Blade guide design?
Started by Satamax, April 09, 2021, 03:33:31 AM
Satamax
Hi everybody.
I need your help for ideas.
I have a friend who has the same brand sawmill as mine, but the model after. My blade guide is a ........ (type the word you want)
His looks like this.
I find this better than mine. But i would like to add a "tilt" So i could raise or lower a smidge the front of the blade if i need to. Any idea. One which comes to mind, thicker polyethylene pads, with a fulcrum in the middle, and two recessed screws front and back. To adjust.
Thanks guys.
French CD4 sawmill. Mecalac digger, with grapple. Self moving hydraulic boom crane. And a Brimont TL80 CSA.
Osterman.r
Look into a cooks saw single roller guid retro fit kit. They've got it figured out over there at cooks saw.
Satamax
Quote from: Osterman.r on April 09, 2021, 04:56:11 AM
Thanks a lot. But i don't think that would work. Blades are about 5 inch wide!  ;D
Osterman.r
Aha, sorry, I didn't take a good enough look at your blade in your pic. That must be a big mill.
ladylake
 Seems like if you put any pressure on those sandwich guide it would heat them or the blade up fast.  Steve
Satamax
Well, i don't know, it's special anti friction plastic. And it's lubricated the the cutting "coolant".
