Very rare ERC
Started by okmulch, July 05, 2023, 03:45:18 PM
Brad_bb
Those are something else.  Given that they don't typically grow to make good beams that big, as the framer I would have talked them into switching to something else for those, which I assume are tie beams.  Maybe Western red cedar or doug fir.
okmulch
As of right now, I believe they are going to the Omaha zoo. I will find out more specifics when the customer picks them up this week.
They are also taking 20-13 in diameter 12 foot logs with the beams. The pic Doc Henderson took of the logs on the trailer are some of them.
Rotochopper b66 track, #2 Rotochopper b66 track, woodmizer lt40, CAT 277b, CAT 268b, CAT 287c, CAT 277c, CAT299d2, CAT299d3, CAT 299d3, Volvo 70e,volvo70f, volvo90f
Cedarman
I have been supplying this contractor for quite a few years.  Normally I would have suggested he use WRC. Since I knew we had these big logs and they were sound and we were waiting for the right application,  I said we could make them along with other materials he wanted.
okmulch
Well the beams were picked up this afternoon along with a load of logs to be made into columns using a lathe-mizer.
The final resting place will be at the Omaha zoo for the orangutan exhibit. These rare ERC beams will be in a great place for many to enjoy! We are working towards having a plaque installed explaining how rare the beams are for their size and species and a little history where they came from. We are glad to be a small part in this adventure and glad that these trees will make it to a good home.
I'm glad to hear you'll be making a plaque that points out the rarity of the timber in this species. Also that they will be on display with orangutans hanging off of them!😊
Walnut Beast
Excellent and nice job! Top zoo in the world! Exactly what Barbender said! Totally agree.
okmulch
Here is a picture of some of the exhibit the beams and logs were used in at the Omaha zoo. They are still finishing up the orangutan exhibit. Should be completed next week.
Nebraska
Geez now I'm gonna have to run down there and look now that I know the story on those.
customsawyer
It's always cool when you get to see where your product is used.
www.thecustomsawyer.com
I knew them before they were famous!   8) 8) 8)
   And here I was wondering what they'd look like after the buyer painted them. :D
