Author Topic: Got old Betsy back up and running.  (Read 829 times)
Offline customsawyer
    • The Custom Sawyer
« on: September 19, 2021, 08:46:27 AM »
After the ordeal of getting my LT70 home from Hazelhurst I finally got her back up and running. It had the 24' ext. with the hyd. on it but I also had a 12' ext that I wanted to add to it. Well that wasn't as easy as I thought it was going to be. The top and bottom rail on the 24' ext. were not drilled and they were ĺ" short. Thus I had to drill them and then make a bushing to cover the ĺ" gap and make my own extra long pin to connect the two ext. together. Here she is setting on a 65' pad with a 36' log on her. I went ahead and removed the axle since it basically removed it self. Yes I bolted her down.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: Got old Betsy back up and running.
« Reply #1 on: September 19, 2021, 09:37:26 AM »
Thatís impressive!
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline Southside
    • White Oak Meadows
« Reply #2 on: September 19, 2021, 10:37:59 AM »
One or two more extensions and you can hook it up to Dannys saw and cut from either end of the log.   :D
White Oak Meadows
Offline Andries
  • Making buildings out of big curvy logs
« Reply #3 on: September 19, 2021, 10:52:47 AM »
When I had twelve and twenty four foot extensions on my LT30, the feed chain spur wore down quickly. I tried to figure out a way to support all that chain but didn't come up with a decent solution. D'you know any NASA engineers that could sketch up a solution to that little issue? 😆
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline GAB
« Reply #4 on: September 19, 2021, 11:31:32 AM »
Jake:
Do you have any pictures or drawing of your new alignment pins?
Looking at the picture you posted it looks to me like if you were to cut it into two pieces you should be able to get more usable lumber.  Looks like it has quite a belly.
GAB
    • The Custom Sawyer
« Reply #5 on: September 19, 2021, 11:45:15 AM »
Jake:
GAB
I cheated on the alignment pins. I just got 2 grade 8 bolts Ĺ" by long enough that I could cut the head and threads off and used the smooth part. ;)
As to the log having a little belly in it it (Tom) did. That is one of the reasons I charge extra for the long material, is to absorb some of the extra waste. This customer needed 25 ft. boards for a lowboy but with that much sweep in the log I left it attached until I could get my first two faces cut. The extra length let the log reach my hyd. toe board rollers, turner and clamp on the 24 ft. ext. This makes the log handling easier on the first two cuts. After that I cut a 10' log off the small end and moved the log up to the front of the mill.
Offline GAB
« Reply #6 on: September 19, 2021, 12:00:58 PM »
So you did what was best based on the equipment you have.
I like it.
GAB
Offline jmouton
  • never enough time
    • Log-Gistics
« Reply #7 on: September 19, 2021, 06:52:58 PM »
now you have to hook up the sawdust blower,  or youll be like us using a snow shovel to get it away
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #8 on: September 19, 2021, 07:13:48 PM »
I think there is a now an 8th Wonder of the World.  Along with the Pyramids and the Great Wall of China is Jake's "Mile Long Sawmill."
Seriously, what is the longest Woodmizer in history?  Is this it?
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Offline GAB
« Reply #9 on: September 19, 2021, 07:43:39 PM »
I spoke with the CFO for WM around 2000 and he said they had sold one mill with four (4) 24' extensions.
And I said to who and what was it for?
He replied: to the U. S. Navy they were building the replica of a ship and needed to cut masts.
That is the longest that I heard of.
GAB
    • The Custom Sawyer
« Reply #10 on: September 20, 2021, 06:12:40 AM »
I figure there might be once or twice that I will actually need the extra length. It sure is fun to hear the gasp on the other end of the phone when someone is thinking they are going to challenge your operation and they ask how long can you mill. They usually need something around 25' long so when you hit them with 56' you almost always get that long pause on the other end like they are trying to think of something that they might can use that long just so they can say they had it cut.
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #11 on: September 20, 2021, 06:31:06 AM »
Cutting it is tough enough, transporting it is another issue. ;D
 Man that is SOME mill! You should take some good photos and make a calendar up, now that's eye candy! Just the thought of trying to level the pith on a log that long or handling slabs has already cost me some sleep. :D
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Offline kelLOGg
« Reply #12 on: September 21, 2021, 06:06:49 AM »
My mill came as a manual mill and I added 2 drive chains. Even though it cuts just 20 feet (long to me) I didn't want chain hanging freely in easy access of dropped boards and other accidents that could hit the chain. So I did this:
I welded a 1 x 2 channel iron for the upper loop to slide on and the return loop passes through a pipe with a PVC pipe inserted  to minimize chain wear. I put a screw through the channel into the PVC to keep the chain from dragging the PVC out. On the top loop there is slight wearing of steel on steel but so far (16 years or so) there is minimal wear and it still works fine. For heavily used mills a thin layer of HDPE sheet could be added to the channel surface for further protection. I can stand on the 1 x 2 channel but it is not heavy duty so logs shouldn't hit it and they don't because the loading ramps don't make contact with the channel. There is no noticeable wear on the drive sprockets.
Offline thecfarm
« Reply #13 on: September 21, 2021, 06:13:03 AM »
Must use hand signals for the guy on the other end.  ;D
LT 35HD back up and running with pics. (customer service still exists!)
Started by MReinemann on Sawmills and Milling
Last post October 11, 2012, 07:25:39 PM
by MReinemann
back in the woods and back in the game
Started by Quebecnewf on Forestry and Logging
Last post February 12, 2011, 09:13:50 PM
by Ed_K
He's Back!!! I figgered he would find his way back!!!
Started by ADAMINMO on General Board
Last post March 13, 2008, 10:42:54 PM
by Warbird
What does it take to keep a saw running?
Started by cnl390 on Chainsaws
Last post August 17, 2011, 04:27:22 PM
by shelbycharger400
