Whatcha Sawin' 2021 ??
Started by Magicman, December 31, 2020, 10:05:41 AM
Peter Drouin
You guys with flat roofs :D ;) Up here in NH the thing would be on the ground on the first storm.
A&P saw Mill LLC.
License NH softwood grader.
Peter Drouin
Fun this last week 10 ° cutting frozen Hemlock logs hard as a rock. The T7s did ok but, Dull faster. If you don't take the lumber off fast enuff the thing will freeze to the cant. 8)
A&P saw Mill LLC.
randy d
I know what your talking about we were sawing pine 2x4 and they froze down to the cant real fast and its fun scarping off saw dust to. we use windshield washer fluid but it still freezes to the 2x4.  Randy
SawyerTed
Quote from: Peter Drouin on January 24, 2021, 09:57:49 AM
Yes "flat" is relative.  The photo makes it look flatter than it is.  The roof has about 20" of fall in 14'.  We rarely get more than 6" of snow and none of it stays more than 2 or 3 days.  While this lean-to will hold up to our snow loads, it wouldn't where snow and ice accumulates over several weather events. There are hundreds of sheds like this built on tobacco barns just in Stokes County.
Resonator
If it gets cold enough and the sawdust freezes thick, I scrape it off in sheets. ;D
Bruno of NH
You are right Peter
I used alot of blades this last week frozen logs add to the winter fun.
busenitzcww
br>
Finally got back to the mill this year! Some 6/4 walnut and some pin oak slabs.
doc henderson
great stuff... from Kansas!     8)  8)  8)
Walnut Beast
kelLOGg
A neighbor called me today to ask if I could saw cookies from spalted maple her husband got for firewood. I told her "yes" and I could do it now. As she approached me and my wife, I told my wife that I was going to bake saw some cookies for her. Two hours later I had this pic in my email. I'm still laughing.
(There is an electrical issue with the head feed so I had to push. That's my task for tomorrow)
longtime lurker
Not sawing last week - but finished lifting one of my sheds that came off second best in a Category 5 cyclone.
It's been a work in progress for a long time - as time and money permitted. It spent 6 years down in "sydney opera house" style with some pallets to stop it collapsing further.... which was really good in terms of self washing floors every time it rained but not good for much else.
I had every builder in like 100 mile here buying lumber at some point or other and looked at it and none of them knew where to start so it was either knock it down or do it ourselves. Now I'm not a builder.... but pallets, forklifts, dogs and chains and ratchet straps : I got general freighters covered.
New posts in
I can now say that officially - it's nearly twice as strong as the original design. We do not wish to do this again in a hurry.
*No OH&S guys were consulted in the making of this post :D
tule peak timber
Awesome,,,,,,You are making me smile with your engineering solutions.We have the Disney concert hall here in Los Angeles with a twisted roof like yours. Keep up the good work ! Cheers WOC
Patrick NC
Got a load of cedar today. Some are kinda small, but it's all worth sawing. Good thing is I've got an order for 4x4s.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
donbj
Quote from: longtime lurker on January 25, 2021, 08:18:06 AM
New posts in
Nice job! Thoughtful patient approach get's it done! Now a big sale on pallets coming up.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
WV Sawmiller
   We were setting up a big circus style tent for employee billeting in Baghram Afghaniland and had a heavy snowfall that did the same thing to it. The only thing that kept it up was we had started staging the furniture and had a long row of 6' tall wardrobes along the outer walls on both sides and they held it up. Once occupied and the heat was on in the tents the snow would just melt off as quickly as it would fall. A contractor convinced the USAF foam insulation would be a great addition so they foamed a bunch about 2" thick. They ruined a bunch of A/Cs because they did not seal the vent fans and they got clogged and the next time it snowed the well insulated tents collapsed under the weight because it could not melt as per our original design. We finally had to tear all the foam off and ship it off the base because it was hazardous waste that we could not bury or burn.
Bruno of NH
Got in some new bands to add to the supply
Silvertips 7/39 × .055 I have lots of big logs coming up with wide cuts.
Larry
Finding good help anymore is really hard.  This one is on the small side but he has a big heart and doesn't eat much! :D
Got about 2,000 foot of yard tree walnut to work through than 1,000 board foot of really nice cherry logs.  Couple of the big walnut logs get live edge slabbed but the rest is all grade sawing.
Walnut Beast
Good looking help but I think Magicman might beg to differ from some of his past help 😂
WV Sawmiller
    Yeah but Miz pat might vote for the pooch. :D
terrifictimbersllc
He's wondering why there's no log on the mill.  :D
Raym
After my portable sawing job last week, I am going to try and figure out how to do more of these.
One problem I have is keeping the lubemizer jets clean. They seem to always get clogged and isn't an issue when I'm sawing here because I just take them out and blow them out with compressed air.
Wasn't an option at customers site so I removed the jets and drilled them out to 5/64 (smallest bit I had). Will see how that does.
'14-LT40 super, nyle l200m kiln, vintage case 480E loader.
It's not the fool that askith, it's the fool that agreeith.
DWyatt
Quote from: DWyatt on January 18, 2021, 09:01:44 AM
Fun weekend with Dad sawing some 2 1/2" beech slabs from some large "logs" for a customer and 3 poplar logs into 1x material for us. I didn't do a final tally of the poplar, but they made a lot of lumber. 2 of the logs could have been veneer quality and one was just a normal lumber log. Note the chunk of Beech that didn't get sawed in the background of the poplar picture ::) He said they were logs ::) I said hourly rate. The one poplar was the biggest log I have had on the mill and it was a pain in the butt. 12' long 28" small end and 38" large end, but it made some purdy lumber. I have 4 more poplar logs to pick up next weekend, having a neighbor who's a logger is convenient.
A little late, but Dad just sent me a picture of the huge poplar log loaded on the mill that I mentioned in my previous post. This is the biggest log I've milled to date, I don't wish to repeat it soon :D Except I have 2 @8' long that are this big that still need milled
Bruno of NH
My debarker swing motor shaft came in last night.
Got it put in the motor this afternoon. Just need to put things back together at the mill.
Thanks @Marty Parsons
DPatton
 :) I got a new circular saw blade in today :)
  ;D But it's not your standard issue 7 1/4" circular saw blade ;D.
It's a little bigger. :D :D
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
