Author Topic: Blade wonít go back on wheels  (Read 705 times)
Offline Tcbitt
« on: April 12, 2021, 08:18:53 PM »
Hello all.
I just got my woodland mills HM126 and so far have only tested it out on a few small logs. Last time I fired it up, as soon as I hit the throttle, the blade jumped off. I noticed a few teeth were gone, and looks like it dug into the blade guard when it happened.
My problem is that when I went to replace the blade, itís impossible to get t on the wheels. Iíve loosened the T bar as much as it will go and pushed it in. Thereís still not enough play to get it the new blade back on the wheels. Iíve combed thru the manual trying to figure out what other possible adjustments could be causing the issue. Is there a way to get the follower wheel to move over more to be able to get the new blade on?
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Blade wonít go back on wheels
« Reply #1 on: April 12, 2021, 08:22:45 PM »
Is your new band the same length as your old band?
lots of dull bands and chains
Offline Tcbitt
« Reply #2 on: April 12, 2021, 11:42:05 PM »
Yeah, I tried both the old blade and the new blade... both from WM.
Seems that when I loosen the tension, I can push the handle which moves the follower wheel a bit, which is helpful. But itís not enough to get the blade on still.
Offline Dan_Shade
« Reply #3 on: April 13, 2021, 02:21:18 AM »
What type of tensioner?
Have you tried manually pushing the wheel towards the center?
Offline Dan_Shade
Re: Blade won’t go back on wheels
« Reply #4 on: April 13, 2021, 02:28:25 AM »
I looked at the manufacturer website, it says tool less blade change, and that the tension is accomplished by using Bellville washers. {I'm pretty sure that those are cone shaped}.
Do you know how to relieve the tension?
Check out pages 62-64 of your manual:
https://cdn.woodlandmills.ca/resources/english/2021/hm126-manual.pdf
Offline tacks Y
« Reply #5 on: April 13, 2021, 08:30:32 AM »
Are you sure one of yours wheels is not cocked around? In other words it slides back but the wheel also need pushed against its adjustment stop.
Offline Shanem
  • Member*
« Reply #6 on: April 20, 2021, 06:25:37 PM »
I ran into as well. Just keep turning t handle counter clockwise a few more turns and it will expose the threads....then just push t handle in towards the motor. Should go right on then
Online farmfromkansas
« Reply #7 on: April 20, 2021, 06:53:23 PM »
I have had to take a big C clamp and push my MP32 in to get a new blade on.  Had mine 16 years and it had gotten a little stiff.
Offline Iwawoodwork
« Reply #8 on: April 22, 2021, 12:42:03 AM »
I use the handle of the 12" crescent type wrench  as a lever between the wheel  and housing/shield to get the idler wheel over enough to install the new .045 thick blades on. You may have to use some leverage/ pry stick to move the wheel far enough
Offline woodland84
« Reply #9 on: April 22, 2021, 08:15:39 AM »
I had the same issue once. The tensioner gets stuck. Unthread the handle some more and give it a few shakes to loosen. It should then be able to push in further.
Tilt on blade wheels
Started by welderskelter on Sawmills and Milling
Last post July 01, 2018, 06:59:09 AM
by ladylake
belts for the blade wheels
Started by randy r on Sawmills and Milling
Last post December 14, 2012, 01:38:00 PM
by randy r
Dressing bandmill blade-wheels
Started by Chuck White on Sawmills and Milling
Last post April 21, 2018, 07:57:17 PM
by bandmiller2
B56 belts for Wood-Mizer blade wheels
Started by LT40HDD51 on Sawmills and Milling
Last post May 13, 2020, 11:17:01 AM
by VooDooChikin04
