Rope
Started by Rat Rod Mac, October 01, 2014, 08:30:25 AM
Rat Rod Mac
New guy here and have a dumb question for the pros. I need a rope to use to tie to a tree when sometimes you have to help guide it when it falls. Something to tie on the draw bar of the tractor to put tension on the tree. What rope should I get as far as material,,, nylon, polypropylene, etc, etc. And what size diameter do you think would be best with out getting too crazy with diameter. 1/2" or maybe 5/8" or how about 3/4". I was figuring about 150" would do it. What do you guys say? Thanks in advance.    RRM
thenorthman
3/4 nylon works pretty good, 5/8 will do ya.
If your at all concerned about it, order some actual bull line from baileys, much stronger then the stuff you get at the hardware store.
I prefer 1/2" cable though.
well that didn't work
GAB
The size of the tree involved and other needs to miss targets, has a lot to do with the proper size rope to use.
Personally I prefer the 3/8" wire rope attached to a winch mounted to the tractor.
The higher up the tree the the rope is placed, the more leverage thereby lessening the risk factor.
Gerald
Don't get anything that stretches... even if the rope doesn't break, but a hook breaks or pulls loose when the line is stretched, something is going to fly very fast and furious and some real hurt can happen.
I use 1/2" cable... more strength than the tractor has and it doesn't stretch.
Just to tip a tree, not much strength is needed but sometimes we try to pull more than needed.. ;)
bill m
Not sure how big the trees are that you will be pulling over or how much of a back lean they have but a 3/4 inch double braid will work fine.
Rat Rod Mac,welcome to the forum.
Rat Rod Mac
Thanks for all of the advise and suggestions. It's appreciated.   RRM
longtime lurker
Depends on the tractor.
As pointed out, a stretched rope snapping can whiplash and bite you.
Of course, a stretched cable snapping can whiplash and just cut you clean in half.
And theres been more then one death when someone tried to pull something down with a farm tractor, decided to give it a jerk to help it a little, and the tractor reared over backwards and landed wheels up on the driver.
Logging... no wonder my insurance premiums are so high :D
terrifictimbersllc
I have 200' of orange Samson double braid 3/4" rope and  2 matching aluminum blocks with 10' of the same rope on them too.  All from Bailey's.  This rope will stop my 7.3L 4x4 F-350 in 4wd on dirt, without any apparent ill effects.  Had them for years, very useful.
