Barn siding
Started by witterbound, November 05, 2007, 03:48:42 PM
witterbound
I've got an old sagging barn in Arkansas.  It was built as a hog barn, long after timberframing was popular, so it's stick framing.  It's roof is sagging.  So, I've spruced it up a little bit by adding a timberframe ridge beam (my first timberframe project).  Been a lot of fun.  Once I remember how to post pictures I will.  My timbers came from Arkansawyer, whom I found on this website.  Gonna make another trip to Flippin to buy some oak siding for the barn.  My question is, should I put tarpaper or tyvek between the oak board siding and the pine studs, or nothing?  Back in the old days I imagine they didn't use anything.  But should I use something to help keep the water out and make it a little more "windproof"?
witterbound
Here are some pictures of my ridge beam raising.  Well that didn't work.  I have added them to my album, but I haven't yet figured out how to add them here.  I'll keep working on it.
witterbound
OK, I give up.  Someone give me a clue on how to post my pictures from my Forestry Forum album to this board??  Thanks.
OK, maybe I've figured it out . ...
Great pics. thanks.
About the Tyvek...I think it would work well to stop the wind and outside rain, but....my memory of it when adding on and having the new room wrapped in it, was the incessant noise and flapping when the wind blew. As long as the siding ties it down well, that probably won't happen. Just a thought. That noise is prolly great when one is sailing and the sails are flapping in the breeze, but when inside the room...it was 'bout driving us crazy..  ;D   or crazier :)
Your new beam looks like it was a neat, carefully planned procedure.  :)
Jim_Rogers
Do you intend to heat this barn?
If so then you should have the vapor barrier, if not you really don't need it, unless you want to stop the wind....
Jim Rogers
ljmathias
Nice work- thanks for showing us. It's neat to see a hybrid structure like you've made out of your stick frame barn. Makes me think more of this type of combined use of timber frame with stick frame walls should be considered for some applications.
LJ
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
witterbound
Thanks Jim.  I don't intend to heat it, so I think I'll just put up the siding without tyvek or tarpaper.  Learned a lot doing this little project.  I think my next timberframe project will be to build a very small showerhouse that I can put up next spring.  If I get er done, I'll post some pictures.
LeeB
How far from Flippin are you witterbound? You one of the locals?
witterbound
Someday I hope to be.  Grew up in NWA, but moved to KC area years ago.  My barn is in Witter, which is about 15 miles south of Huntsville.
Dave Shepard
Nice job! Welcome to the forum!
Dave
TexasTimbers
I like the way you solve problems witter. :) Thanks for the pictures.
Stephen1
It looks like a lot thinking went into this project. Nice work. Thanks for the pictures.
witterbound
It was an interesting challenge to raise it inside the barn, without something like a forklift.  Thanks for everyone's comments.
