Poor man's "setworks"
Started by alecs, May 15, 2022, 09:59:43 AM
alecs
I'm new to running my mill (Woodland HM130), and I don't really trust my eye yet on looking at the log scale.  So I have been measuring cuts with a tape measure before cutting to see that I am getting consistent boards.  That has had the predictable result of getting sap all over my tape measure (cutting pine).  So I came up with these little guides.  I laser cut some acrylic pieces, with a different piece for each board thickness, the idea being to put the long end on top of the cant and line up the blade with the stub end to determine the blade height when running each cut.
Thoughts?
I'll try and get a couple of photos of them in use once I try them out.  In the meantime, working on designing a tag axle for bringing long logs out of the woods.
Crusarius
Thats a pretty sweet idea. I am starting to lose my touch identifying steel thicknesses from across the shop. I may need to make some of those for steel thickness.
btulloh
I find gauge is very helpful also. Making consistent Lumber is a good thing to do. I also made up a chart that shows how many clicks or holes it takes to make a certain thickness. You'll probably want gauges for both hardwood and softwood scales also.
I saw a lot of pine for framing and I have a chart and gauges that help me to cut pine slightly oversize so that it dries and shrink to match store-bought thicknesses.  For instance to get a 2 x 4 that matches store-bought I'll cut pine 1 9/16 thick by 3 5/8 wide. Even allowing for differences in shrinkage because of tangential versus lateral shrinkage and the way it varies as your Cutthrough account they still come out pretty consistent and can be mixed in with store-bought when necessary.
Anything that helps make more consistent Lumber is a good thing.
HM126
Hilltop366
The inconsistency in using your eye on a scale can be overcome, a great idea that I had seen here on the Forestry Forum was to have two pointers or lines stacked so you had to line up the pointers with your eye while you read the scale.
This eliminates the errors by having your eye at the same level every time in order to get the pointers lined up.
moodnacreek
So that's how you set , by eye. It can be done, is done and I used to do it also but it is not what you really want. Something mechanical like a screw with a hand crank [ one turn to the inch kerf included] or rachet or pin stop or detent any thing so youdon't have to look at the scale.
Ljohnsaw
Quote from: Hilltop366 on May 15, 2022, 01:51:22 PMThis eliminates
That's called a parallax error.  The best way to overcome that (short of counting/mechanical - but that can have errors as well) is to use a laser line.  Like this:
 The red line is actually sharper and thinner then the picture shows.
fluidpowerpro
Similar concept to ones I have made using thin aluminum strips. I drill a series holes in them to correspond to board thickness plus a bit for kerf and drying. The mark on the wood is made with a sharp tipped sharpie through the hole.
 You can use them starting from the top or bottom edge of the can't.
Change is hard....
chet
This may be what was Hilltop366 was referring to eliminate parallax error.
I used a piece of 1/4" Plexiglass and put a permanent red line on both sides for my sight line. If you look at it straight on you see one line,  otherwise you will see two red lines.  The faint red line you see underneath is the shadow that the camera picked up.
Hilltop366
Yes, thats what I was thinking of, I was also wondering what effect the distance between the two lines has. Just holding up my fingers or two business cards to try it seems like the more distance the more accurate it would be....or it could be my imagination.
chep
I love the idea of gauges. I run a Lucas mill and the parallax stuff gives me fits on the provided scales. Anyone running a Lucas figured out how to improve the stock scales ?
DixieReb31
alecs, Do you place the gauge before every cut?
WM LT35HD, John Deere 2040, John Deere 4044 w/FEL, Grapple, forks.
chet
With the 1/4" between the two lines it is dead on. Before I put the second line on the backside, the reading I would see on the scale could very by as much as 3/8".
NOCO Jim
What about those cheap digital readouts?  Anyone have success with using one?
glad to be here
KirkD
Quote from: NOCO Jim on May 16, 2022, 09:30:29 PM
I mounted one last summer and used it a bit but need to improve my mount as I offset it to leave the stock readout in place. I like how I can zero it after a cut and then go right back to zero at the start of another cut then drop down the amount I want to. I think it will work fine when I get it on a permanent mount.
This is what I got but I am pretty sure mine is longer than 24" I will measure it later.
DRO
I also want to make it removable so I don't have to leave it out in the weather when I am ot using the mill.
Wood-mizer LT40HD-G24 Year 1989
alecs
Quote from: DixieReb31 on May 16, 2022, 01:33:47 PMalecs, Do you place the gauge before every cut?
I haven't actually had a chance to try it out yet.  Placing before every cut was my plan.
I've been taking a step back to try to get my track and bunks a little more accurate based on some cuts that I made last week.  In those cuts, I'm not quite sure how I did it, but I made more than one 2x8 that was 2" on the money on either end, but almost 2 1/4" in the middle.  But the 8" was consistent along the whole length of the board.  I'm still trying to replay in my mind what I did that would have caused this issue.  Might have been operator error, but my first thought was to check the setup of the track, bunks, saw carriage, etc. to make sure everything was aligned properly.
Quote from: NOCO Jim on May 16, 2022, 09:30:29 PMWhat about those cheap digital readouts?
This was sort of the direction I was heading in, but I was thinking about trying to do it with a different kind of sensor.  I wanted to be able to set it up to simultaneously tell how thick of a cant was left on the bunks as well as how thick of a board I was about to cut.
I might first try the parallax-eliminating indicator design and see if that gets me where I want to go.  With the design of the Woodland Mills unit, the log scale sits up pretty high, and with the unit on its trailer (vs. on cribbing on the ground) it is not possible for me to look at it straight on.
I will update the thread as I go in case there is something useful I come across.
Hilltop366
Quote from: alecs on May 17, 2022, 12:45:56 PMI made more than one 2x8 that was 2" on the money on either end, but almost 2 1/4" in the middle.
It is good to check the mill.
It is also likely that the can't bowed. Stress in the log.
Watch the log on the bunks after a cut, it can bow either lifting the ends of the log = next cut will be thin in the middle or lifting the middle = next cut will thick in the middle.
Try searching for "stress in log" or something along those lines for info.
alecs
Thanks for the reminder about the cant potentially bowing!
I made a clear acrylic pointer to replace the red metal pointer that came on the mill.  Here it is installed.  It is definitely easier to see what is going on with this one compared to the factory part.
I tried scoring the indicator line on both sides of the acrylic to see if it would make a difference, but the acrylic is only 1/8" thick and I can't really tell what line is on what side of the new pointer.  I think it would actually work OK if the acrylic was practically touching the log scale, but that might make it harder to move or remove the magnetic scale.
I think the linear DRO that NOCO Jim suggested might mount easily though.  Might give it a try.
chet
It doesn't matter what line you see. The whole idea is when you look straight on (eliminating the parallax error)  you will see only one line. A fine permanent marker high lighting your score will help also.
Ljohnsaw
Quote from: KirkD on May 17, 2022, 11:37:41 AMThis is what I got but I am pretty sure mine is longer than 24" I will measure it later. DRO
What is the rule made out of?  The listing says you can cut it to any length.  Wondering if you can substitute a metal yard stick so you can have more than 24".
Vautour
I've been looking at them and will be installing one soon,Norwood has them on some of there mill,.. Amazon  (600 mm 23.76'') in length at $75.00 + shipping.
the Gospel is WANTED by the people in 52 Countries but made illegal by their Government
Crusarius
vatour, check banggood.com you may be able to get longer for less.
KirkD
Quote from: ljohnsaw on May 17, 2022, 11:38:28 PM
It has a special printed surface they read off of. Mine is a 36" I don't see it listed on Amazon they must be out of them but if you search igaging 36" dro you will see other places to get them like eBay. The head with the digital read out is magnetic with a long cord so you can put it anywhere you want on the mill head.
alecs
Well, I got to try out my gage today, and it works well.  However, the other development is that the installation of the custom indicator that I made yesterday gets me a lot closer to dead on each time.   So I tried the gage on every cut, but with one exception, it was only to confirm the reading on the log scale and no adjustments were needed.  Thanks for all the feedback on this topic.  I appreciate it.
Hilltop366
Good to hear.
Would it be possible to put another layer or two of plastic with another line on there?
One line next to scale and the other closest to your eye.
My original Setworks croaked on my '97 LT40 Super, so I'm back to using the scales and pointer. The easiest thing you can do is make yourself a set of quarter scales. Mine are 8/4, 6/4, 5/4, and 4/4 on the factory Woodmizer scale. They account for blade kerf, so 8/4 leaves a full 2" board, 6/4 leaves 1.5" etc. You could make your, say a 4/4 scale for full 1"- start at 1", +1⅛"=2⅛+1⅛=3ΒΌ etc. Having those marks made out ahead of time saves you from doing math in your head, which invariably leads to mistakes.
