This is why I have a parts machine.
Started by grassfed, August 22, 2011, 10:51:04 AM
grassfed
This happened Sunday. I managed to drive it out on three wheels. I will swap axles with my parts machine and then put on the wheels and tires from this axle on. The loader on my truck managed to pick the back end up and set it on some logs...
Mike
lumberjack48
Looks like more than just a axle, not sure what its called, i think the spindle and axle are busted off. That would have been a good video of you driving out on 3 tires. I never had this happen to me, i seen a guy hid a tree with a front tire and busted it silken clean off.
Your lucky to have a parts machine, good luck with it
grassfed
I think that they call it an outer half axle. It has the wheel flange on the outside and the planetaries bolt to the inside end (deere/funk inboard planetaries). The break happened exactly at the outer edge of the outside wheel bearing and the only other part that was damaged was the seal.   Looks like it has had a crack for a while and just gave up while I was winching a hitch. Took a minute to figure out what happened.  I am just swapping the whole rear axle and difs and then changing wheels. I wanted to get it out since we had rain coming and it gets muddy there. It rode on the log bumper and just dug an inch or two deep furrow in some spots.
Mike
mad murdock
The main ???? how did it tranaspire?? Sorry to see your breakdown.  good thing you have a parts machine handy!
grassfed
It was already cracked I'm sure. The broken area had grease and corrosion on 3/4 of the diameter and then a clean white mettle fresh snap on 1/4 . I figure it has had a hair line crack as long as I have owned the skidder (I am real easy on stuff) The crack probably got worse slowly and then I just happened to have the crack in the right place this time. When the winch took a strain the weight transfer popped the crack. The cracked area was facing down and a little toward the load when it broke. The skidder was in park with the brake on and I was pulling in two fir trees.
Mike
mad murdock
I thought it was prolly a pre-existing hurt.  You just don't break a piece like that all at once, unless a big old coastal redwood was felled right across the arch maybe ;)  I hope you aren't down for too long.  Sounds like you will be back yarding wood in a few days, or less.
treefarmer87
thats not good :( im working on getting a parts skidder, loader,and truck
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Taylortractornut
Scrappers get mad when we wont sell the landfills  junk  JD scraper,   old  Macks,  or Dodge trucks.         THey say well it will bring 13 dollars a hundred.       We had  a differential carrier go out on the  main scraper and Deere   wanted 14k for a new axle.      Jut gave 1100 to had a feild man  change it out.    Pluswe have all the metal lines and such.
My overload permit starts after sunset
snowstorm
likely there is more broken parts in the housing. planatery parts. the little jd skidders werent ment to run chains on the rear. i know a lot do. bolth rear wheels are locked all the time.
Bobus2003
Been there, done that on my 440, I have also stripped the splines on the Hub once.. A parts machine was my savior also
grassfed
I don't think that any thing else broke since the machine was not moving when it happened. It just fell off when I started winching.
Mike
treefarmer87
thats wierd it happened like that ??? its a good thing it happened on level ground and your ok  :)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
forestry mick
I had the same thing happen a few years back on the 540! It was an old crack going most of the way through. Parts machines are handy to have! Good luck!
