Author Topic: What size band  (Read 223 times)
Offline Welshman
  • Member*
What size band
« on: September 27, 2021, 06:04:37 PM »
What is the best size band blade to use 1 1/4 or 1 1/2 inch wide and number of teeth
Offline Lasershark
Re: What size band
« Reply #1 on: September 27, 2021, 06:36:51 PM »
I recently switched from 1.25" to 1.5" and I've found the wider blades cut straighter and resist deflection better than the others. They also don't seem to break as often, although this may be a change in my setter technique. As for number of teeth, I believe 1" spacing is standard, so a 158" blade has 158 teeth:
Wood-Mizer LT28, LT35, LT40, LT50, HR120, HR130, HR300, HR500158"
Whereas I run a Wide head:
Wood-Mizer LT40 WIDE, LT50 WIDE 171"
Woodmizer Blades
2020 LT-50 Wide, 38 HP Gas, with debarker, lubemiser and laser sight,  2002 Dodge Ram, Husquvarna 365 chainsaw, comealong, couple cant hooks and a strong back.
Offline Southside
    • White Oak Meadows
Re: What size band
« Reply #2 on: September 27, 2021, 08:21:22 PM »
What are you running for a mill and engine? What type of wood do you saw?
White Oak Meadows
Band Wheel Size VS Motor Size?
Started by skocienski on Sawmills and Milling
Last post March 07, 2012, 09:43:25 PM
by pyrocasto
band wheel size
Started by fathead on Sawmills and Milling
Last post November 06, 2011, 01:05:07 AM
by fathead
Band Wheel Size?
Started by WyMan on Sawmills and Milling
Last post March 08, 2003, 07:24:36 AM
by WyMan
The size of forces and speeds in a band saw
Started by Pabene on Sawmills and Milling
Last post September 26, 2017, 11:52:42 PM
by Brucer
