LT 28 Power Feed
Started by Knute, September 05, 2011, 12:27:37 PM
Knute
My power feed stopped working Saturday. I have power to the control box, but no power getting to the motor. Checked the brushes and they are fine. What do you think I should be looking at? Mill is 1 year old and has sawn about 2500 BF. Any help will be greatly appreciated. Thanks.
Papa1stuff
Call WM ,they will walk you right through the fix!!
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Knute
Found the problem. One of the wires in the switchbox was disconected, apparently just from the vibration of the mill running. It fit quite loose, so I squeezed the clip for a tighter fit.
