Author Topic: What Pressure to use  (Read 1807 times)
Offline Mark M
  • Wilton, ND
    • Some of My Pictures
« on: November 13, 2004, 07:15:52 PM »
DanG'd if I can remember what pressure to use for my oxy-acetylene torch. I seem to remember 5 Psi for the acetylene and 25 for oxygen, is this right? I do remember not to go above 15 for the acetylene.
I don't know enough about gas welding to know when to use oxidizing or carbonizing flames so I just need to know the basic settings so I can heat up some re-bar to make a poker for my wood stove.
Offline Buzz-sawyer
  • To see it is to saw it....
Re: What Pressure to use
« Reply #1 on: November 13, 2004, 07:27:46 PM »
5 and 10....like the store :)
    HEAR THAT BLADE SING!
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #2 on: November 13, 2004, 07:31:16 PM »
  YUP. That's what we use 5 & 10, more or less.  ::) ;D ;D  Might turn the Oxy up a little to raise the heat.
Offline DanG
« Reply #3 on: November 13, 2004, 07:33:40 PM »
Well, for once, here is something I haven't forgot. I never knew in the first place.  ;D :D   It's probably a good thing I don't have one of them things.
Offline Furby
  • Blurb....
« Reply #4 on: November 13, 2004, 08:05:23 PM »
Ok, while we are on the subject..........
Can ya all give me some tips for useing one of these things???
Need to know how to cut, and weld with one.
It's one thing grandpa never got around to giving me a full lesson on.  ::)
Offline J_T
  • Some of anything beats all of nothing Even in Dukedom Tn
« Reply #5 on: November 13, 2004, 08:23:28 PM »
I don't have the combo torch . Mine is made for cuting only.I have ran 15and 60  only use LP and oxygen have used liquid oxygen when I was in the scrap buisness. My old rig is a victor about 35 years old and still works. 8)
Jim Holloway
Offline etat
  • Member*
« Reply #6 on: November 13, 2004, 08:43:47 PM »
My numbers for cutting are close to JT's. :)   Usually between 7 and  10 for the gas and around 40  for the oxygen.  I've got BIG regulators and guages, that may make some difference.  My torch isn't a combination either, it's a long commercial type Victor, the only thing you can change on it is the cutting tips themselves.   Sometimes I use propane, and sometimes acetelene.  I've got tips for both.  If I'm cutting something real thick I'll turn up the pressure a bit. A bit more on the gas to heat er up, and a bit more on the oxygen to blow through.  You gotta learn, mostly by trial and error,  what the flame coming out of the torch is supposed to look like. Makes all the difference, along with steady hands.
I've got a old Smith torch I can change over to if I want to braze and a couple of different sized tips. I don't do welding with it..For brazeing I'd get down closer to the other numbers by turning the pressure down some. Again the flame itself is real important.
I ain't been one bit of help have I? :)
Offline Haytrader
« Reply #7 on: November 14, 2004, 04:59:52 AM »
I was taught and beleive that you would have different settings depending on what it is you are cutting.
For instance, if you are cutting mostly sheet metal, 5 and 12 to 15 but for heavier stuff like 1/2 in. thick I set her on 10 and 40. This setting works good for heating and bending also. If you are doing much heating then get a rosebud tip.
You need a completely different torch head to run propane than you do for acetylene.
Haytrader
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #8 on: November 14, 2004, 09:37:13 AM »
15 for the gas and 45 for the O2 works good for me for cutting
Online Larry
    • Copas Sawmill
« Reply #9 on: November 14, 2004, 10:27:18 AM »
My cheat sheet.  This one is from Victor.  Welding supply shops have these as a freebe lot of times.
Hope it is readable.
Offline Mark M
  • Wilton, ND
« Reply #10 on: November 14, 2004, 11:23:20 AM »
Thanks a lot everyone!
LT 40 Pressure
Started by WH_Conley on Sawmills and Milling
Last post April 15, 2010, 01:23:33 AM
by Brucer
No hyd pressure on LT 70 HDDRX
Started by justice on Sawmills and Milling
Last post July 28, 2009, 05:19:52 PM
by Bibbyman
Pressure Washer
Last post May 05, 2004, 04:08:12 PM
by SwampDonkey
540B oil pressure?
Started by PaYoungBuck on Forestry and Logging
Last post February 14, 2014, 07:53:51 PM
by Maine logger88
