Author Topic: Whatcha Sawin' 2021 ??  (Read 111796 times)
Offline Patrick NC
  • I'm not new anymore, but still pretty green
Re: Whatcha Sawin' 2021 ??
« Reply #580 on: April 18, 2021, 08:29:55 PM »
Started multiple weekend mobile job yesterday. Customer had a lot cleared to build his retirement home and wants to saw the logs into framing lumber. Mostly tulip poplar, a little maple, and some white oak. He is 67 years old and not in the best shape, so he paid extra for me to provide labor and a tractor. Most of his logs were not bucked to length and covered in mud. Spent a lot of time cleaning logs. Worked 17 hours the last 2 days and got 3100 bf. 2x6s,8s, and 10s. Mostly 14' long. Also a bunch of 1x random width. Total mill time was 11 hours.
 There was one short beech log that he wanted cut at the end of the day today.
it sawed easy, but moved around like a snake. Had some nice figure in it though.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Offline Bindian
  • Gender: Female
« Reply #581 on: April 18, 2021, 08:40:00 PM »
Been cutting bunches of 2x6s and 2x4s, from 8 feet up to 16 feet.
  Having fun in retirement.
Almost have two customers lumber ready for pickup this week.
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel. An old Lull 644D-34 called Bull
My Hero is Johnny Jett
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #582 on: April 18, 2021, 08:45:53 PM »
2 miles from my house, five miles from the mill.
Logs 13 miles from home. Mill 30 miles. 52' 12x12.
Dave,
       I am confused.   I thought extended length Woodmizers couldn't be moved.  But it looks like you are towing your mill from place to place.  Please straighten me out.
               hugs,  Brandi
Two different setups. One is my mill and extension cutging 47'. The other is a different mill with my 24' and another 12' extension cutting 52', with 57' total capacity. Every move is a break down and reassembly.
Offline Bindian
  • Gender: Female
« Reply #583 on: April 18, 2021, 08:49:41 PM »
Dave,
               hugs,  Brandi
How long does it take to break it down and to set it up?
          hugs,  Brandi
    • My homepage
« Reply #584 on: April 18, 2021, 09:21:55 PM »
You could split the extension and have the axle back under the mill in a couple hours. It has stationary legs that have to come off. Setting up on a new slab, aligning, and drilling new anchors is probably an all day affair. I spent three hours today realigning and setting more anchors and then checking bed to band alignment. People ask me if I have a portable mill. Only if you can move a 60' long, 25 ton slab without breaking it.
Offline Walnut Beast
    • My homepage
« Reply #586 on: April 19, 2021, 03:52:40 PM »
I'll be sawing four 8x8s out of one log later today. It'll be ewp, so it'll actually work.  :)
As promised. 4-8x8. Flat and square as can be. Could have made 4-10x10, with a little wane.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #587 on: April 19, 2021, 07:11:18 PM »
Nice work Dave, and thanks for the photos of the long sticks.
So, with @bindian at 27x 2x4's and you at 4x 8x8's - there's whole lotta squeezing the log for the most bf.
Who's the winner?  :D
LT40G25
Ford 545D loader
Stihl chainsaws
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #588 on: April 19, 2021, 08:25:58 PM »
 I threw this muddy ash log I salvaged while cutting some next years firewood about 60 yards from the house. looked to solid to waste on firewood. I cut 3- 1X10's to finish a customers order and the rest into 1X1 strips I will cut in half for 2 tomato stakes out of each. I started with a used blade and the extra mud sent it diving after 2'. I replaced the blade and it worked fine.
 Sawed a second similar log into tomato stakes. Note my new process I picked up from Rich to load the slabs/edgings on the tractor forks and the lumber on sawhorse to be picked up later. I am liking this and think it will be my new standard practice. I am finding it is much easier to turn around and put the slab on the forks and slide the lumber off on the sawhorses then haul the slabs away when I get done or get a load and come back and pick up the lumber.
 After I moved the boards I still have about 120 sticks or 240 future tomato stakes.
   When I finished I had 849.8 hours on the mill so did my 850 hour service. Before I started sawing I checked on the belt smell I got yesterday. Turned out the alternator belt was loose and had twisted. I put it back and tightened and called WM Pa and they added a replacement to a box of bands I'd ordered this morning. Should all be here tomorrow.
   I called the customer to let him know his order was ready. I had forgotten he wanted 8' and turns out he can't store the 10' so I'll throw them on the RAS and trim even the excess I usually leave. Won't take but a couple minutes to do that.
WM LT35HDG25(2015) , 2009 4wd Dodge PU, Kawasaki 650 ATV, Stihl 440 Chainsaw, homemade logging arch (w/custom built rear log dolly), JD 750 w/4' wide Bushhog brand FEL
Offline Bindian
  • Gender: Female
« Reply #589 on: April 19, 2021, 10:42:08 PM »
Heck,
       If I had known it was a contest, I would have put that 38 inch log on the mill.  After bibbying with my new 461 Stihl.
                       hugs,  Brandi
Offline doc henderson
« Reply #590 on: April 19, 2021, 11:02:54 PM »
put a walnut log on the mill.  right at 36 inch diameter.  @Cardiodoc and I got this a few weeks ago with his daughter.
quite a few 2 inch slabs.  some crotch figure near on end of the wood.  did well despite a big rot pocket and a couple nails
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #591 on: April 20, 2021, 05:28:49 AM »
Doesnt look like that blade was any worse for the metal.
« Reply #592 on: April 20, 2021, 08:04:24 AM »
i agree.  sawed flat and not much change in set.  so we finished the log and made another 5 slabs after.  it will be changed before the next log, unless it is dirty then I may chance opening the cant with this blade then a new one for the boards.
« Reply #593 on: April 21, 2021, 08:01:31 PM »
   I'm beginning to feel like I should apply for a MM award for traveling. I tentatively confirmed a job in Charleston WV, 89 miles from here, Saturday morning for a repeat customer up there. It looks like it is only 4-5 logs and they are in the 5' range. I think the biggest is 24" although he may have a 36" log he is talking about splitting with a chainsaw before I get there. It will obviously be a minimum fee applied job. Now I just got an e-mail from a guy 112 miles from here wanting me to come do about a one day job at a campground they are opening for Memorial Day weekend. He needs to build some cabins and sleeping decks/porches and such and wanted me to come saw Saturday and Sunday. I told him I can figure on leaving Charleston then go west about 90 miles to his site and camp there a night or two as needed. I'll get my mill and tent set up Saturday and if time permits we will saw a couple of hours. Then I will come back home Sunday night or Monday making a big triangle trip. This will be the first time I ever overnighted on a mobile job. My big concern now is if the weather will cooperate.
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #594 on: April 22, 2021, 08:47:46 AM »
Hey, if you want a long haul job, come on down here to Alabama and I'll get you to saw some of my logs.  I can pay you with a fishing trip or food.   :D :D  I don't have any money, I spent it all on the sawmill. :D :D
Here's some sassafras I cut yesterday.  Some nice clean boards, taking 16" off.
YellowHammerisms:
Take steps to save steps.
If it won’t roll, its not a log; it’s still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, they’re burned, and you can’t fix them.  So don’t burn the cookies.
Sawing is fun for the first couple hundred boards.
« Reply #595 on: April 22, 2021, 09:02:41 AM »
got a burr or pin oak from the tree service working down the street.  gave them a couple slabs.
« Reply #596 on: April 22, 2021, 09:48:33 AM »
YH,
   Thanks for the offer. First time I have ever been asked to "Saw for food." :D
    I found a pair of old classmates have a son there at Huntsville and he is a woodworker so I told her to tell him to come see you and ask for his 50% War Eagle discount. ;)
« Reply #597 on: April 22, 2021, 10:11:04 AM »
An Auburn discount?  Only if they wear a Crimson Tide hat.   :D :D
YellowHammerisms:
Offline Bindian
  • Gender: Female
« Reply #598 on: April 22, 2021, 11:02:23 AM »
Is that better than an Aggie hat? ;)
hugs,  Brandi
« Reply #599 on: April 22, 2021, 12:12:50 PM »
Brandi,
   If he comes in with an Aggie hat Robert probably wouldn't even sell him the sawdust. I probably would not either. :D
question
Whatcha Sawin' ???
Started by Magicman on Sawmills and Milling
Last post March 06, 2019, 08:53:50 AM
by Jeff
Whatcha NOT Sawin' ???
Started by terrifictimbersllc on Sawmills and Milling
Last post September 17, 2022, 07:23:50 AM
by jpassardi
question
Whatcha Sawin' 2022 ??
Last post December 31, 2022, 02:04:10 PM
by GAB
question
Whatcha Sawin' 2019 ???
Last post January 01, 2020, 08:02:10 AM
by Jeff
