New member
Started by Contractor1, April 19, 2013, 10:44:01 PM
Contractor1
I am new to the forum but have been viewing as a guest for a few months. I just purchased a 2013 wm lt 40 hydraulic. I am just sawing for myself to build some upcoming projects on some property I purchased. I have already gained a lot of knowledge from reading the posts on the forum. Some of the things I did not learn were
1. I spend more time staring at the log or can't with the engine running than anything else.
2. A 12 foot 2x6 in wet cypress is real heavy.
3. Some logs just are not worth the effort.
I am located in Jacksonville, Florida and am the guy Nomad posted about.
Meadows Miller
Gday
And Welcome Aboard Mate  ;) ;D ;D ;D 8) 8) 8) 8) You are in good company there and we will look after you Mate  ;) ;D ;D 8)
Regards Chris
4TH Generation Timbergetter
Gasawyer
Welcome to the forum! Good luck with your mill.
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
mesquite buckeye
YellowHammer
Welcome, and congratulations.  I stare at logs, too.   :D.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
justallan1
Welcome to the forum, Contractor1.
What you don't know now, you can find out here, just ask.
Allan
wesdor
Welcome. You will be really happy with the hydraulics on that mill.
Happy sawing
Woodey
Welcome to the Forestry Forum!
WOODMIZER LT40HDD34CAT w/accuset
JLG SKYTRAK 6036 Telescopic Forklift
NYLE L200 KILN
BAKER M412 MOULDER
JustinW_NZ
Welcome, and make sure you post up some pictures of projects  :)
Cheers
Justin
Gear I run;
customsawyer
Welcome to the forum. You are in good company with Nomad.
www.thecustomsawyer.com
Nomad
     Glad to hear you got in!  I guess Jeff can ignore my request for help now.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Quote from: nomad on April 20, 2013, 05:50:39 AM
I wrote you a big long response to try and help. It should be in your messages. :)
m wood
welcome contractor1.  Are you a home builder too?...and plan to use some lumber on those projects as well?(just wonderin).  new lt40 hyd huh?  nothin like jumpin into the deep end of the pool :) :D
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Contractor1,welcome to the forum. Sawing is fun!!
dgdrls
Welcome aboard Contractor1, lots of great folks here and many of them run 40's
did you post on the thread I linked below?
best DGDrls
https://forestryforum.com/board/index.php/topic,66111.0.html
slider
welcome contractor. I know what you mean about staring at logs.I have been staring at a semi load for about 2 weeks now,I sure wish it would go away.
al glenn
Welcome Contractor,not to worry it will all come with time,start slow double check everything and enjoy yourself.All the finer points will come naturally as you gain experience.You will never look at a tree the same way.To do much you will need some good equipment,yard tractors with dinky loaders need not apply. Frank C.
clww
Welcome to the Forestry Forum. :)
Many Stihl Saws-16"-60"
18-Wheeler Driver
tgalbraith
 smiley_clapping
Welcome to the forum Contractor1. You will like it here.
I spent 20 years in Florida (Cape Coral area) before I retired,
and I don't miss the heat and hurricanes at all.
Good luck and saw on -----
M Belsaw, 46" insert blade, Oliver 88 power  plant
Welcome!
Also, go to you profile and update it to include your location.  You bought a great mill.
downsouth
Welcome to the FF. I still stare at logs on the mill,trying not to lose any BF. I lived in the Orange park area for a while and out in Middleberg. For about 3 years. It's a nice place.
Nomad
Quote from: Jeff on April 20, 2013, 06:22:57 AM
     Yeah, I worded that poorly.  I'd read Jeff's message already so he wasn't ignoring my request.  What I really meant was that his help wasn't needed in this instance. :embarassed:
Lucas DSM23-19
Chuck White
Welcome to the Forestry Forum, Contractor1.
Great place to hang out, and learn.
PC-Urban-Sawyer
Quote from: Contractor1 on April 19, 2013, 10:44:01 PM
Contractor1,
I could have tole you that!  :D
Welcome to FF. Glad to have another Floridian aboard.
Herb
millwright
Welcome to the forum, you can expect to pick up a lot of knowledge here.
