dollar, then recycle it.
In the same way you keep your walnut losses minimized - buying the right logs, not allowing too much over cut, knowing exactly what the kiln is doing, I manage the soil microbes in my pastures and hay ground, which give me grass that I feed to the herd.  This time of year I spend 30 minutes each evening walking behind the daily paddock moves with a shovel and whacking and carrying out any bull thistle that shows up.  It actually does not feel like work standing there looking over the temporary fence watching all the little ones playing as a bunny or wood chuck shuffles by, it's my decompression time from the day no matter what happened I walk away feeling better.
LeeB
I'm certainly not in it commercially. Kinda hard to do that with only 12 head. I enjoy them. They are more like pets that keep the freezer full. Even though they are for feeding me, I still want to take care of them and practice good husbandry.
brianJ
Permethrin is a contact killer with no residual activity so spray in the evening and more flies be bugging the cows by morning.
mike_belben
Im not disagreeing because i dont know, but if there is no residual activity how can  it last in fabric for several washings?
Praise The Lord
mike_belben
And a question.. Is anyone here a commercial swine producer?
Praise The Lord
LeeB
Quote from: brianJ on June 25, 2021, 08:14:35 AMPermethrin is a contact killer with no residual activity so spray in the evening and more flies be bugging the cows by morning.
I believe it has residual killing power, just no deterrent powers. Won't prevent new ones from coming but will kill them when they do.
Southside
@Wudman had a commercial hog operation in the past.
LeeB
Bought a rub pillow today. I'll see how that works out.
farmfromkansas
I get IGR mineral from the Coop, have to get a prescription to buy it, but it treats the manure to keep flies from reproducing, also has the right amount of antibiotic to protect the cows from antiplasmosis.  That disease showed up a few years ago, so now we have to feed this expensive mineral to protect our cows.  70 cows in my pastures.
zippski
Surprisingly, throughout the 80's and early 90's I was a 100 sow farrow-to-finish operator, which nicely complemented the 2500 acre cash crop operation.
How can I help?
Leigh
zippski
Leigh
zippski
Nebraska
I like  the rub option, trick is getting them to use it and the right mix of fly stuff.
LeeB
I think getting them to use it will be easy enough. They love their grain and have to go through a gate to get it.  :D
Nebraska
Good the right bait always helps. :)
Wudman
Quote from: zippski on June 25, 2021, 06:28:22 PM
How can I help?
Leigh
zippski
Ten years prior to that we were a 300 sow farrow-to-finish operation that went broke trying to feed them (total crop failures in back to back years in '79 and '80).  Of course the fact that hogs dropped to about $.13 at the same time didn't help the situation much.   :-\
Everything around here is grown on contract now (for Smithfield Foods).  I know a few folks that made a decent living doing it over the last 25 years.  As for me, the only hog I want to see is right beside me eggs in the morning........and I do like bacon. ;D
Wud
Charlie Daniels
mike_belben
Well im surprised it took 2 pages to get to food on a beef thread but i dont want to fully derail it so i made a thread to ask some piggy questions.
https://forestryforum.com/board/index.php?topic=115780.new#new
Praise The Lord
chevytaHOE5674
We used to use a IGR mineral but found after years of use we had no worms, grubs, dung beetles, etc. A manure patty would persist in the field untouched for 2 or more years as there was no bug action to break them down.
Now we fly tag (using alternating active ingredients every year), we also pour on with a product like Ultra Boss, or Ultra Saber. Fly control is as good as one could ask for, and we have worms and grubs that break down manure patties in short order. A cow pie doesn't last more that a few weeks now.
mike_belben
Quote from: LeeB on June 25, 2021, 03:19:13 PM
how did the rub work out?
greg judy, who does not put anything in his cows that i know of, and uses birdhouses to try controlling flies, has a video about pouring on some sort of parasitic moth larvae into the cow pies. i guess they eat the fly larvae and dont bother the cow.  havent seen a followup vid but did not go looking either.
would chickens being grazed behind cows help consume fly larvae from the plops or no?  i figure they may scratch and spread the manure further into the soil and faster than by rain action alone.  anyone with experience?
by the way, for incessant flies that get inside my home from kids with the door wide open, the most convenient killer is all surface windex, yellow liquid.. the one with L-Lactic acid for an active ingredient.  one good stationary direct hit will kill them in 7...6...5... but a flyby dusting shot will usually knock the unswattable off trajectory long enough for a 2nd good spritz.  best part is its not some poison.. its literally house cleaner so you can be blasting all over with reckless abandon then just wipe up and kill 2 birds with one stone.
i also use orange antibacterial palmolive in my laundry.. L-Lactic acid in that too and it kills any musty stink from boys soaking wet swim stuff hiding in the bottom of a basket for 2 days.  blue dawn ultra is the best grease removing laundry soap and manly shower scrub ever invented, and dawn makes an antibacterial orange version like palmolive but it does not use Lactic acid and does not kill the musty stink of wet clothes.   i should be buying dawn by the pail.  tire bead lube, mosquito larvae killer...
Praise The Lord
LeeB
I can't say the rub isn't working but it doesn't seem to help much. I am still having to spray them every 5-7 days.
