problems with old growth SYP
Started by HD, September 27, 2010, 10:24:05 PM
HD
I have problems cutting old growth pine. I've got a 28" log on the mill. I get down to a 12x12x12 cant. I'm cutting 1x12 boards. I make two cuts and on the third cut my blade dives. I turn it over and make cut and get about 4' it dives. I'll change the blade. Had to go slow to finish. Out of 6 logs I had to change blade 3 times. Logs are clean. I'm running 10 degree blade.  Is this going to be the way it is with tight grain pine? Has anybody run into old timber and had problems?
Don K
Are you running a lot of soapy water or other stuff to keep pitch buildup to a minimum. Also if the blade is getting too hot you will lose tension and it will dip.
I have cut it on a LT 15 and LT 40. Issues are the same on both mills. I usually had good success though.
By the way, welcome to the forum. ;D
Don
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
HD,I would try less hook on the band drop down to 7 or even less.Jeez I wish I had some old growth SYP to have problems with.Be sure you have enough set and its even top and bottom slow the feed. Frank C.
northwoods1
I've been cutting some large 16' pine that is partially dried out, cutting 1" just like you are. I've been finding that there is a lot of stress in it, when I get it down to a 12"x12" I can only take a board or maybe two from a face and then have to take some from the opposing face. Even the straight grained pretty looking logs have a lot of stress and they will just curl right up if you take to much from one face of the cant but if you keep an eye on things and take the log down equally no problems. Just a thought maybe that is what your dealing with?
paul case
those same sap on the blade problems have plagued me when sawing fresh post oak. the real problem is when the bade is sapped up on the outside since my lube only goes on the inside.  pc
pc
HD, chances are you are sawing a butt cut and sawing from the butt end.  Compression wood is simple wood that has been mashed and buckled by the weight of the tree.  When trees are felled leaving a low stump, that bad wood ends up in the log.
Butt logs are best sawed from the small end.  Be sure that there is no pitch buildup on your blade.  I use 2oz of Cascade per gallon of water for lube and increase the flow on bad logs.  I use 10° blades, and I understand that 7° might be better, but I haven't decided to change just yet.  I saw approximately 75Mbf of SYP each year and do OK with the 10° blades.  The great majority is large old growth.  Matter of fact, that's what I sawed last week and beginning tomorrow what I'll be sawing this week.  Some 30"+ SYP logs.
Proper blade alignment is an obvious requirement.
northwoods1
Quote from: Magicman on September 28, 2010, 09:04:08 AM
Thats the good wood!! haha , I love a big old flared out bent over tree with some good compression wood when I look at it I see $$. A big limb can have some nice area of figured compression wood too.
HD
Thanks for the replies. You know it just might be the wood. It just blows my mind to get pretty cuts and then the blade dives. I'm useing half bottle of pinesol in 5 gallans of water. The blade is clean. I guess if i keep having problems i'll try changing set and degree on blade. I haven't run into this problem before. I've cheked alinment and all looks ok.
Bodger
I'd also check the blades coming off and be sure that the set has not somehow been knocked out.  I cut quite a bit of old growth pine, recycled beams, jump butted pitch trees and sinkers using 10° blades...tried the 7's and switched back.  A dash of diesel will cut that pitch on the blade.
Work's fine for killing time but it's a shaky way to make a living.
Quote from: northwoods1 on September 28, 2010, 10:04:43 AMThats the good wood!! haha , I love a big old flared out bent over tree with some good compression wood when I look at it I see $$. A big limb can have some nice area of figured compression wood too.
Yes, I understand, but you are not talking about SYP either.  Folks aren't looking for figured wood with SYP, they are looking for stability.
......  Compression wood is simple wood that has been mashed and buckled by the weight of the tree.  .........
Not exactly a good description of compression wood.  :)
Compression failure in wood is "mashed and buckled".  Trees tossed around in storms often show compression failure. Marked reduction in strength as the wood cells are crushed.
On the other hand, compression wood is abnormal wood that has developed usually on the compression side of the tree (lean side, or underside of limbs). The compression wood has wood cells with walls of high fibril angle. These slanting fibers shrink in the longitudinal direction much more that regular (normal) cells thus causing warp when the wood cells dry.
A thin cross-section of wood held over a light will show the areas that are compression wood as very dark (no light passing through) as a result of the high fibril angle.
Here is some good reading on the compression wood, and also discusses how it affects wood strength.
http://www.metriguard.com/fiber.htm
metljakt
I talked to an old sawyer about this.  He has run into the same problem.  His solution:  He adds 1/8 cup of Dawn dish soap to his lube, and then sprays WD-40 on the blade about every other cut.
kelLOGg
Quote from: paul case on September 28, 2010, 08:36:18 AM
I have run into sap buildup on the non-lubed side of the band when sawing old pine beams. I added additional diesel wipes top & bottom and on both sides of the cut. It keeps the blade very clean.
ladylake
I'd try blades with more set first.   Steve
HD
OK, My blades are clean on both sides so I don't think it's a lube problem. I guess i'll stick with the 10 degree...
Ladylake, how much more set?
terrifictimbersllc
What's happening with the tension when the bad cuts start?
Nate Surveyor
Thanks for the info about SYP. I have a few butt cuts, that have given me trouble....
This just fits.
Nate
I know less than I used to.
Thanks beenthere for a more descriptive definition of "compression wood".  Yes, a tree is very heavy and the effects of that weight does strange things, especially with SYP.  (I didn't find a definition in the FF dictionary.)
I was questioned in a PM concerning sawing from the "little" end.
My absolute preference is small end first, on everything.  With big logs though, you have to carry the head to the far end, lower it to the sawing height, and then back up to log to be sure that the head will clear the log.
Logs are easier to set up because you are raising the toe board closest to you.  Less walking.
When sawing knotty logs, the blade doesn't tend to follow the limb and raise up.  You are sawing into the crotch.  Much less tendency for "knot wave".
You can only saw as much lumber as the small end will yield, so it's much easier to determine where to make your opening face when you are looking at it.
When sawing butt cuts with the potential for having compression wood, you have sawed through "good" wood and your blade is on track before it hits the compression.  You may loose 6" or so, but at least your blade doesn't have to climb out or adjust itself in good wood.
I'm sure that other sawyers will have their own preferences, or add items that I didn't think about.  There are just sooo many variables when setting up and sawing logs.  Each log is really and individual unto itself.
pineywoods
My experience and preferences mostly match what magic said in the previous post. Last week I sawed about a dozen good sized syp logs that added some new experiences. most were 14 to 20 inches on the small end, nice straight logs will little taper. Some butt cuts, some second cuts, all 12 ft long. I've cut a lot of syp over the last 10 years, but I have never seen any log of any species that wiggled and moved as much as these did. Some of the cants visibly twisted, just about every board warped like crazy as soon as it was cut loose from the cant. The logs all came from trees that had been completely ripped out of the ground by a tornado. That may not have had anything to do with it, but they were about like trying to saw a wet noodle.
An interesting thing about how trees grow is the effect of the growth hormone auxin.  Auxin stimulates cell growth and is produced in the crown of the tree in the growing buds.  The auxin moves down the stem via the inner bark (phloem) and is distributed evenly around the bole of the tree.  This auxin stimulates cambium growth during the growing season when the active buds are producing auxin.  Light breaks down auxin over time, however, and if the tree is bent over from vertical, the auxin that accumulates on the underside of the lean is more protected from light and the higher concentration of auxin stimulates the cells in the cambium on the underside to grow faster than the cambium cells on the upper side of the lean.  As Beenthere points out, these cells that are stimulated to grow have different make-up than normal cells in that the microfibril angle of the cellulose molecules that make up the cell walls is different and the cell walls contain more lignin (the glue that sort of fills in around the cellulose chains to form the solid cell wall).  The effect of the faster growth on the underside of the lean (the bottom is growing faster than the top due to the effect of the higher auxin concentration on the bottom) actually straightens the tree back up to the vertical over time leaving a curve that we call sweep.  A log with sweep always has compression wood on one side.  When the vertical point is again reached, light affects the auxin the same all the way around the bole again, and even growth occurs from that point and on up the straightened point of the the stem.
That is way more information than anyone wants or needs.  Suffice it to say that a tree that is bent over will try to straighten back up in response to light  :).  Whew, I got that out of my system ::).  And if any of y'all understand all that, then you must be a little weird too :-\.
HD
Well, i didn't have problems cutting until I got to the center of the logs. My problem isn't boards twisting after a cut, its just moving along fine and then the blade dives. I can change blade and its fine until I start the next log cant.
Magicman, my logs are set up both small and butt ends on ground. I don't have a way to move them now that there next to the mill.
Correct me if I'm wrong, Softwoods more set,Hardwoods less set. Is this right YEE SEASONED SAWYERS???
DouginUtah
gymnosperms -> softwoods -> compression wood on lower side
angiosperms -> hardwoods -> tension wood on upper side
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
One other item about sawing logs with sweep.  Orientate the log so that after the faces are opened, you are sawing the cant from either the horn or hump side.  That way, you eliminate the heavy crowning that you will experience if you saw it from the side.  You probably will still have to flip the cant as boards are removed and stress is relieved.
Twisted trees/logs are going to give you misery anyway.  Beetle killed logs that have dried somewhat seem to move less than fresh cut SYP.  I'll be back to sawing beetle killed logs tomorrow.
ladylake
Yes more set for softwood maybe aroud 28 thousands, the dryer the log the worse it is.   Steve
Here is a prime example of sawing a butt log with sweep.  I prefer to lay them on the side with the "horns" toward the clamp for the first face opening.
Notice that the pith is not centered in the log on the butt end.
For the second face opening, I rotate 90° and saw the horns off.
The log is then rotated and the other side face is opened.  The last 90° rotation has the hump up.  I then saw through.
Notice that the cant has raised up off of the saw deck as boards were removed.  I should have rotated this one sooner.   :-\  It must now be rotated 180° and boards removed from the other side of the cant.  The old folks called this "suck butt".   :D
Here is an example of the band following the stresses of compression wood in the butt.
I would prefer that the log not be cut so low to the ground.  Leave this junk on the stump.
