Luke and I finished our job this afternoon, and I even remembered to take a few pictures.(Image hidden from quote, click to view.) 16' 1X12's with the framing lumber in the background.(Image hidden from quote, click to view.) Mostly 16' 2X10's. Previously sawn framing lumber in the far background on the right and also under the red roof.(Image hidden from quote, click to view.) Another view. 2X4's & 2X10's.(Image hidden from quote, click to view.) 120, 14' 2X10's in the foreground. Total yield was 6208 bf. I could saw two different jobs tomorrow, but I made an executive decision and will be off.
I'm trying to finish my shed/composting toilet project and needed a few 1/2" X 3" battens and few more 8" boards. I've been cutting my spruce boards 7/8" thick just because it is so simple to do the math on my simple set. I went up to cut one more tree and almost immediately got caught in a fawn stampede. One ran up to within 10' of me while I was on the 4 wheeler. I cut the tree and came back to the 4 wheeler and it came back again with 20'. I had left my camera in the barn below. One feature I noticed is it had what looks like a solid white long a foot long on its neck. I called my wife to see if she wanted to take pictures of them so she came out about the time I finished limbing and bucking the tree into 4- 14' logs. The smallest diameter at the top was down to about 8" since I was cutting battens. Becky finally came out and got on the 4 wheeler with me and I took her up the hill with her screaming like a banshee every time I'd roll over a rock or limb or the hill would slope 2 degrees. Her balance was never great but she has gotten worse. Sure enough at the top trail the fawn and doe popped up. They had never been 100 yards from me the whole time. Becky got a picture or two and they went back the way we had come and she decided to walk rather than ride. I found the fawn bedded down 20 yards from the stump of the tree I had cut. I saw the doe again on the access road on the way back to the house. She cut across the yard, jumped down into the creek and circled in my lot in front of the house. I had washed the mill, moved it back into the pasture and set it up for sawing. I had noticed the power feed hesitated in reverse the last time I used it and when I set it up so I pulled the cover to the belt and found it was a little loose so I tightened it and it seemed to work fine after that on the 4 small 7' logs I cut.(Image hidden from quote, click to view.)2-14' spruce logs (Image hidden from quote, click to view.)2 more, one already cut in half and the top is on the mill arms. I sawed about 155 bf of battens and boards and have plenty to finish my shed projects. All the framing is done, sides are on 2 just waiting for the roofs and I may finish all 3 tomorrow if weather and my body holds out. I do still need to finish the toilet seat/box. I'll cut the other 2 - 14' logs in half and should have enough to nearly complete another shed. I'll have to recalculate before sawing.(Image hidden from quote, click to view.)The stack on the right were previously cut the rest are from today.
Y'all leave Luke alone. Da last thang I need is fer him to git messed up with wimmen!!
Brandi, Remember, this is a family site so don't be showing pictures of you sawing in a dress with that airplane blowing in the background. That would definitely blow your skirt up!
Let me see - Blonde + Blower = Marilyn Monroe moment Now let me go check on Jeff's pole dancing. This is getting to be a real happening site.
Nice looking material Brandi very well sawn ,nice square edges no wane I don't get to see that around here unless I cut it myself, local mills leave a lot of wane.
Started by Magicman on Sawmills and Milling
Started by terrifictimbersllc on Sawmills and Milling
Started by Brad_bb on Technical Support Topics
