How to Cut Wood Pegs / Dowels
Started by asca65290, June 10, 2011, 12:57:06 AM
asca65290
What is the best way to cut wood pegs or dowels out of a chunk of wood or a log?  I would like to make short (8-12") dowels out of Osage Orange.
Thanks for your help!  :)
Dowel makers, like the Veritas Dowel Maker, use square material and a socket that slips over the squared piece and a drill and run through the jig.  You can search Lee Valley for one , model #05J45.01
Lud
  • Shaper with round over bit.  Use longer stock. Cut to length.
    V block with a stop and hand plane.
    A lathe.
    Drill a hole in steel plate.  sharpen hole edge and pound stock thru to make peg or dowel
Brad_bb
I think of a Dowel as completely round as in turned on a lathe.  A peg however...  For timber frame pegs, you use a Froe and rive a straight grained log chunk into square blanks, keep them wet, and draw knife them on a shaving horse.
shelbycharger400
about a month ago i found a 24 spindle lathe on craigslist with duplicator.    I cannot remember the brand. they make gunstocks and such.    The picture looked intimidating. with 15 in between the centers.   One motor drove 4 centers.
Phorester
How many do you want to make?  If just a few, maybe a hatchet for roughing them out and a and drawknife or even a pocket knife for smoothing.
If you need a bunch, or if you'd be making some every year, maybe go with one of the options suggested by the others here.
asca65290
Thanks for everyones help.  I was looking for advice on how I could make a number of them relatively quickly.  I like the Dowel Maker product recommended by SwampDonkey.  Thanks again for everyone's help!
ljmathias
I bought a box of 40 or 50 from a dedicated maker- for the price, and given the time it would take me to learn how to do it and then make them myself, I couldn't justify not buying them.... plus they offer a wax coating that makes them slide in better.  Just my opinion, though, time being money and all.
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
low_48
Here is a link to a site for making a jig that uses a chisel as the cutting tool. A cheap version of the Veritas jig.
http://woodgears.ca/dowel/making.html
terrifictimbersllc
For timber framing pegs I rip wood into square stock corresponding to the right diameter.  Then set the table saw at 45 degrees and make octagons out of them.  Goes pretty fast.
