Author Topic: Need advice on sawing locust  (Read 441 times)
Offline TmbrWlkr
« on: April 13, 2021, 11:13:51 PM »
I have a Norwood HD36 and am still learning.  Got it to augment my main business which is salvaged industrial timbers ( pretty much all softwoods).  Now I am going to be sawing locust posts for a retaining wall.  Any advice on blades wood be appreciated.  Thanks in advance.
Online Bruno of NH
Re: Need advice on sawing locust
« Reply #1 on: April 14, 2021, 07:35:03 AM »
I have sawn lots of black locust logs as of late.
WM turbo 7's have worked well for me when the logs aren't frozen.
The dust is the not so fun thing about it.
You also need to flip the logs alot as sawing.
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #2 on: April 14, 2021, 09:13:57 AM »
Is the locust dry or green?  Dry locust fits on the spectrum somewhere between cast iron and mild steel.   :D
Wudman
You may tear down statues and burn buildings but you cant kill the spirit of patriots and when theyve had enough this madness will end.
Charlie Daniels
July 4, 2020 (2 days before his death)
Offline Patrick NC
  • I'm not new anymore, but still pretty green
« Reply #3 on: April 14, 2021, 12:36:11 PM »
I use 7 kasco blades on my hd36 for everything from white oak to yellow pine and cedar. It's the same profile as the Norwood 7 sabertooth but $5 cheaper per blade. I've never cut locust, but I have cut some dry white oak with no problem. If it's harder than white oak I'd probably try 4
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #4 on: April 14, 2021, 03:22:06 PM »
7 turbo for me. It's hard but not as hard as steel.
Online doc henderson
« Reply #5 on: April 14, 2021, 04:01:15 PM »
a straight log with be great, any branch point will tend to pull you blade a little.  very dense.  cut a bit thick so you have some room to flatten and plane.  I have only sawn honey locust
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #6 on: April 14, 2021, 05:53:35 PM »
Center your pith posts,
If they're green you should be fine
dry is a bit tougher,
Strip the bark off before you start sawing.
D
Offline TmbrWlkr
« Reply #7 on: April 14, 2021, 06:27:30 PM »
Ok guys - thanks for all the advice. Cut 6 posts today with the blade that was already on the mill (ashamed to say I dont know the brand (1 1/2 7 degree). Seemed surprisingly ok - but logs are only 3 weeks out of the woods.  Back at it tomorrow and will switch to a Norwood 7 degree - seems the key is to cut it green?  Will keep you updated.
Offline Gary Davis
« Reply #8 on: April 14, 2021, 07:55:03 PM »
I have been cutting black locust with 10 degree with no problem
Need advice on sawing black locust 6x6 posts for customer
Started by hunz on Sawmills and Milling
Last post March 04, 2014, 07:31:31 AM
by Seaman
locust sawing
Started by heavyhorseman on Sawmills and Milling
Last post October 10, 2003, 02:19:22 PM
by shopteacher
Next sawing project - locust
Started by NCDiesel on Sawmills and Milling
Last post May 07, 2013, 02:02:19 AM
by mesquite buckeye
sawing Locust logs?
Started by oregonsawer on Sawmills and Milling
Last post April 07, 2008, 07:13:29 PM
by Ironwood
