Wood-Mizer LT30, LT40, LT50 quick access drive belt tension modification.
Started by Dave Shepard, December 02, 2021, 04:16:32 PM
Dave Shepard
As most Wood-Mizer owners know, drive belt tension is critical to proper operation of the sawmill. As I've just installed a new drive belt on my mill, and it has required several adjudtments as it has broken in. This means removing six bolts and a couple of covers. Not a huge deal, but a bit of a pain when it's dark and your fingers don't work well in below freezing temps. I know belt tension can cause sawing issues, but it's just long enough between needing to make adjustments that it can bite me every few years. I think the book says to check every 40 hours, but that could be months, depending on what I'm working on at the time. The simple solution is a small hole in the belt cover. Now I can check the tension quickly, and I don't have to take the covers off unless I actually need to.
https://youtu.be/JmLfCeyuD6A
Southside
White Oak Meadows
Dave Shepard
You read the scale on the side of the gauge at the cover and depress 7/16". My Super is 18#@7/16". It's hard to see in the video, but the gauge has Imperial and metric markings.
Andries
LT40G25
Ford 545D loader
Stihl chainsaws
Southside
Ahh, have to check my gauge, been doing it with a tape measure in one hand and the gauge in the other.
White Oak Meadows
BandsawBen
Thats seems like a great idea. You can use the shroud as the gauge. I like it and will be drilling a hole.
John S
Newer models have a small access plate with two bolts for checking the tension. I still remove all six bolts and clean out the sawdust in there.
2018 LT40HDG38 Wide
Thanks Dave Shepard, I drilled a hole today.
It works perfectly but I probably will now have to remove the cover more often after verifying that I am a bit slack.
Stephen1
Thats a simple fix!. The newer mills as stated have a access hatch built in. Shows the engineers listen to the sawyers and thier issues.
Dave Shepard
Version 2.0. I'm reminded of my mother's favorite saying "You're always doing something rash!"
I might put the piece I cut out on a hinge, but probably not. Drive belt tension isn't really a pain, but I'm sure it will get done more often now. Break-in of the new belt has required a number of adjustments, and my hands don't work well in the cold. Now I can do it all with gloves on. I was down to 11# from the 18# it was supposed to be.
Dave Shepard
You could, but I still have my board return installed, which makes it a tight fit to remove the cover just by unbolting it.
Crossroads
Great idea! Now I'll have to put the electoral tape 7/16" out from the cover. I'm a bit clumsy and struggled to hold a straight edge still while pressing the gauge 7/16". Can't walk and chew gum either
Unclefish
PAmizerman
I did that years ago. I have a piece of masking tape wrapped around my Guage that is 7/16"
Away from the cover once inserted into the hole. No measuring tape needed.
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Dan_Shade
@Dave Shepard does your access panel invite bird nests and/or fill up with dyst/bark debris?
lots of dull bands and chains
Dave Shepard
