Wild Fire 2024
Started by Riwaka, February 20, 2024, 02:55:23 PM
Riwaka
German wild fire unit.
REBO is introducing the FLM 2000 for the first time. With this front-mounted extinguishing unit, equipped with a water cannon, it is possible to use the REBO Rack as a protected and even remote-controlled fire engine. The REBO Rack FLM can be equipped with different launcher sizes and up to two launchers. The system is controlled via ISOBUS. This system was created in cooperation with the company AWG Fittings and the company Agribumper. The REBO Rack Steel Buddy travels on tracks from Zuidberg.
https://youtu.be/mkj7N2HuP_I?si=OvgYJ9_hW_p6Xo2l
Firewoodjoe
That's quite the rig. Are those explosives to to put out the fire also?
Riwaka
Not sure.
There is leftover ww2 & training UXO (unexploded ordnance) in parts of Germany. Water cannons appear to be used to keep fire staff and machinery away from areas where hot uxo may be present and potentially cooking off. I would not want to have a Pulaski to cut a fireline through those areas.
https://www.aljazeera.com/news/2022/8/4/fire-triggered-by-explosions-spreads-in-berlin-city-forest
Riwaka
40 000 acres of farmland and forest burnt so far in a wild-fire west of Ballarat, Victoria, Australia with hot strong winds from the desert regions expected in a few days time.
Belly tank helicopters on the job.
https://youtu.be/ytLRLn_Q81M?si=6hK8oTmcRpeHMXNd
Riwaka
A few hours left of bad fire conditions in Victoria. They did have 100F (40C) and winds of 60mph (100km/h) at the end of the day. Obviously a hard task to keep the 50 000 acres burnt so far of the Bayindeen Fire contained. Reports of flare ups outside the containment lines and new fires starting elsewhere.
The catastrophic conditions occurred over a wider area than anticipated (as reported by automatic weather stations)
There is video of Skycrane helicopters with both bucket and belly tanks operating.
Riwaka
Everything is bigger in Texas, it appears including the wildfires.
Riwaka
Australia's Victorian Country Fire Authority conducts water drop tests from the saddle helicopters. Their first test drops in 10 years.
https://youtu.be/l2IJ9iU9VVs?si=E4TR98XeYXgU89HL
dominicelliott
Great, I will consider installing them in the near future
BAN
Anyone have info on wildfires in Virginia? Have a falling mod call to go over.
Riwaka
Deciduous leaves burning in spring. Also burning structures. Claim of fires started by out of control burns and tree branches etc falling on powerlines then into leaf litter etc.
Locations
https://www.fireweatheravalanche.org/fire/state/virginia
Thursday vid update
https://youtu.be/jtqyDWUBPKw?si=fsid_j92Q5bdMnts
nativewolf
Last nights rains will have put the stopper on the fires in the Shenandoah.  I was just outside Quantico, about 100 miles from the fires, and it was very smokey.
Liking Walnut
BAN
Quote from: nativewolf on March 23, 2024, 12:18:04 PMLast nights rains will have put the stopper on the fires in the Shenandoah.  I was just outside Quantico, about 100 miles from the fires, and it was very smokey.
That's good to hear. The guys are on the way over.  I'm sure there's enough fire weakened trees to keep them busy for a bit.
Riwaka
LA County Fire Department Caterpillar D8R fire dozer.
https://youtu.be/Y7vBqacEgw4?si=SSOl34305VFQccsv
ehp
Well as of right now I donot think you could start a fire in the bush with 5 gallons of gas , the forest floor is moving cause its flooded , been raining almost everyday for over a month
Riwaka
Wildfire California, Tracy - 2024
California Fire , Tracy, East Of San Francisco, 14K acres, high fuel loads of grass.
https://youtu.be/PG02YpZ8OIw?si=W48FSkI0JGxiuEqP
Whitehorse, Yukon fire break, being cut through the Spruce and Pine. Planting Alder, Willow and Poplar as alternative tree species.
https://youtu.be/ad1hlTOr-8s?si=_-HvHFPa8I1feEAj
rusticretreater
Quote from: Firewoodjoe on February 20, 2024, 06:49:50 PMThat's quite the rig. Are those explosives to to put out the fire also?
Oxygen depriving pyros using halon and similar gases that displace oxygen.  Kinda like using nitro to put out an oil well fire.  Boom and the flames are out.  Then you douse everything with water.
Run a tanker truck or two in there behind it and keep that sucker spraying.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
