Author Topic: Stainless buck covers  (Read 2303 times)
Offline Dana Stanley
  • For fun and profit!
    • Stanley Carpentry Construction
« on: June 24, 2019, 02:32:15 PM »
Can anyone point me in the direction of stainless bunk covers. I checked the Woodland Mills site, as they have them on the HM130, but I didn't see them for sale as an accessory!
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
Offline Pabene
Re: Stainless buck covers
« Reply #1 on: June 24, 2019, 03:39:25 PM »
I would order stainless steel covers from a sheet-metal shop in your aria. Remove one bunk from your mill and and bring it to the shop, ask them to make covers for you. I am sure you then can epoxi glue it to your bunks, clamp the covers as the epoxi cures.
« Reply #2 on: June 24, 2019, 04:58:23 PM »
Can someone with a HM30 tell me how thick the covers that Woodland mills uses are? I'm thinking they just protect the paint so the bunks don't rust out!(edited-Also protect wood from stains) I don't know that I need stainless. I was thinking 26ga zinc Galvanized from HD is 26.00 for a 2x3 sheet. I have a shear and brake that can cut and bend that. The bunk has holes already for bolts. Any thoughts on that? I just don't know what is commonly uses on 3x6 bunks.
I don't want to spend too much more on this, as so far it is just a hobby. I'm a yankee, we are notoriously cheap. That's why we came up with Yankee ingenuity!  8) I hate moving emojis! That's why although good advice,(thanks) I'm not jumping on the have them fabricated idea.
Matthew 3:10
Online btulloh
« Reply #3 on: June 24, 2019, 05:16:10 PM »
I donít worry about it on my hm126. Using it keeps the rust off. If it sits, Iíd spray something on to protect it. Maybe clean it, ospho it, and hit with a little paint. After three years, mine is not hurting.
« Reply #4 on: June 24, 2019, 05:43:28 PM »
From what I understand, and have seen, the rusting metal can quickly stain some wood. Although so far I just make sheds and fence posts. I do want to make some finer wood projects. Signs for one thing. That was a big reason for getting it, to make wider planks for signs, and cedar if I can get my hands on some. Not real common here anymore.
Matthew 3:10
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: June 24, 2019, 08:45:50 PM »
It's not necessarily rust but the tannic acid particularly in Oak that reacts with iron and stains the lumber blue.  The stainless steel covers isolate the iron in the sawmill from the tannic acid in the log/cant.
The same thing that happens when metal is in Oak and some other species.
There was no doubt that this Walnut log contained metal, and it did.
Neither was there any doubt about this White Oak log on the right.
Offline twobears
  • sawdust runs in my veins..
« Reply #6 on: June 24, 2019, 09:53:28 PM »
it really wouldn't matter how thick it was as long as there all made with the same guage metal..i'de use stainless steel tho.i'de use 1/8 inch or maybe alittle less.
« Reply #7 on: June 25, 2019, 07:27:32 AM »
In my short time sawing I have seen it. One day it began to rain so I went in, and overnight the cant on the mill developed a large deep stains. (Oak)
Matthew 3:10
Offline Hilltop366
« Reply #8 on: June 25, 2019, 07:44:03 AM »
I used wood (spruce) with counter sunk bolts over the steel on my DIY mill.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #9 on: June 25, 2019, 08:01:39 AM »
Definitely do not use galvanized it will get you nothing other than where you are now. Stainless is the only way. I would recommend 16 ga wrapped completely over the bunk then bolt each side to the edges of the bunk. that way it will not move or get peeled when sliding logs around.
I noticed with my mill I got the stains on the wood immediately just from flipping them around. I am looking at doing the stainless steel bunks but need to figure out how with my clamp setup.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #10 on: June 25, 2019, 09:08:28 AM »
I made mine using basic sheet metal tools.  1/16Ē stainless, bent into a U shape, slipped over the tops of the bunks and sheet metal screwed into the sides.  They keep the wood from turning blue.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
« Reply #11 on: June 25, 2019, 10:15:28 AM »
I worked with sheet metal including stainless for the last 30+ years and I would recommend not going less than 16 guage (1/16") if possible for bunk covers.
Ray
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline Tropical Sawyer
« Reply #12 on: June 25, 2019, 06:53:13 PM »
Can't help you on where to buy them from, but if you want to make your own, I measured mine which came from the factory and they are 1.7mm thick.
Definitely make them out of stainless. A benefit which I don't think anyone has mentioned yet is that stainless is very smooth and "slippery" compared to galvanized. This makes it much easier to turn and handle logs on the mill.
They also look pretty flash :).
As Crusarius mentioned the factory ones are wrapped around the tops of the bunks and bolted in place on all 4 corners. Seems to work pretty well.
Woodland Mills HM130, Stihl ms310 and ms660, Granberg chainsaw mill, 3 ton Kobelco excavator, 1 ton Chinese front-end loader.
New to sawmilling but have been chainsawing for a few years.
« Reply #13 on: June 25, 2019, 06:58:29 PM »
Here's a picture of mine.
Online lxskllr
  • dummy with saw
« Reply #14 on: June 25, 2019, 08:16:10 PM »
Would aluminum work? That would shave some $ over stainless.
Offline D6c
« Reply #15 on: June 25, 2019, 10:00:47 PM »
Don't know what size your rails are but I bought stainless covers from woodmizer for my mill.  (2" rails). Weren't too expensive.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #16 on: June 26, 2019, 07:35:23 AM »
Aluminum is to soft and won't last. Will deform first time you drop a log on it.
« Reply #17 on: June 26, 2019, 12:13:48 PM »
. Thanks for the pic. I had ordered 24ga sheet but after seeing you post I canceled and will look for 14 ga. Which should match yours! Thanks again.
Matthew 3:10
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #18 on: June 26, 2019, 12:18:15 PM »
16 gauge should be fine that is 0.060"
« Reply #19 on: July 01, 2019, 09:35:55 PM »
I ordered a pc of 16Ga. 304 stainless 24x24 for $40.00 from ebay. Now I need to find someone to cut and bend it. I don't think my finger brake/shear will handle it.
Matthew 3:10
B20 Stainless bed covers
Started by logloper on Sawmills and Milling
Last post May 25, 2011, 11:58:25 PM
by redbeard
installing your own stainless steel bunk covers
Started by kelLOGg on Sawmills and Milling
Last post November 23, 2010, 03:30:21 AM
by weisyboy
Woodmizer stainless bunk covers on LT15
Started by Gagnon Mountain on Sawmills and Milling
Last post October 04, 2018, 05:58:02 PM
by Bruno of NH
Buck Knives & Buck Knife Co. Warranty
Started by Shotgun on General Board
Last post November 22, 2011, 07:14:11 PM
by Logjam
