Author Topic: Stainless buck covers  (Read 2305 times)
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Stainless buck covers
« Reply #20 on: July 01, 2019, 10:02:21 PM »
it is not rated to handle it but it might. may need to do some reinforcing to make it work. as for cutting sheet metal best way I have found is plasma. next best would be metal cutting circular saw. Jigsaw is last option.
Bandsaw or porta band will work great as long as you have a deep enough throat.
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #21 on: July 01, 2019, 11:48:12 PM »
It will cut easy on a manual, foot operated shear, and decent brake.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Offline frazman
« Reply #22 on: July 02, 2019, 07:15:05 AM »
The stainless steel covers are sold as an extra from Woodland Mills at 2 per set.
I will have some made from a metal shop once I purchase the HM 126 this fall...
Offline Dana Stanley
  • For fun and profit!
    • Stanley Carpentry Construction
« Reply #23 on: July 04, 2019, 09:09:23 PM »
I e-mailed them, they want $75.00 for two, I need 5. Making them makes sense for me, as I have the time and ability to do it myself. I convince myself that doing this stuff on a low budget is a fun challenge! I isn't an unreasonable price, but again this is a hobby for now, so if I can do it for less I need to.
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #24 on: July 05, 2019, 06:36:27 AM »
Quite a while back, someone had a set of them from a Wood-Mizer mill for sale (in the For Sale section) here on the Forum!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
« Reply #25 on: July 10, 2019, 08:28:52 PM »
So the stainless came in today, and I tried to cut it with my 30 year old HF brake/shear. Well the cast iron table for the shear cracked! I ordered a metal saw from Eastwood! Ill get on it when that comes in.
Matthew 3:10
Offline frazman
« Reply #26 on: July 10, 2019, 11:03:41 PM »
Yes, s/s can be a tuff metal to work with. Good luck with your project. Hope it all turns out well...
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
« Reply #27 on: July 11, 2019, 01:25:30 AM »
Stainless is a harder metal to shear and it's also a harder metal to bend on a brake press, likely the nickel content.  You have to make different allowances for it compared to regular sheet metal, depending on the type of bends. It tends to bend with a bit larger radius, not as tight as regular sheet metal.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #28 on: July 11, 2019, 07:12:39 AM »
when you drill it, DRILL IT SLOW! if it turns red when you are drilling go full throttle and get it done as fast as you can. Once it cools it is quite a bit more challenging to drill. Make sure you have plenty of sharp drill bits on hand. Stainless is a bear to work with in all aspects.
And make sure you wear gloves. It is not very forgiving if you slip.
Offline VB-Milling
  • Always learning
« Reply #29 on: September 15, 2021, 02:54:35 PM »
I'm curious as to whether the DIY covers ever happened.  I see @Dana Stanley hasn't logged on in a while though.
HM126
Offline maple flats
  • Life is what you make it!
    • cnymaple.com
« Reply #30 on: September 19, 2021, 11:39:24 AM »
Use Cobalt drill bits, not cobalt coated. They will work best. I've drilled plenty of SS in the past, until I had Cobalt bits I was lucky to get 1, sometimes 2 holes before the bit needed sharpening and if it had gotten hot, it was junk. 14 ga SS will be a challenge, use good cutting oil and keep it flowing.
B20 Stainless bed covers
Started by logloper on Sawmills and Milling
Last post May 25, 2011, 11:58:25 PM
by redbeard
Woodmizer stainless bunk covers on LT15
Started by Gagnon Mountain on Sawmills and Milling
Last post October 04, 2018, 05:58:02 PM
by Bruno of NH
installing your own stainless steel bunk covers
Started by kelLOGg on Sawmills and Milling
Last post November 23, 2010, 03:30:21 AM
by weisyboy
Buck Knives & Buck Knife Co. Warranty
Started by Shotgun on General Board
Last post November 22, 2011, 07:14:11 PM
by Logjam
